Help set up my fuel system #1763614
02/26/15 02:50 PM
02/26/15 02:50 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Need to upgrade my fuel system on my street/strip Satellite. It's adequate for street use but has started to run out of fuel at the top of third when I've gotten on it on a hill (highway onramp).
Right now the engine is in the 525 HP neighborhood, car should run mid 11s but hasn't been down the strip yet as I'm still sorting it out. Plans in the near future are for headwork and 600-650 HP.
I'm thinking 1/2 inch pickup and fuel line up to the mechanical pump, with one Holley black pump. 9/16 line from the pump to carb with a dead head fuel pressure regulator. Does this sound sufficient? I would think that this should be more than enough but I really don't know.
Re: Help set up my fuel system [Re: GTX MATT] #1763615
02/26/15 03:19 PM
02/26/15 03:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why the 9/16 line... the 1/2 is your choke/flow
and is more than enough.. I assume you would run on
the mech pump and turn on the black when racing
Re: Help set up my fuel system [Re: GTX MATT] #1763616
02/26/15 03:35 PM
02/26/15 03:35 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
On my car I used AN-8 from the pickup at the tank to my mechanical Clay Smith pump. From the pump to the carb also used AN-8 and Holley reg. Deadhead system.
Re: Help set up my fuel system [Re: rt66jim] #1763617
02/26/15 04:48 PM
02/26/15 04:48 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I went with 1/2" stainless tubing from tank to frame rail by pump, -8 hose from tubing to pump then back to the tubing from pump to regulator, 3/8" tubing from regulator to each carb on a 572 hemi. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Help set up my fuel system [Re: MR_P_BODY] #1763618
02/26/15 07:51 PM
02/26/15 07:51 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Sorry Mr P - I meant 3/8 I just doubled it when I typed it up.
Is there a reason I couldn't run the black full time?
Re: Help set up my fuel system [Re: GTX MATT] #1763619
02/26/15 08:01 PM
02/26/15 08:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You would be getting marginal with 3/8.. I would
run 1/2 just in case... you can run the pump all
the time
Re: Help set up my fuel system [Re: GTX MATT] #1763620
02/26/15 08:22 PM
02/26/15 08:22 PM
I use to use a Holley blue 110 GPH electric pump between the tank and the Carter 3 valve NASCAR mechanical fuel pump on the motor without a regulator on my old NHRA 426 C.I. Max Wedge Stocker. The mechanical fuel pump will and does act as a pressure regulator My message is don't waste your time and money on a regulator now before trying that electric pump working in series with your mechanical pump A 1/2 inch O.D., 7/16 I.D. line, is fine as far as I've used for motors up to 700+ HP My new drag car will have a 5/8 O.D., #10 AN size, hardline from the pump to the pressure reg. mounted up front in front of the carb. due to shooting for 850 +HP carbureted now with EFI in the potential future for more power with a power adder later. I'll use #12 AN from the tank to the 500 GPH electric pump to start with, over build it once instead of doing it twice BTW, how many GPH is that Holley black pump rated at
Re: Help set up my fuel system [Re: Cab_Burge] #1763621
02/26/15 08:48 PM
02/26/15 08:48 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I like the KISS method.... I ran 1/2 line up to the passenger fender to the regulator then used two 3/8 lines from there to the carb. I used the Holley Blue pump with regulator. Works fine on my car. No pressure problems. My motor is over 650hp. I run it on the track and street with no issues.
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Help set up my fuel system [Re: QTR MILR] #1763622
02/26/15 09:51 PM
02/26/15 09:51 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Cab its 140 gph
Re: Help set up my fuel system [Re: GTX MATT] #1763623
02/27/15 01:08 AM
02/27/15 01:08 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I just run a stock fuel tank and a stock 3/8 sending unit. I use just the Holley black pump with 3/8 line to the deadhead regulator and to the carb an 850 DP. Its been feeding my 440/493 fine and it works nice driving on the street all the time as I drive it alot. Ron
Re: Help set up my fuel system [Re: QTR MILR] #1763624
02/27/15 12:37 PM
02/27/15 12:37 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Re: Help set up my fuel system [Re: actionange] #1763625
02/27/15 01:43 PM
02/27/15 01:43 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Thanks for the info guys.
Heres another question, looks like the Holley Black uses 3/8 NPT input and output. I can't find a flare nut for 3/8 NPT for 1/2 inch line anywhere, what gives?
Re: Help set up my fuel system [Re: GTX MATT] #1763626
02/27/15 01:47 PM
02/27/15 01:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a adapter from 3/8 to 1/2.... also I like to drill
out the adapters to get a bit more flow
Re: Help set up my fuel system [Re: GTX MATT] #1763627
02/28/15 02:07 PM
02/28/15 02:07 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I'd very interested to see some pics of where you mount the pump when you get to that point. I am going to have to go the electric route on mine.
Re: Help set up my fuel system [Re: Belvedere1] #1763628
02/28/15 03:27 PM
02/28/15 03:27 PM
You should mount all electric fuel pumps, unless the instructions say other wise, as close to the tank as possible and lower than the bottom of the tank
Re: Help set up my fuel system [Re: Cab_Burge] #1763629
02/28/15 03:50 PM
02/28/15 03:50 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
What are your future plans/goals? My advice would be to go somewhat overkill on the lines. It gets pricey replacing lines and fittings 2 years from now when you build a new motor or decide to add a little spray. Ask me how I know .....I would go with -8 minimum from the tank to pump and from pump to regulator (skip the mechanical pump), and -6 from regulator to carb. Just my
Randy
Re: Help set up my fuel system [Re: Cab_Burge] #1763630
03/04/15 01:53 AM
03/04/15 01:53 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Right, but I was referring to specific location as in on the inside or outside of the frame rail, mounted to a bracket, clearance from mufflers, etc.
Re: Help set up my fuel system [Re: Belvedere1] #1763631
03/04/15 02:25 AM
03/04/15 02:25 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Not sure, I was thinking inside the rear frame rail where it goes up over the axle assuming it looks good in relation to the sending unit when I get under there again. I'll have to get under it and look around once the snow melts.
Re: Help set up my fuel system [Re: MR_P_BODY] #1763632
03/04/15 02:53 AM
03/04/15 02:53 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Will a mechanical pump draw through an electric pump when on the street just driving around? I wouldn't mind having an electric pump at hand for race duty, but it would be nice to be able to drive around town on just the mechanical pump.
(sorry for the hi-jack)
Re: Help set up my fuel system [Re: StealthWedge67] #1763633
03/04/15 03:20 AM
03/04/15 03:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
My buddy does it on his 460.. mech pump with a holley
blue in the rear... so yeah I guess it works..he
has been doing it about 6 years now... he runs 11.50
on motor and 10.80 on a little spray
