Help me Diagnose Problem w/ my 6-Way Seat #1758872
02/20/15 12:13 AM
02/20/15 12:13 AM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
On my 70 Coronet R/T, the 6-Way drivers seat will flop back into the reclined position whenever leaning back in the seat, or pushing the pedal on the right...
I used to keep an old starter wedged under the seat, but my wife said that was horribly ghetto...to which I told her that's "Mopar style"...she didn't find the humor.
Anyhow, does anyone see anything missing/wrong?
Here's the brackets:
https://www.amazon.com/clouddrive/share/D1DO07NtiRHUSdPX-7elH09Kca_tH0WDOW2xWys_OD0
Here's a closeup of the inside of the left bracket:
https://www.amazon.com/clouddrive/share/pkdskNBlZ0McRc3GOHBlw6Y1-WyNnhMGmB8glsKg8kQ
and here's the inside of the right bracket:
https://www.amazon.com/clouddrive/share/fWqOwLop4QyfX8t3yfY10XxzMq0FogtNKIlhvuN3YQg
The only thing I can see different/missing is the horseshoe shaped spring on the reclining function on the right side. If that's the culprit, how would I go about finding that only spring?
(and no it's not under the carpet or seat, I already looked)
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Help me Diagnose Problem w/ my 6-Way Seat [Re: shanker] #1758873
02/20/15 01:45 AM
02/20/15 01:45 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If its flopping back, something is stripped or broken. I'd start by looking a broken spot welds or stripped teeth or gears.
After it flops back, will it power back up, or do you have to pull it back? They didn't make the stuff under the seat any more heavy duty then they figured they needed to, to get past warranty.
If a missing spring was the cause of your issue, I doubt replacing the spring is going to fix the problem anymore. What ever has been sliding past the spring latch is probably missing teeth by now. Gene
Re: Help me Diagnose Problem w/ my 6-Way Seat [Re: poorboy] #1758874
02/20/15 11:22 AM
02/20/15 11:22 AM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
no stripped/elongated/excessively worn gears...
I know that the pics are not super huge high resolution like they should be, but this is moparts and I didn't want to get chastised for my pictures not showing up on a 14" monitor.
Re: Help me Diagnose Problem w/ my 6-Way Seat [Re: shanker] #1758875
02/20/15 12:07 PM
02/20/15 12:07 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The spring obviously serves a purpose or they wiuldn't have wasted the two cents it cost! You could probably make one with some piano wire from a hobby shop. Just make sure you "cold" bend it or it will lose any tension. See it that helps then move to the next step.
Re: Help me Diagnose Problem w/ my 6-Way Seat [Re: Stanton] #1758876
02/21/15 02:02 AM
02/21/15 02:02 AM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I just finished going thru the seat tracks and it is for sure this spring that I need..
I checked out PG Classics reproduction 68-69 B-Body and 70-74 E-Body 6 way seat tracks and it is on theirs..
what's the chances of contacting them and buying a spring directly?
I'm doubtfull that if anyone online has a set of 6-way seat tracks that are so rusty their unusable that the spring will be any good anyhow..
Re: Help me Diagnose Problem w/ my 6-Way Seat [Re: shanker] #1758877
02/21/15 06:19 PM
02/21/15 06:19 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I tried this to see if it'd be a temp solution until I either find a spring, or make one somehow...
did not work...
I only had 1 spring in my tool box drawer, if I had one on the opposite lug, I think it had worked...oh well, only takes a few minutes to pull the seat out and no jack is required.
Re: Help me Diagnose Problem w/ my 6-Way Seat [Re: shanker] #1758878
02/21/15 08:48 PM
02/21/15 08:48 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I'd call http://www.wildcatmopars.com/ and see if they can help. Other than that, the spring "kinda" looks like a torsion bar clip, but I don't have one handy to measure.
Re: Help me Diagnose Problem w/ my 6-Way Seat [Re: shanker] #2338832
07/18/17 01:37 AM
07/18/17 01:37 AM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I'm bumping this thread because I FINALLY found the correct spring that I'm missing.
I found it on ebay...it cost me 29.99 shipped which is CRAZY for a spring IMHO, but if you don't have it, and need it, and in 2 years this is the only one I've come across, then I guess I gotta pay to play.
http://www.ebay.com/itm/Mopar-Six-Way-Seat-Spring-1969-B-Body-1970-E-Body-1971-E-Body-/232376290995?hash=item361ab4ceb3:g:~YkAAOSwjRpZRXWm
Re: Help me Diagnose Problem w/ my 6-Way Seat [Re: shanker] #2338837
07/18/17 01:43 AM
07/18/17 01:43 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
There were some for sale on here I saw in the last few weeks.
It looks nothing like a torsion bar clip.
Re: Help me Diagnose Problem w/ my 6-Way Seat [Re: shanker] #2338838
07/18/17 01:46 AM
07/18/17 01:46 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
This
Re: Help me Diagnose Problem w/ my 6-Way Seat [Re: shanker] #2340054
07/19/17 11:17 PM
07/19/17 11:17 PM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
thats the same member selling them on eBay...
Re: Help me Diagnose Problem w/ my 6-Way Seat [Re: shanker] #2671001
06/28/19 07:49 AM
06/28/19 07:49 AM
KS
b5cuda69 Offline
b5cuda69  Offline
KS
Hello everyone, I'm late to the party but need one of those springs to finish my six-way seat frame. Anyone got a lead on this? Thanks,
Bill
