Re: Tire Size for 1970 Plymouth GTX
[Re: 6bblgt]
#1754509
02/23/15 02:34 AM
02/23/15 02:34 AM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
While there is no perfect cross reference, because tire measurements are left to the manufacturer - the following is the best practical reference to cover all musclecar era sizes. Tread width is no-where in the tire size spec. D70-14 = 195/70/14 E70-14 = 205/70/14 F70-14 = 215/70/14 G70-14 = 225/70/14 H70-14 = 235/70/14 E70-15 = 205/70/15 F70-15 = 215/70/15 G70-15 = 225/70/15 H70-15 = 235/70/15 E60-15 = 225/60/15 F60-15 = 235/60/15 G60-15 = 245/60/15 H60-15 = 255/60/15 J60-15 = 265/60/15 L60-15 = 275/60/15 & everyone likes/wants bigger tires
[Re: 6bblgt]
#1754510
02/23/15 10:37 AM
02/23/15 10:37 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Thanks Dan, saved good info
Careful, your character's showing!
[Re: GTXKARL]
#1754515
02/26/15 01:29 AM
02/26/15 01:29 AM
Posts: 959 france
jose jones
france
I cannot put rims and tires on the car because i need to put a lot of money into getting it running. So I have to use the rally wheels I have. I know everybody's says they look small, but the biiger rims are not in the budget. So can I put 215 70 14s on the front and 225 70s on the rear? I just want the back tires to be a bit wider than the front. Sorry, and thanks for the help.
14's look small on a big B-body you will most likely be disappointed with the look, If you can't afford 15x7 Rally Road wheels go find some cheap steel wheels and run 15 inch tires that way you haven't spent money on 14 inch tires that you will be unhappy with along with having a hard time selling if you ever decide, Then later when you can afford it buy some 15 inch Rally or Magnum 500's 15's are getting hard to find I imagine finding 14's s even more difficult
