street/Strip oil pan #1760042
02/22/15 12:57 AM
02/22/15 12:57 AM
Massillon, Ohio
cudatom Online content OP
cudatom  Online Content OP
Massillon, Ohio
Looking for some input. Need a decent pan for my 400. The engine has a 4.25 stroke crank. Wont run faster than 11.0-11.50.
Its going in a 67 Belvedere II. I do want a pan w/dipstick provisions and an internal pick up.
I have narrowed it down to a Canton Racing pan part #15-950 or Milodon #30930. Just cant find any info whether the Canton pan will have an issue w/the stroke length(Summits site says stock stroke) and for the Milodon (Summit shows it has no dipstick provision). Which after looking at images appears incorrect. Which pans have you guys had good luck in a 66/67 B-body. As I have said not locked into any one pan yet. Just want one that wont leak and will work with my set up.
Ok
Re: street/Strip oil pan [Re: cudatom] #1760043
02/22/15 01:03 AM
02/22/15 01:03 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Not sure on the stroke but if you have any concerns about ground clearance look at the Milodon Road Race pan. I am on pan #3 which is the road race pan, I believe it will finally fix the problem of having to treat the oil pan as a consumable that the deep pans had.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: street/Strip oil pan [Re: cudatom] #1760044
02/22/15 03:35 AM
02/22/15 03:35 AM
Cab_Burge Online work
Cab_Burge  Online Work
I like and use the OEM type 1970/71 ST.Hemi and 440 6 pak 6 quart oil pan with the 3/8 6 pak oil pickup in any motor like that, as well as more HP and in faster cars, that I build for a 1966 to 1971 B and E body My 518 C.I. pump gas Duster ran 9.993 at 134.+ MPH on Oregon 91 octane non ethanol pump swill with the air cleaner and full exhaust on, no oiling problems at all as long as the oil level is above the add mark That motor made 727 HP on a DTS engien dyno in Klamath Falls ,OR at 4300 on pump swill with a set of Indy SR M.W. ports and a single Holley 1050 Doimnator carb. Keep it simple as long as it works well I do make my own crankshaft scrapers and the stock Mopar windage tray I make sure the oil pickup is within 1/8 from touching or partially touching the bottom of the oil pan also I'm bulding a pump gas 1966 Dodge Coronet Deluxe two door sedan right now that will have a 464 C.I. pump gas 440 RB motor in it with that exact same set up except the shorter 3.91 stroke
Re: street/Strip oil pan [Re: cudatom] #1760045
02/22/15 06:31 AM
02/22/15 06:31 AM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline
I went with the Milodon road race pan after seeing just how low the moroso 7qt pan hung down on my R/B engine.
DOn
Street/Strip 73 Barracuda
Re: street/Strip oil pan [Re: The Cuda Guy] #1760046
02/22/15 12:04 PM
02/22/15 12:04 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been using the Moroso 7 qt pan since 2006 and it has never hit anything as it has good road clearance in my 63. Ron
Re: street/Strip oil pan [Re: 383man] #1760047
02/22/15 01:16 PM
02/22/15 01:16 PM
IN
ahy Offline
ahy  Offline
IN
Ron, your car is beautiful and you are careful with it. The way I drive mine, sometimes spirited on real mid west roads, I would have been through several pans and maybe engines by now.
I run the 6 quart "hemi" pan with a skid plate on the K frame. Is a low deck with 4.15 stroke and windage tray. The stock dipstick (mounted in the block, not pan) works fine. The Hemi pan is about 1" deeper than stock and hangs a little below the K. The skid plate has saved it more than once. I think it would be a good choice for the OP or the road race pan which is more spendy.
Anything deeper than the OE 4 quart is best used with a matched skid plate IMO.
PS. My skid plate really earned its keep last fall. Driving to a track day at around 5:30 AM on a cold rainy sleety morning I "ate" a full tread of a super single truck tire. Standing tall like a big doughnut. Front valence, lower rad support, radiator, fan/clutch all toast. The skid plate pushed the tire under the pan and it was fine save for some rubber stains.
Re: street/Strip oil pan [Re: ahy] #1760048
02/22/15 03:46 PM
02/22/15 03:46 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run a 440-source pan. It hangs low, but its never been an issue because I usually watch where I'm going and I'm fairly careful with my car. It's got a couple of dings here & there, I have assumed from rocks bouncing along the roadway, but never have I had an issue with destroying it.
If you drive it like you stole it, you may want to go to a road-race style pan.
Re: street/Strip oil pan [Re: StealthWedge67] #1760049
02/22/15 03:52 PM
02/22/15 03:52 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
me too, I have considered going to the six quart but not sure I feel like changing a pan in the car.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: street/Strip oil pan [Re: gregsrt] #1760050
02/22/15 04:04 PM
02/22/15 04:04 PM
Puyallup, WA
Puyallup, WA
I like the fact that I can load 7 quarts plus an additive, and the dipstick reads right at the bottom "add" mark. Lots of oil, and away from the tray.
Re: street/Strip oil pan [Re: Cab_Burge] #1760051
02/22/15 04:09 PM
02/22/15 04:09 PM
Massillon, Ohio
Massillon, Ohio
Thanks for the info Cab. I saw that pan. Just wasn't sure how it would fit on a 67. Mancini had a hemi pan for the earlier body styles but it was similarly priced to the 2 pans I mentioned. I do like keeping things simple.
Now that I know someone that has 1st hand knowledge of fitment I may go that direction. Pan and pick up is $169 so that would free up money for other small parts that always creep up on us. This is the car. If I can dig my trailer out of the snow I can pick it up from the body shop Saturday. [image]http://[/image]
Ok
Re: street/Strip oil pan [Re: 383man] #1760052
02/22/15 04:15 PM
02/22/15 04:15 PM
Massillon, Ohio
Massillon, Ohio
Love your car 383man. My dad raced one in stock class in Ohio at Magnolia drag strip in the early to mid 60's.
Ok
Re: street/Strip oil pan [Re: cudatom] #1760053
02/22/15 06:43 PM
02/22/15 06:43 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Cool Car!
The pan fits my 67.
Re: street/Strip oil pan [Re: cudatom] #1760054
02/22/15 10:58 PM
02/22/15 10:58 PM
You have a PM
Re: street/Strip oil pan [Re: Cab_Burge] #1760055
02/23/15 09:27 AM
02/23/15 09:27 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Wow ... that looks great.
What hood scoop are you going to use?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: street/Strip oil pan [Re: 6bblFLASH] #1760056
02/23/15 11:41 AM
02/23/15 11:41 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I have the 30930 in my '67. Its a nice pan and fits well. I actually got it in the car with the scatter shield on the back of the engine, that made it a pain the in the you know what though.
It is not that low profile though, sticks down almost as much as some of the cheap deep sump big pans. Although every bit counts. I'd say it hangs around 2 inches below the K frame.
Re: street/Strip oil pan [Re: David_in_St_Croi] #1760057
02/23/15 02:42 PM
02/23/15 02:42 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Every time I get under my car...the pan has a new dent in it. Ive dented 3 pans so far. One of them starting leaking at a spot weld after I hit something. My dented pans have nothing to do with driving style....
My car sits lower in the front that most on here, to get as much travel as possible..and my torsion bars wont hold the fat thing up any higher...
The road race pan looks pimp. 2 more inches of ground clearance is a must for me...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: street/Strip oil pan [Re: Von] #1760058
02/23/15 06:49 PM
02/23/15 06:49 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
another for the Milodon road race pan .
since fitting never even close to hitting anything
sits right at the k-member height , minimal below
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: street/Strip oil pan [Re: tex013] #1760059
02/23/15 07:02 PM
02/23/15 07:02 PM
AndyF Offline
AndyF  Offline
I agree, the road race pan is the best setup for a street car. But it is expensive and the extra size does make it more difficult pulling/installing the engine unless you cut out the K frame. We cut the K frame on my B-body car so now it is much easier to get a big pan in and out.
Re: street/Strip oil pan [Re: tex013] #1760060
02/23/15 08:25 PM
02/23/15 08:25 PM
Massillon, Ohio
Massillon, Ohio
Yeah the road race pan is nice. Unfortunately it is way out of my budget. Too many little items needed to finish the car.
With the curbs and roads around here if the other pans I listed sit 2" below the k frame I'll need to keep several on hand. After talking w/Cab I will probably buy the Summit Racing version of the 70-71 hemi pan.
Dennis this is the scoop that is going on the car.
Ok
Re: street/Strip oil pan [Re: cudatom] #1760061
02/24/15 12:18 AM
02/24/15 12:18 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
/ Really looks good Tom.
