Crane 1.5 ductile rockers #1755452
02/15/15 11:16 PM
02/15/15 11:16 PM
Canada
WO23Coronet Offline OP
Canada
I've got some Crane ductile rockers for a BB here that have galling in the bores, so I was going to bore them out and install bronze bushings (I've got a mini mill and lathe), does anyone have blueprint specs for them? The pads look good so I won't have to get them ground but the bores definitely need to be done. Looking for mainly the bore to shaft dimensions (clearance), but any would be appreciated. Also what kind of bushings would you go with? Initially I thought oil lite's, but they're probably not needed as its pressure fed. I was going to bore them out .060" ish, bush them, then ream/hone them to size (I know bronze it's tricky to ream)
Re: Crane 1.5 ductile rockers [Re: WO23Coronet] #1755453
02/15/15 11:30 PM
02/15/15 11:30 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
When I bought a SB motor it came equipped with bushed Crane rockers. The shafts were also ground down to fit the new bushed rockers.
Re: Crane 1.5 ductile rockers [Re: WO23Coronet] #1755454
02/15/15 11:30 PM
02/15/15 11:30 PM
Washington
madscientist Offline
Washington
Unless you have all the tooling, are very good with dial indicators and have a bunch of experience, I would send them to Rocker Arm Specialties in California.
If you have the tooling and feel comforatable making fixtures and things, go for it.
Re: Crane 1.5 ductile rockers [Re: WO23Coronet] #1755455
02/15/15 11:32 PM
02/15/15 11:32 PM
USA
B3RE Offline
B3RE  Offline
USA
I'm not so sure I'd want to bore them out for a bushing. They don't have a lot of extra material to begin with, and I'd be afraid of weakening them too much. You may want to consider honing them to smooth the galling and get about .005"+ clearance on the shaft. Then use them on a motor with full time oiling to the shafts, preferably not from the cam bearing oil feeds.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Crane 1.5 ductile rockers [Re: madscientist] #1755456
02/15/15 11:35 PM
02/15/15 11:35 PM
USA
B3RE Offline
B3RE  Offline
USA
Last I heard, RAS was no longer in existence. I hope I heard incorrectly.
Mike Beachel
Re: Crane 1.5 ductile rockers [Re: B3RE] #1755457
02/15/15 11:53 PM
02/15/15 11:53 PM
You did, I had Gary bush, change ratio to 1.6 and blueprint 7 BB Mopar ductile iron rockers that I had here. I had them do a bunch of different brand, Mopar, Isky, Crane, Sig Erson and some cheaper no names, ductile iron rockers back in the early 1990s the same way as these are being done I've used them all up except the last nine I had so it is time to use them on my latest street pump gas stroker motor (512 C.I. 440 block) I'm making now with stock type heads. I sent them to him several weeks back, he quoted 2 to 3 weeks to finish them and he said Fridy he will ship them to me tomorrow, 2/16/20015. I'll post when they arrive and any appropriate comments
Re: Crane 1.5 ductile rockers [Re: Cab_Burge] #1755458
02/15/15 11:59 PM
02/15/15 11:59 PM
Canada
Canada
What does he charge? Ballpark/range is fine
Re: Crane 1.5 ductile rockers [Re: WO23Coronet] #1755459
02/16/15 12:07 AM
02/16/15 12:07 AM
You have a PM
Re: Crane 1.5 ductile rockers [Re: B3RE] #1755460
02/16/15 12:13 AM
02/16/15 12:13 AM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
The new owner of RAS, rockerarms.com closed up in 2012. But the old owner help the employees reopen as RAU (rocker arms unlimited). I hope they offer similar parts and service like they use to. I guess Cab will let us know!
Re: Crane 1.5 ductile rockers [Re: urdustd] #1755461
02/16/15 12:38 AM
02/16/15 12:38 AM
USA
B3RE Offline
B3RE  Offline
USA
I guess that's why I heard RAS was no longer in business. I was hoping there was still a possibility of getting some 440 Max replacement rockers.
Mike Beachel
Re: Crane 1.5 ductile rockers [Re: B3RE] #1755462
02/16/15 12:52 AM
02/16/15 12:52 AM
Lowes
steve660 Offline
steve660  Offline
Lowes
I had RHS bush some Comp Pro Magnum a few years ago. They didn't bore out the rockers. They press in a bushing and use a smaller diameter rocker shaft. I have an extra set of their shafts if interested.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Crane 1.5 ductile rockers [Re: B3RE] #1755463
02/16/15 03:45 AM
02/16/15 03:45 AM
Gary new phone number is 530-242-1316. The post about the new owners closing up RAS is true, Gary new location is in Redding,CA now He has been real busy, I belive, so call him and if he doesn't answer leave a message
Re: Crane 1.5 ductile rockers [Re: Cab_Burge] #1755464
02/16/15 10:35 AM
02/16/15 10:35 AM
USA
B3RE Offline
B3RE  Offline
USA
Good to hear, thanks Cab!
Mike Beachel
Re: Crane 1.5 ductile rockers [Re: WO23Coronet] #1755465
02/25/15 02:31 AM
02/25/15 02:31 AM
jax. fla.
70Dustmite440 Offline
jax. fla.
I'd kinda like to know that to.
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
