semi-chrome polish on tail light lens? #1763355
02/26/15 03:04 AM
02/26/15 03:04 AM
Tacoma, Washington USA
Adam71Charger Offline OP
Looking for a polish to take the haze out of tail light lens, I've used semichrome on plastic trim, will it work for lenses (red and white)?
Re: semi-chrome polish on tail light lens? [Re: Adam71Charger] #1763356
02/26/15 03:17 AM
02/26/15 03:17 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Meguiars makes a plastic polish, works great on lenses for removing that "dead" hazed look
Re: semi-chrome polish on tail light lens? [Re: Adam71Charger] #1763357
02/26/15 04:29 AM
02/26/15 04:29 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes, will work with various results depending how bad they are to start. Wenol will work about the same too. They both are sort of similar products.
Toothpaste will work too.
Also wet sanding from 600-800-1000-then fine rubbing compound and plastic polish will give really nice results. Depending on scratch depth you may need to go
Re: semi-chrome polish on tail light lens? [Re: autoxcuda] #1763358
02/26/15 11:25 AM
02/26/15 11:25 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Toothpaste or Mothers aluminum polish.
I did my gauge cluster lenses with the Mothers and they turned out crystal clear!
Re: semi-chrome polish on tail light lens? [Re: GY3] #1763359
02/26/15 01:41 PM
02/26/15 01:41 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I used Mother's plastic polish for my dash lenses and my tailight lenses. Worked great! Made a huge difference.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: semi-chrome polish on tail light lens? [Re: DAYCLONA] #1763360
02/26/15 04:36 PM
02/26/15 04:36 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
When I re-did my wagon, I had one NOS tail lamp lens that I installed. I used Meguiar's on the other lens, which was moderately hazed, and unless you look at them from about 6 inches away, you can no longer tell the difference.
Earning every penny of that moderator paycheck.
DBAP
Re: semi-chrome polish on tail light lens? [Re: Adam71Charger] #1763361
02/26/15 07:09 PM
02/26/15 07:09 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Yes, but it is a single grit and may be too fine or too rough. Try it and see.
For heavy scratches use 1500 grit paper then 3000 grit paper. Then follow up with these and it'll look like new.
Cheap but good at Amazon -
web page
Re: semi-chrome polish on tail light lens? [Re: Lefty] #1763362
02/26/15 07:51 PM
02/26/15 07:51 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
web page
LEFTY NAILED IT...Ived used the number 2 scratch remover on headlights as well as lenses and even gun stocks...A local plastics company highly recommends it for all plastics...It did a great job on these 1963 Dodge lenses...They look like new..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: semi-chrome polish on tail light lens? [Re: 72N96RR] #1763363
03/04/15 06:56 PM
03/04/15 06:56 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
What about something like '69 Charger lenses that have ridges, polishing them without rounding the edges off?
Re: semi-chrome polish on tail light lens? [Re: Adam71Charger] #1763364
03/04/15 08:36 PM
03/04/15 08:36 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Get some rouge, and a buffing wheel...
Re: semi-chrome polish on tail light lens? [Re: RSNOMO] #1763365
03/04/15 08:49 PM
03/04/15 08:49 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Been using toothpaste for the last 40 years. Any of the white paste works best, not the green gels. Once did some 71 Challenger taillight lens and the things came out brighter than new. But it does take time. Also did the ones on my 69 Charger. Just keep moistening your cotton rag (old tee shirt) when it starts dragging and drying out, it will form to grooves and edges after rubbing for awhile.
Re: semi-chrome polish on tail light lens? [Re: Adam71Charger] #1763366
03/04/15 09:37 PM
03/04/15 09:37 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
On our late model stuff, we just use regular polish and get good results on taillites, headlites, marker lites, etc. I have tried some of the so-called plastic polishes and don't see any difference in the gloss.
If you really want the tailites to sparkle like new and to stay that way, spray them with catalized clear. We do that with headlites and taillites and they look great and the clear is much harder than the original plastic, so it resists new scratches and scuffs.
It is best to glass bead the surface so that the clear has a good textured surface to bite to. Sounds extreme, but works very well. We've done dozens, both older and newer.
Master, again and still
Re: Simichrome polish on tail light lens? [Re: DaveRS23] #1763367
03/05/15 03:50 PM
03/05/15 03:50 PM
dogdays Offline
dogdays  Offline
Here's their website:
http://www.simichromepolish.com/
R.
Re: Simichrome polish on tail light lens? [Re: dogdays] #1763368
03/05/15 04:22 PM
03/05/15 04:22 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I've found most all of the polishes that are good for aluminum work equally as well on plastic. Choose the polish by condition of the lens.
If its in rough shape start with a more aggressive polish...then finish with something finer. Stay away from a bench top buffer as previously suggested...
...FAFO...
Re: Simichrome polish on tail light lens? [Re: skicker] #1763369
03/05/15 05:21 PM
03/05/15 05:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've found polished and compounds for paint work equally as well on plastic too.
