Is this Decal Original?? #1758408
02/19/15 11:29 AM
02/19/15 11:29 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Is this an original decal?It is on the inner fender of a 70 Duster 340 4 speed w/CA emissions.Thanks for any info
Re: Is this Decal Original?? [Re: 44D6PAKCUDA] #1758409
02/19/15 11:35 AM
02/19/15 11:35 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm not 100% sure on that example but I believe that was an add on decal that came with over the counter NOX kits, the kits were typically added to California cars in the 70's when the cars were smog tested for licensing, etc.
Re: Is this Decal Original?? [Re: ScottSmith_Harms] #1758410
02/19/15 11:41 AM
02/19/15 11:41 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Yes add on emmisions equiptment decal. See them all the time.
In addition, many times there will be a yellow lettered sticker on the dash saying there is equiptment added. So if you see a approx 1" x 1/2" mix-matched faded or material removed section on your dash face on one of those cars, good chance it was from that sticker.
Also there is an "exempt" sticker (approx 1 1/2" x 1") in the bottom corner of the windsheild you commnonly see on early 70's CA cars.
Re: Is this Decal Original?? [Re: autoxcuda] #1758411
02/19/15 12:04 PM
02/19/15 12:04 PM
Thanks for the info men.
Re: Is this Decal Original?? [Re: 44D6PAKCUDA] #1758412
02/19/15 03:36 PM
02/19/15 03:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
my first car had that "stuff" added, it's probably still sitting in a box in Ohio.
Re: Is this Decal Original?? [Re: autoxcuda] #1758413
02/19/15 03:59 PM
02/19/15 03:59 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It's a NOX decal that came in a kit to reduced the vacuum advance.
You were EXEMPT from having to install the kit if you you had multiple carburetors or cold air induction.
Re: Is this Decal Original?? [Re: Morty426] #1758414
02/19/15 04:19 PM
02/19/15 04:19 PM
So Cal
So Cal
My parents '70 olds vista cruiser 350 4bbl has an exempt sticker on the window. It does not have multiple carbs or fresh air. It never had that nox equiptment on it.
Where there other reasons or certain years that gave you exempt status?
Just pointing out exempt sticker is another emmission related sticker you can find on CA cars of that era. Yes, exempt sticker gets you out Nox equiptment.
Re: Is this Decal Original?? [Re: autoxcuda] #1758415
02/19/15 11:54 PM
02/19/15 11:54 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Those two reasons were the only ones I remembered from the list that CARB had in the NOX manual. I don't know why a Vista Cruiser would be exempt.
