572-13s
#175636
12/26/08 08:57 PM
12/26/08 08:57 PM
Posts: 1,200 UK
602heavy
UK
Using 1/2" head studs , anyone know the torque specs with 30 wt oil? (not arp studs)
These roller lifters have an oil way into the pushrod cup , but the pushrods have no provision for oiling the adjusters , were these roller lifters meant for pushrod oiling? , the lifter gallery has'nt been sleeved or restricted. (mega block)
What's the lash setting cold , the cam card calls for .020 intake/.022 ex (hot)
TIA.
Re: 572-13s
[Re: 602heavy]
#175637
12/26/08 10:10 PM
12/26/08 10:10 PM
I would add .005 to lash, warm it up to 180... Re-torque and re-lash...
Re: 572-13s
#175638
12/27/08 08:53 AM
12/27/08 08:53 AM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
Here is the torque specs from arp for thier bolts and studs.
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: 572-13s
[Re: Mopar_racer_99]
#175641
12/27/08 10:07 AM
12/27/08 10:07 AM
Posts: 2,924 A shed in England
Tig
A shed in England
On our old Iron Megablock we used 70 ft/lb with 572-13 heads and 1/2 inch/20 studs. We've used the same heads, hardware and torque setting on our KB block but we keep going thru head gaskets, always in the same place. Maybe we need to increase the torque setting? Sorry to hijack the thread.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: 572-13s
[Re: 602heavy]
#175642
12/27/08 11:30 AM
12/27/08 11:30 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
That same 1/2" stud is only 90# with ARP paste, so that shows you how much more friction the oil creates. Remember, torque values are measuring a pre-determined friction, so the more friction, the higher torque value is needed to accomplish the same result. Usually on an aluminum head you reduce the torque value by approximately 5%, or in this case, 5# to make up for the expansion of the cylinder head under load, heat.
RIP Monte Smith
Re: 572-13s
[Re: Tig]
#175643
12/27/08 11:31 AM
12/27/08 11:31 AM
CompWedgeEngines
Syracuse,NY
TIG, that is not enough torque.
RIP Monte Smith
Re: 572-13s
[Re: rtstreet]
#175647
12/27/08 06:09 PM
12/27/08 06:09 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
my alum. block and 440-1, set -.008 and recheck when hot, on super cold days lash would go to almost nothing.
Most aluminum head manufactures recommend 70 lbs ft with moly lube.An all aluminum engine will expand .015 to .018 so we usually set cold setting at 010 less on the intakes and .012 less on the exhaust.We never set them any tighter than .005.cold.Cold setting should only be used for initial start up then the valves should be set at hot run temperture.Always make sure you have plenty of piston to valve clearence.
Re: 572-13s
[Re: B G Racing]
#175648
12/27/08 08:06 PM
12/27/08 08:06 PM
Posts: 1,200 UK
602heavy
UK
Thanks all ,
Cam card calls for .020 intake/.022 ex hot , so i set lash @ .025 intake/.027 ex cold?
Will torque head studs to 90lb/ft with 30wt oil?
Thanks again.
EDIT Oops , should of read .015 intake/.017 ex setting cold.
