Re: semi-chrome polish on tail light lens?
[Re: Adam71Charger]
#1763357
02/26/15 04:29 AM
02/26/15 04:29 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Looking for a polish to take the haze out of tail light lens, I've used semichrome on plastic trim, will it work for lenses (red and white)?
Yes, will work with various results depending how bad they are to start. Wenol will work about the same too. They both are sort of similar products.
Toothpaste will work too.
Also wet sanding from 600-800-1000-then fine rubbing compound and plastic polish will give really nice results. Depending on scratch depth you may need to go
[Re: Adam71Charger]
#1763361
02/26/15 07:09 PM
02/26/15 07:09 PM
Posts: 6,516 Santa Cruz, California
Lefty
Yes, but it is a single grit and may be too fine or too rough. Try it and see.
For heavy scratches use 1500 grit paper then 3000 grit paper. Then follow up with these and it'll look like new.
Cheap but good at Amazon -
web page
[Re: Lefty]
#1763362
02/26/15 07:51 PM
02/26/15 07:51 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
web page
LEFTY NAILED IT...Ived used the number 2 scratch remover on headlights as well as lenses and even gun stocks...A local plastics company highly recommends it for all plastics...It did a great job on these 1963 Dodge lenses...They look like new..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: Adam71Charger]
#1763366
03/04/15 09:37 PM
03/04/15 09:37 PM
Posts: 12,162 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
On our late model stuff, we just use regular polish and get good results on taillites, headlites, marker lites, etc. I have tried some of the so-called plastic polishes and don't see any difference in the gloss.
If you really want the tailites to sparkle like new and to stay that way, spray them with catalized clear. We do that with headlites and taillites and they look great and the clear is much harder than the original plastic, so it resists new scratches and scuffs.
It is best to glass bead the surface so that the clear has a good textured surface to bite to. Sounds extreme, but works very well. We've done dozens, both older and newer.
Master, again and still
Re: Simichrome polish on tail light lens?
[Re: DaveRS23]
#1763367
03/05/15 03:50 PM
03/05/15 03:50 PM
dogdays
[Re: dogdays]
#1763368
03/05/15 04:22 PM
03/05/15 04:22 PM
Posts: 5,107 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I've found most all of the polishes that are good for aluminum work equally as well on plastic. Choose the polish by condition of the lens. If its in rough shape start with a more aggressive polish...then finish with something finer. Stay away from a bench top buffer as previously suggested...
...FAFO...
[Re: skicker]
#1763369
03/05/15 05:21 PM
03/05/15 05:21 PM
autoxcuda
So Cal
I've found polished and compounds for paint work equally as well on plastic too.
