Re: Flow Numbers for Stock Small Block Heads
[Re: hemid68]
#1756576
02/17/15 03:02 PM
02/17/15 03:02 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
Shady Dell Speed Shop has flow numbers on their website. Here is a link to their website which shows the flow numbers for a J-head: http://www.shadydellspeedshop.com/jhead.htmYou can find other flow numbers for other heads on their site as well.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: BlueDart]
#1756580
02/18/15 05:37 AM
02/18/15 05:37 AM
Posts: 170 renton , washington
perfmachst
renton , washington
That's about what I flowed a virgin x head at if I remember they quit @.450
I've flowed many stock small block heads, all drop off above .475 lift. my bench flows at 25 " test pressure. this is mopar, chev and ford heads. higher test pressure gives higher flow numbers,
[Re: hemid68]
#1756582
02/19/15 10:54 AM
02/19/15 10:54 AM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
Thanks to all of you guys that replied. It was nice to know that everything seems to be on the up and up. The heads are going on a "stocker" style engine, so I can't do any porting, but it is good just to know where they're at. The information was greatly appreciated! Thanks again, Dan
You are right about that, no porting allowed but make sure the valve job goes all the way to the intake plenum.
[Re: hemid68]
#1756589
03/01/15 02:31 AM
03/01/15 02:31 AM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Here are my numbers, a result of DYI home porting job using the MP SwirlHead porting templates:
596 castings, I had the machine shop go over them, they put in new Manley severe duty valves, 2.02/1.60, 11/32 stem, new bronze guides, and a standard 3 angle valve job. I ported them using the MP porting templates, here are the flow numbers (flowed on SF-600 @ 28" water):
LIFT I E
0.100 67 57 0.150 99 79 0.200 130 104 0.250 162 125 0.300 189 140 0.350 215 152 0.400 235 160 0.450 253 167 0.500 262 172 0.550 261 175 0.600 248 177
