brass soft plugs falling out #1761358
02/23/15 02:38 PM
02/23/15 02:38 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
anyone here ever had brass soft/freeze plugs fall out. sb chevy sitting in a heated garage and 3 soft plugs feel out. why?
Re: brass soft plugs falling out [Re: mopar dave] #1761359
02/23/15 03:16 PM
02/23/15 03:16 PM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
I know the feeling I used green loctite on mine. I lost one at 7500rpm in 3rd gear!! No blown head gaskets or cracked block or heads it just fell out. Made for a pretty insane ride when the water got under my tires!
Re: brass soft plugs falling out [Re: mopartoby] #1761360
02/23/15 03:32 PM
02/23/15 03:32 PM
Mt Morris Michigan
Mt Morris Michigan
I'm sure that was not a fun ride.
Re: brass soft plugs falling out [Re: mopar dave] #1761361
02/23/15 03:35 PM
02/23/15 03:35 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
How were they installed? I have seen them installed with a socket in the bottom of plug, and it stretches the metal and it does not fit tight enough. The proper tool drives them in from the O.D. rim
Re: brass soft plugs falling out [Re: qwkmopardan] #1761362
02/23/15 03:43 PM
02/23/15 03:43 PM
Mt Morris Michigan
Mt Morris Michigan
they look like there flush with the hole surface.
Re: brass soft plugs falling out [Re: mopar dave] #1761363
02/23/15 03:47 PM
02/23/15 03:47 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
Yes, i have. Where are they made? i have found the need to mic out alot of new freeze plugs, because some are just too loose of a fit. Sometimes you just have to use the steel plugs on some motors and install with loctite.
Re: brass soft plugs falling out [Re: ditchdrift] #1761364
02/23/15 04:34 PM
02/23/15 04:34 PM
Mt Morris Michigan
Mt Morris Michigan
made in usa. I think i'm going to put the rubber expanding plugs in to replace the ones that fell out. I don't want to pull motor again.
Re: brass soft plugs falling out [Re: mopar dave] #1761365
02/23/15 04:39 PM
02/23/15 04:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Use these... Doorman
Re: brass soft plugs falling out [Re: MR_P_BODY] #1761366
02/23/15 04:41 PM
02/23/15 04:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Another shot... use Permitex on them
Re: brass soft plugs falling out [Re: MR_P_BODY] #1761367
02/23/15 04:53 PM
02/23/15 04:53 PM
Mt Morris Michigan
Mt Morris Michigan
nice, where do you get those? how much? got to run off to work now, get back later.
Re: brass soft plugs falling out [Re: mopar dave] #1761368
02/23/15 04:59 PM
02/23/15 04:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i don't care for brass plugs because they will pop out. i have some friends who had a brass plug blow out,... with the front wheels in the air. water got under one tire and the car ended up in the wall. very ugly and costly.
Re: brass soft plugs falling out [Re: lewtot184] #1761369
02/23/15 07:07 PM
02/23/15 07:07 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
As stated above , soft plugs that come out or start leaking were improperly installed. Most take the easy way and put a socket in the center and pound them in. By doing that, it pulls the sides in and reduces the wall tension. The proper way is tapping the outer cup ring till flush with the block, some sealer might help but most of it will be pushed into the block by the tight fitting soft plug. I have used brass soft plugs on 3 engines and never had a leak or have one pop out.
Re: brass soft plugs falling out [Re: mopar dave] #1761370
02/23/15 07:31 PM
02/23/15 07:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can get them at your local parts store... they
might have to order them if they dont stock them..
I dont know what size you need but they can look
that up.. I forget the price but they werent much..
I bought a whole box of them for the mopar blocks
and that was about $22 for the box if I recall...
I had a plug come out on my R block and I replaced
it with these.. never came out again
Re: brass soft plugs falling out [Re: MR_P_BODY] #1761371
02/23/15 10:38 PM
02/23/15 10:38 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
1 5/8 for small block Chevy. Bolt ins may take the same plug as the 1 41/64 that Mopar uses.
Re: brass soft plugs falling out [Re: mopar dave] #1761372
02/24/15 12:33 AM
02/24/15 12:33 AM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
I wonder if they were Pioneer brand? I recently bought a Pioneer brass kit to replace the Pioneer brass plugs in a 340 block. When I looked at the new Pioneers, they had changed them sometime. The sidewall height is only about a third of the old original ones. I returned them and got some Sealed Power ones which have the long sidewall height. Doorman also make the original height ones also.
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: brass soft plugs falling out [Re: rowin4] #1761373
02/24/15 12:35 AM
02/24/15 12:35 AM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
Good tip!
K. Schwab
Re: brass soft plugs falling out [Re: FM3AAR] #1761374
02/24/15 01:01 AM
02/24/15 01:01 AM
Mt Morris Michigan
Mt Morris Michigan
ok, must of been installed wrong. engine has about 14,000 miles and freeze plugs fall out while parked in a heated garage is just strange.
Re: brass soft plugs falling out [Re: MR_P_BODY] #1761375
02/24/15 01:02 AM
02/24/15 01:02 AM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks mike. how are those installed?
Re: brass soft plugs falling out [Re: mopar dave] #1761376
02/24/15 01:07 AM
02/24/15 01:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Put permitex around the perimeter and use 2 wrenches
and just tighten it up... once the OD touches then
tighten the small nut.. its very simple.. once you
see them you will understand
Re: brass soft plugs falling out [Re: MR_P_BODY] #1761377
02/24/15 01:09 AM
02/24/15 01:09 AM
Mt Morris Michigan
Mt Morris Michigan
ok, pretty much same way as the rubber ones.
