Re: Deburring/polishing a block? [Re: Jonnyj00] #1760787
02/25/15 09:11 PM
02/25/15 09:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry to hijack the thread but what are you guys using to paint the lifter valley? I saw they make some expensive paint made just for that application and I don't mind spending the money if its necessary but if I can find something that works just as good for less that's always good lol.
I use Rustoleum (sp).. it holds up well.. never had
it lift off
Re: Deburring/polishing a block? [Re: MR_P_BODY] #1760788
02/25/15 09:46 PM
02/25/15 09:46 PM
SE Iowa
Jonnyj00 Offline
Jonnyj00  Offline
SE Iowa
Yes I was referring to glyptal as the expensive choice.
Mr P. when you say rustoleum are you talking about the standard red oxide primer or something else rustoleum makes?
Re: Deburring/polishing a block? [Re: Jonnyj00] #1760789
02/25/15 09:56 PM
02/25/15 09:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the black rustoleum.. its just a color
Re: Deburring/polishing a block? [Re: MR_P_BODY] #1760790
02/25/15 10:16 PM
02/25/15 10:16 PM
SE Iowa
Jonnyj00 Offline
Jonnyj00  Offline
SE Iowa
Got ya thanks
what about high temp engine enamel?
Re: Deburring/polishing a block? [Re: Jonnyj00] #1760791
02/25/15 10:22 PM
02/25/15 10:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Got ya thanks
So far I havent needed any high temp... its only
250* in the engine... it can heat soak up a bit more
