Page 1 of 7 1 2 3 4 5 6 7
Bang for Buck 440 Motor Mods Stockish 67 #1756854
02/17/15 08:25 PM
02/17/15 08:25 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
I am looking for a little more juice out of my motor. It is a relatively stock build.
Recent .030 rebuild (piston kit unknown). Told builder to keep near original specs of compression
Comp CamsXE262H-10
915 heads stock rebuild
Stock intake and exhaust manifolds with 2.5" duals, x pipe
727 with shift kit Converter unknown
3.23 suregrip
Eddy 750 vacuum
Mopar electronic ignition w/ chrome box and FBO recurve
14 degrees BTDC at idle, all in at 2500rpm 36 degrees
20" vacuum at idle
I want the best bang for buck to get some more pop as it has no throw you in the seat feel. Will only spin the 255 Coker redlines if turn wheel and stops pulling before 5 grand.
I want to keep the stock look, including air cleaner, and that is why I removed the Eddy Performer intake. I have the stock 4327s Carter to send to Scott for rebuild if that would help any.
Don't want to break the bank but if I need better heads and a carb I will do it. Dont want headers.. Any thoughts?
My plan was to throw on the Carter, put in 3.55s, and maybe better heads..Not sure which..
Thanks, Pete
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: p d'ro] #1756855
02/17/15 08:31 PM
02/17/15 08:31 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Unfortunately there really is no bang for the buck if you want to keep it stock looking (other than gear). Headers are the number 1 bang for buck on a 440, followed by a cam, then intake manifold.
Stealth heads, or port your heads, 800 AVS, maybe a little more cam, but you don't want to go crazy with exhaust manifolds. Lots of people like the 528 Purpleshaft for exhaust manifolds as AndyF had good luck with it. I can't speak from my own experience though. Or you need to stroke it.
More gear always helps too
It should still smoke those redlines IMO. Are you sure your timing mark is accurate? Have you verified it? Do you know what the comrpession ratio is? Exhaust manifold heat flap stuck?
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: p d'ro] #1756856
02/17/15 08:35 PM
02/17/15 08:35 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Comp CamsXE262H-10
3.23 suregrip
Eddy 750 vacuum
20" vacuum at idle
Thanks, Pete
I would find out what converter you're running. might be too high a stall for your build. wouldn't start throwing any money anywhere until I knew that.
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: mikemee1331] #1756857
02/17/15 08:58 PM
02/17/15 08:58 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Comp CamsXE262H-10
3.23 suregrip
Eddy 750 vacuum
20" vacuum at idle
Thanks, Pete
You are right. I put a call into the guy that put my car back together, but I think the stall was not replaced so he may not know..
If I am at 2500rpms in 1 and punch it I feel no more or even less than my 2007 Avalanche. The higher the rpms get, the weaker it feels. Runs well, just pretty anemic..
No heat riser on the manifolds. Choke is operating well also. I have an A/F meter I can wire into a bung the prior owner welded in. Maybe leaning out at higher RPMs. I would be hapy to spring for some good heads if that would do it..
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: mikemee1331] #1756858
02/17/15 09:05 PM
02/17/15 09:05 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Ok I think that 750 is to big for near stock 440.
I would try a 650 holley or the thermo quad.
also something does not sound right.
I had a 383 stock with Edelbrock performer cam, performer low rise intake and carb performer 600.
pertronic ignition conversion worn out distributor in 69 charger with stock 727 trans and magnum manifolds with 906 heads and the car would smoke the tires no problem.
the 440 should have more power than that! also it should pull to 5 grand if that is the cam you have.
sounds like to me you have real weak valve springs if its not pulling to 5 grand.
do you trust the engine builder?
did you get what you paid for?
1969 Dodge Charger 1969 Dodge Superbee
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: cjs69mope] #1756859
02/17/15 09:16 PM
02/17/15 09:16 PM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
I am now suspicious of build. I referred a friend to the builder who is respected but apparently had one of his techs do his 383 and installed the wrong piston set, resulting in low compression dog. Mine doesn't have same symptoms as his and would smoke the old dried out tires before I got new ones. Also, if I stand on the brake pedal and load it I am sure I can break it loose. As I said, if I give it a little turn of wheel and punch it it goes sideways and holds it pretty well. These cars ran 16.00s when new so I think I got what I paid for, a mild rebuild.
I ran it close to 5 grand once and got a serious knock that went away after shut down. Never came back?? I have discussed it on previous threads and am a little nervous to tach it back up..
I think I will rebuild the Carter and see if that works better.
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: p d'ro] #1756860
02/17/15 10:28 PM
02/17/15 10:28 PM
You may, like a lot of other Mopar car owners, have a fuel delivery problem If you have the stock carb,. off of a 440 it is not to big Trust me on that I would go ahead and put the wideband sytem on the car and use it, it will tell you right away about the fuel supply system, if it starts to go lean at the higher RPM, especially in high gear , it is runing out of fuel Been there done that with all good parts There are a lot of gremlins that can affect fuek delivery, a lot of them Let us know waht you find out
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: p d'ro] #1756861
02/17/15 11:31 PM
02/17/15 11:31 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
a little hard to help when we don't know the actual performance of the car. It might be exactly where it should be and your expectations are too high, or the thing is a total turd, we just can't tell.
My experience is when a guy does not know specifics like pistons and compression ratio, it is usually not good, i.e. very low. You should do a cylinder pressure test. Also, it would be helpful to know the cam.
There could be several reasons that it is under performing:
1) like Cab said, fuel delivery. It can rob power like no other, and unless you test it, you won't know.
2) Plugged or internal failure of muffler. This has happened to me twice. That is an instant loss of 30 + hp, but every thing seems fine.
3) Low compression.
4) Poor heads.
5) Poor tune
The factory intake is the biggest bottle neck on an already good running 440. It is done at 5000 and getting the motor to go past 5200 is a challenge.
A good set of 915s with some porting, good cam, decent compression ratio and a good tune will result is a car that runs very well, even with factory intake and the 4327 carb.
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: p d'ro] #1756862
02/17/15 11:48 PM
02/17/15 11:48 PM
(as said) what converter/cranking compression. HP or lowpo ex manifolds? total vehicle weight? I'd want 3.55's or 3.91's. how tall are those tires? non restrictive air cleaner?. with 20" of vac you do have a healthy long block. You might bring the curve in faster (lighter springs) & bottom line-no pinging allowed.
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: RapidRobert] #1756863
02/18/15 12:04 AM
02/18/15 12:04 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Everyone's pointed out the obvious things to check, but a 440, even a mild one, should roast a set of 255's, even with 3.23's. I had a 9:1 440 in a 78 short box that would rev to 6K no sweat, all stock except for headers and a crane 282/.450" cam.
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: Cab_Burge] #1756864
02/18/15 12:22 AM
02/18/15 12:22 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I don't think it is running out of fuel. If it was bad enough that it won't pull in first then it would be completely gasping in second and never make Drive.
Did they cut the heads when they rebuilt it? If so, how much? Adjustable rockers? If it still has stock rockers and the heads are cut a bunch it could be pumping up the lifters and floating the valves slightly. While we are on the subject of valve train, was the cam degreed?
What does it have for compression pressure?
Also I would pull the pan and see how far off the bottom of the pan the pickup is. They don't rattle for no reason.
Kevin
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: p d'ro] #1756865
02/18/15 12:43 AM
02/18/15 12:43 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
These cars ran 14.0-14.8 stock, through huge reverse flow mufflers with 2.25 inch tail pipes. One that ran 16.0 would be a serious dog.
Try the A/F meter. I don't want to condemn the 750 Eddy, but there are noted problems and they require more attention than most. You should see around 13:1 or richer at WOT. As noted a few times it shouldn't have a problem spinning those tires. There may be alot left desired in the tune, but I'd question the build too. Maybe a low compression engine, which should still spin the tires. If your Avalanche is faster there is an issue.
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: GTX MATT] #1756866
02/18/15 01:10 AM
02/18/15 01:10 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
My personal bolt on favorites for a street car with 3.23's's:
Holley 750 vacuum secondary (never had luck with Carters or Edelbrocks performing the same.)
Holley Street Dominator painted orange to disguise it somewhat.
Hedman 78030 headers.
2800 stall convertor
.528 MP cam. Very slight lope, excellent torque, great rpm! Love that cam! Second choice would be .484 hydraulic.
Stealth heads if funds allow.
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: GTX MATT] #1756867
02/18/15 01:50 AM
02/18/15 01:50 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
THe 440 RT was a 15 second car and the Hemi was a mid 14 second car stock.
http://www.motortrend.com/roadtests/sedans/112_6706_dodge_hemi/photo_04.html
I have not dialed in the Eddy. Straight out of the box except float and idle circuit tune for max vacuum.
I have a bung on each side. Do I have to do a separate run for each side??
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: Twostick] #1756868
02/18/15 01:55 AM
02/18/15 01:55 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Starts, shifts and drives well. Even grabs second every now and again. Less than 500 miles on build. Just no seat in pants pull at all. Much weaker in second..
Did they cut the heads when they rebuilt it? If so, how much? Unknown..
Adjustable rockers? Stock Rockers
I doubt the cam was degreed. I will try to find out.
Unknown
I don;t know what happened. I thought the motor was gone. It has a windage tray. Straight line accel and about 4700 loud knocking. Limped home. Shut down. Restart later. No noise??
Kevin
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: RapidRobert] #1756869
02/18/15 01:57 AM
02/18/15 01:57 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
HP exhaust manifolds
255/630/15 Diamondback Redlines
Stock dual snorkel air cleaner with paper filter
1967 COronet RT Convertible
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: Cab_Burge] #1756870
02/18/15 01:58 AM
02/18/15 01:58 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
Will do. I have read alot of your posts on 440 issues and will try to get this right..
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: BSB67] #1756871
02/18/15 02:03 AM
02/18/15 02:03 AM
MD
p d'ro Offline OP
p d'ro  Offline OP
MD
3) Low compression.
4) Poor heads.
5) Poor tune
I have never raced the car but have driven a mid 14 second car and this is not close. I honestly think my Avalanche would give it a good run. Maybe 16s.
Mufflers new and good exhaust system.
Would I pull 20" vacuum with such low compression?
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: p d'ro] #1756872
02/18/15 02:08 AM
02/18/15 02:08 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Something is very wrong if flooring off the line won't roast the tires unless you're turning. Thats 318 level performance.
Re: Bang for Buck 440 Motor Mods Stockish 67 [Re: p d'ro] #1756873
02/18/15 02:18 AM
02/18/15 02:18 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I see a two runs of 15.4 and 14.7 for the RT and the car had the Cleaner Air Package Lots of these cars ran well into the 14s. Don't settle for less!
