Re: brass soft plugs falling out
[Re: mopar dave]
#1761365
02/23/15 04:39 PM
02/23/15 04:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
made in usa. I think i'm going to put the rubber expanding plugs in to replace the ones that fell out. I don't want to pull motor again.
Use these... Doorman
[Re: lewtot184]
#1761369
02/23/15 07:07 PM
02/23/15 07:07 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
As stated above , soft plugs that come out or start leaking were improperly installed. Most take the easy way and put a socket in the center and pound them in. By doing that, it pulls the sides in and reduces the wall tension. The proper way is tapping the outer cup ring till flush with the block, some sealer might help but most of it will be pushed into the block by the tight fitting soft plug. I have used brass soft plugs on 3 engines and never had a leak or have one pop out.
[Re: mopar dave]
#1761370
02/23/15 07:31 PM
02/23/15 07:31 PM
MR_P_BODY
nice, where do you get those? how much? got to run off to work now, get back later.
You can get them at your local parts store... they might have to order them if they dont stock them.. I dont know what size you need but they can look that up.. I forget the price but they werent much.. I bought a whole box of them for the mopar blocks and that was about $22 for the box if I recall... I had a plug come out on my R block and I replaced it with these.. never came out again
[Re: MR_P_BODY]
#1761371
02/23/15 10:38 PM
02/23/15 10:38 PM
Posts: 1,849 South Bend
John Brown
South Bend
1 5/8 for small block Chevy. Bolt ins may take the same plug as the 1 41/64 that Mopar uses.
[Re: mopar dave]
#1761376
02/24/15 01:07 AM
02/24/15 01:07 AM
MR_P_BODY
ok, thanks mike. how are those installed?
Put permitex around the perimeter and use 2 wrenches and just tighten it up... once the OD touches then tighten the small nut.. its very simple.. once you see them you will understand
