Re: STAGE 6 HEADS
[Re: MIKES_DUSTER]
#1757662
02/18/15 02:12 AM
02/18/15 02:12 AM
Posts: 742 Oak Harbor, WA
Wicked49670dart
Oak Harbor, WA
I have no flow # on mine. I have gone 9.76@135 with a 1.34 60 ft in my Dart. These heads are 2.14/1.81 that have been ported, had a lot of work in spring pockets and push rod area. Matt
Re: STAGE 6 HEADS
[Re: hemi-itis]
#1757664
02/18/15 10:11 AM
02/18/15 10:11 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
I have a set on my shelf that went 4.86 @ 140, intake flow numbers were around 350, can't remember the exhaust. They have been ported twice, once by Muscle Motors when I bought them new and then a second time by a local Chevy guy who thought he could make them flow a little better, he's the one who gave me the flow numbers...that I have since lost. My combo was a low deck 500" striker, stock block, solid roller, injected meth in a 235" 4 link dragster. I have no complaints with them, won lots of money with them and never had one single issue. Yes, I've read all of the horror stories....
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
Re: STAGE 6 HEADS
[Re: RapidusMaximus]
#1757665
02/18/15 01:17 PM
02/18/15 01:17 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
I know a little...These are the Chapman VI's (Zeus Castings) that go 381 peak but 335 @ only .500 and 361 @ .600.
Re: STAGE 6 HEADS
[Re: J_BODY]
#1757669
02/19/15 12:49 PM
02/19/15 12:49 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I have raised port stage VI but they are the standard port, not max wedge. If I remember right they max out at around 330 cfm. My car weighs just under 3800 lbs and runs 10.50's - 10.60's. Low rpm 500 c.i. stroker.
67' charger 499 RB
10.57 at 127
Re: STAGE 6 HEADS
[Re: MIKES_DUSTER]
#1757670
02/19/15 05:43 PM
02/19/15 05:43 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Anyone still using them???? What kind of flow numbers you getting out of them???? Are they comparable to a INDY -1 or EDDYS????
Outside of the 3 Chapman versions, they would be comparable to an ebrock , but only after mucho porting ...
