Re: 1969 B Body drum to disk brakes
[Re: Andrewh]
#1758469
02/19/15 06:09 PM
02/19/15 06:09 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
If you are really stuck on keeping your drum spindles and booster, this is the only kit I know of off hand that will let you do that. http://ecihotrodbrakes.com/dodge_plymouth_discbrake_conversions.htmlIt uses GM calipers that have a piston size compatible with the pressure a drum booster can generate. Is there a reason you don't want to go with disc spindles and booster? A-body spindles I would assume are getting scarce but there should be late B, R, and FMJ spindles that are easier to source. Kevin
[Re: AndyF]
#1758471
02/19/15 07:14 PM
02/19/15 07:14 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
i used SSBC on the front of my 68 Satellite , used the drum spindle and booster . It was quite alright .Still going strong since 2007 though I have now removed the booster . I have also used Wilwood on a 69 Roadrunner , drum spindle, and bought a reman/repro dual mopar booster to go with it .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
