Whats the diifference between a 440 and HP 440 block #1762180
02/24/15 07:30 PM
02/24/15 07:30 PM
Toledo, Ohio
70FJ5383 Offline OP
70FJ5383  Offline OP
Toledo, Ohio
A 1969 motor for example. Is there really a different in the block? Thought the HP motors just had different rods, cam, carb and forged crank.
Re: Whats the diifference between a 440 and HP 440 block [Re: 70FJ5383] #1762181
02/24/15 08:04 PM
02/24/15 08:04 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Regardless of year the block is the same except the stamp.
HP engines have: HP Cam, windage tray, bigger oil pan, HP exhaust manifolds, and the Carter carb.
For any given year all 440s use the same pistons, rods, crank (all forged in the earlier years), intake, heads (only 68 and up, 67 uses a bigger exhaust valve in the same 915 casting).
The only exception to this rule are the 6 pack engines. After the introduction of the "6 pack rods" in 1970 its also murky as to which engines came with the "6 pack rods" but most seem to have them by the mid-late 70s.
Re: Whats the diifference between a 440 and HP 440 block [Re: 70FJ5383] #1762182
02/24/15 08:12 PM
02/24/15 08:12 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yeah, I should know this, right. A 1969 motor for example. Is there really a different in the block? Thought the HP motors just had different rods, cam, carb and forged crank.
The difference in the block is 2 stamps ... H and P.
In 69 the only thing different between the shortblock assemblies of the 350HP 440 and the 375HP is nothing.
The main differences between the 2 complete engines in 1969 are the cam, the valve springs, the carb, the distributor, windage tray and the exhaust manifolds.
Re: Whats the diifference between a 440 and HP 440 block [Re: JohnRR] #1762183
02/24/15 08:18 PM
02/24/15 08:18 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Nothing.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Whats the diifference between a 440 and HP 440 block [Re: hemi71x] #1762184
02/24/15 08:35 PM
02/24/15 08:35 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I remember reading an article many years ago by a former Chrysler engineer. He claimed that when they needed HP blocks, they would do a visual check on available blocks and pick out the ones with the least amount of core shift. These got stamped HP. Just because it did not get a stamp does not necessarily mean that it would not pass the visual check, it just meant that they quit looking at blocks when they met their quota. Sounds reasonable.
Re: Whats the diifference between a 440 and HP 440 block [Re: Lee446] #1762185
02/24/15 09:27 PM
02/24/15 09:27 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
That dude is good then. Most people don't have x-ray vision to see the core shift. I have to use a sonic gauge!
Re: Whats the diifference between a 440 and HP 440 block [Re: fastmark] #1762186
02/24/15 09:31 PM
02/24/15 09:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Clark Kent's night job.
Don't be the exception.
Re: Whats the diifference between a 440 and HP 440 block [Re: Supercuda] #1762187
02/24/15 10:28 PM
02/24/15 10:28 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
440 block - $300
440HP block - $700
difference - $400, well that and the HP stamp
Re: Whats the diifference between a 440 and HP 440 block [Re: B5 Bee] #1762188
02/24/15 10:39 PM
02/24/15 10:39 PM
Toledo, Ohio
70FJ5383 Offline OP
70FJ5383  Offline OP
Toledo, Ohio
440 block - $300
440HP block - $700
So the uninformed are paying more for the same block. Thanks for clearing that up.
Re: Whats the diifference between a 440 and HP 440 block [Re: GTX MATT] #1762189
02/24/15 10:39 PM
02/24/15 10:39 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Not that murky; all 1970 - 1975 440 HP and truck engines used the mis-named "6 pack rods".
To the OP, as the others have stated....just the stamp.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Whats the diifference between a 440 and HP 440 block [Re: DPelletier] #1762190
02/24/15 11:34 PM
02/24/15 11:34 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I've heard people find them in the regular passenger car engines too
Re: Whats the diifference between a 440 and HP 440 block [Re: GTX MATT] #1762191
02/25/15 12:46 AM
02/25/15 12:46 AM
As far as the differences look at the block casting numbers HP versus non HP have the same casting number correct As far as visual core shift, I have seen Moapr RB and Hemi blocks have very noticeable differences in the front of the block where the cam tunnel is in relation to the main tunnels, lots of other little things also
Re: Whats the diifference between a 440 and HP 440 block [Re: Cab_Burge] #1762192
02/25/15 04:19 AM
02/25/15 04:19 AM
dogdays Offline
dogdays  Offline
Exactly! It doesn't take X-ray vision to notice holes not centered in bosses, etc.
R.
Re: Whats the diifference between a 440 and HP 440 block [Re: GTX MATT] #1762193
02/25/15 02:18 PM
02/25/15 02:18 PM
DPelletier Offline
DPelletier  Offline
It's possible (and even likely) that there are exceptions to any rule; QC wasn't exactly top notch.....but I doubt there are a statistically significant number of non-HP 440's with the heavy rods and related damper.
Re: Whats the diifference between a 440 and HP 440 block [Re: DPelletier] #1762194
02/25/15 03:34 PM
02/25/15 03:34 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
1970-1 440 out of a C body would have the small rods if it was a none HP Motor. I have had plenty of these. Quality Control in 1970 at Chrysler was basically none existent. Making a decision on blocks if they become HP or HP2 or high performance motor would of been a big job. There were a lot of 440 motors cast for the 1970 build. I believe the number of 440s complete motors built was around 750,000 over its life time of the motor. That is complete motors, how many blocks for warrenty or counter sale were also built. Lot of blocks to look at to decide if they are for HP 440s or not.
As for the HP block pricing, any block can become an HP block with a set of stamps. So why pay the price for something that can be created that is only bought to trick someone that the engine might be the original motor to you car looking at the front pad.
1971 HEMI E BODY REGISTRY
Re: Whats the diifference between a 440 and HP 440 block [Re: hemicar1971] #1762195
02/25/15 05:29 PM
02/25/15 05:29 PM
dogdays Offline
dogdays  Offline
Because there is an unlimited supply of stupid or ignorant people out there, and some of them have big money burning a hole in their pockets.
ALSO,
Remember that in the Chevy world, there was a Lot of difference between a high performance engine and a regular mill. Same goes for Ford, Pontiac, Olds, etc.
Take the 396, for example. The regular engine got 2 bolt block, cast crank, oval port heads. The High Performance engine got 4 bolt block, forged crank, rectangular port heads. Or my '72 350. About the only things that were the same between the 2-barrel or regular performance 4-barrel and the LT1 were the oil pump, water pump, valve covers maybe, rocker arms and pushrods, and assorted bolts for everything except connecting rods. So when I found a disassembled LT1 for a reasonable price I drooled. Still couldn't afford it, but what a wealth of better parts.
My point is, when you come from that kind of world, the letters "HP" stamped on the block mean a lot more than they would to a Mopar savant. Even if you tell them it isn't the original block, it will probably still be worth more to them. And remember they have the big bucks burning a hole in their pocket.
R.
Re: Whats the diifference between a 440 and HP 440 block [Re: 70FJ5383] #1762196
02/25/15 05:46 PM
02/25/15 05:46 PM
Portland, Oregon
Digger73 Online rolleyes
Digger73  Online Rolleyes
Portland, Oregon
My son's friend had me help out with his 73 Plymouth. He installed a 440 where a 400 was. No big deal but, he was all tweeked out about his 440 not being an HP block. I asked him if he really wanted an HP block? Of course he was about to wet his pants at the prospect of an HP block. So, while he was watching I pulled my stamps out and stamped HP on the identification block. The look on his face was priceless. After the shock wore off he then asked the question, Is that the only difference between a non HP block and an HP block? I just smiled.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Whats the diifference between a 440 and HP 440 block [Re: dogdays] #1762197
02/25/15 05:49 PM
02/25/15 05:49 PM
DPelletier Offline
DPelletier  Offline
ALSO,
R.
...which is why I don't subscribe to the value placed on #'s motors for Mopars. Unlike most GM products, Mopars have the engine in the VIN and the difference between HP and not was negligable....these aren't Corvettes or Chevelles.
Re: Whats the diifference between a 440 and HP 440 block [Re: 70FJ5383] #1762198
02/25/15 08:38 PM
02/25/15 08:38 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
440 block - $300
440HP block - $700
unless it's the infamous HP2 block! then the price goes to $900.
Re: Whats the diifference between a 440 and HP 440 block [Re: mikemee1331] #1762199
02/25/15 08:51 PM
02/25/15 08:51 PM
JohnRR Offline
JohnRR  Offline
440 block - $300
440HP block - $700
