STAGE 6 HEADS #1757661
02/18/15 12:55 AM
02/18/15 12:55 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Anyone still using them???? What kind of flow numbers you getting out of them???? Are they comparable to a INDY -1 or EDDYS????
Re: STAGE 6 HEADS [Re: MIKES_DUSTER] #1757662
02/18/15 02:12 AM
02/18/15 02:12 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
I have no flow # on mine. I have gone 9.76@135 with a 1.34 60 ft in my Dart. These heads are 2.14/1.81 that have been ported, had a lot of work in spring pockets and push rod area. Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: STAGE 6 HEADS [Re: Wicked49670dart] #1757663
02/18/15 02:45 AM
02/18/15 02:45 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: STAGE 6 HEADS [Re: hemi-itis] #1757664
02/18/15 10:11 AM
02/18/15 10:11 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
I have a set on my shelf that went 4.86 @ 140, intake flow numbers were around 350, can't remember the exhaust. They have been ported twice, once by Muscle Motors when I bought them new and then a second time by a local Chevy guy who thought he could make them flow a little better, he's the one who gave me the flow numbers...that I have since lost. My combo was a low deck 500" striker, stock block, solid roller, injected meth in a 235" 4 link dragster. I have no complaints with them, won lots of money with them and never had one single issue. Yes, I've read all of the horror stories....
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: STAGE 6 HEADS [Re: RapidusMaximus] #1757665
02/18/15 01:17 PM
02/18/15 01:17 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I know a little...These are the Chapman VI's (Zeus Castings) that go 381 peak but 335 @ only .500 and 361 @ .600.
WIZE
In Car:
Re: STAGE 6 HEADS [Re: Streetwize] #1757666
02/18/15 07:07 PM
02/18/15 07:07 PM
Earth
Rob C Offline
Rob C  Offline
Earth
That ought to work well with a long duration solid roller... LOL
Re: STAGE 6 HEADS [Re: MIKES_DUSTER] #1757667
02/18/15 07:10 PM
02/18/15 07:10 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I'm "Stage VI'd" out... let other people fill in the details on them.
Re: STAGE 6 HEADS [Re: BradH] #1757668
02/18/15 11:36 PM
02/18/15 11:36 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
whole thread dedicated to them in the archives.....
Re: STAGE 6 HEADS [Re: J_BODY] #1757669
02/19/15 12:49 PM
02/19/15 12:49 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have raised port stage VI but they are the standard port, not max wedge. If I remember right they max out at around 330 cfm. My car weighs just under 3800 lbs and runs 10.50's - 10.60's. Low rpm 500 c.i. stroker.
67' charger 499 RB 10.57 at 127
Re: STAGE 6 HEADS [Re: MIKES_DUSTER] #1757670
02/19/15 05:43 PM
02/19/15 05:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Outside of the 3 Chapman versions, they would be comparable to an ebrock , but only after mucho porting ...
Re: STAGE 6 HEADS [Re: JohnRR] #1757671
02/22/15 04:38 AM
02/22/15 04:38 AM
Thanks for the info guy's and ill try to find the post about them in the archives.
Re: STAGE 6 HEADS [Re: MIKES_DUSTER] #1757672
02/22/15 09:58 AM
02/22/15 09:58 AM
OH.
7074cuda Offline
7074cuda  Offline
OH.
I have them on my car head work by compu-flow if I remember right Nick said they flowed 310 at .600 standard port head.I run a 451 and weigh 2950 car ran best of 10.09 131mph
Re: STAGE 6 HEADS [Re: 7074cuda] #1757673
02/22/15 01:01 PM
02/22/15 01:01 PM
s.e. michigan
top8x7b Offline
top8x7b  Offline
s.e. michigan
No flow numbers as I ported them myself with templates early casting standard ports 9.40s at 142 2900lb ,solid cam 950 carb 496ci I think the key is not over cam or carb
