340 valve covers #1754252
02/14/15 03:31 AM
02/14/15 03:31 AM
I picked up this set of 340 valve covers recently and was curious if they were amatched set or what they were from originally. Im better with the big block stuff when it comes to valve cover i.d.
Re: 340 valve covers [Re: ] #1754253
02/14/15 03:42 AM
02/14/15 03:42 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Even among 340's, the covers vary from year to year, and 340's could have subtle differences compared to 318's. If these are for a '70, you'd need someone expert with them. I'm more familiar with '68 & '69. What you have looks to be a matched set, but I couldn't tell if they are 318, or even later year 70's covers painted orange.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 340 valve covers [Re: GO_Fish] #1754254
02/14/15 03:50 AM
02/14/15 03:50 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
They don't look like 340 covers
Re: 340 valve covers [Re: ademon] #1754255
02/14/15 03:57 AM
02/14/15 03:57 AM
I got them with a pair of X heads and the guy was certain he pulled them from a 69 Dart back in the 80's wearing these covers. I wasnt sure.
Re: 340 valve covers [Re: ] #1754256
02/14/15 04:21 AM
02/14/15 04:21 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
How tall is the wire bracket on the top cover?
Re: 340 valve covers [Re: ] #1754257
02/14/15 04:23 AM
02/14/15 04:23 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
His story as he remembered may be true, but those are not correct for a 69 340 (or 318). They look to me to be '70-71 period, not sure about engine size. Edit, maybe they are '70? I think '71 had the twist cap oil fill rather than the push on breather???
Re: 340 valve covers [Re: GO_Fish] #1754258
02/14/15 04:27 AM
02/14/15 04:27 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
There defiantly not 71's, these are 71 and correct for 70 also I think.
Re: 340 valve covers [Re: ademon] #1754259
02/14/15 01:03 PM
02/14/15 01:03 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
These were also correct on a 71, but this style appeared on blue engine cars (when the engine plant change from Windsor to Mound Road occurred in the spring of 71).
Re: 340 valve covers [Re: ScottSmith_Harms] #1754260
02/14/15 01:04 PM
02/14/15 01:04 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: 340 valve covers [Re: GO_Fish] #1754261
02/14/15 01:16 PM
02/14/15 01:16 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
The twist on oil cap started in 1970. I have a couple sets of 69 340 covers and they are all turquoise. I will have to take a picture and post.
JB Rhinehart, Realist
A-Body's RULE!
Re: 340 valve covers [Re: ademon] #1754262
02/14/15 01:24 PM
02/14/15 01:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Relax and finish your Captn' Crunch Jimmy! Here's a set of Turquoise 69's
Re: 340 valve covers [Re: ScottSmith_Harms] #1754263
02/14/15 01:30 PM
02/14/15 01:30 PM
Rhinotruck
Rhinotruck
It was actually Coco Crisp, and it is 8 degrees outside with 40 mph wind, so I might not go over to the shop today... And.....they look ORANGE underneath...
A-Body's RULE!
Re: 340 valve covers [Re: Rhinodart] #1754264
02/14/15 02:33 PM
02/14/15 02:33 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Take your and stuff it!
They were just used to mask the valve gear on some heads that got painted orange, that's just over spray.....Still wearing original turquoise paint.
Re: 340 valve covers [Re: ScottSmith_Harms] #1754265
02/14/15 05:28 PM
02/14/15 05:28 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Well this makes it look more like the OP's covers could possibly be '69. The rear of the driver side cover is bent, and the curved bracket may also just be bent instead of straight. Need a better picture of the intake manifold side of the passenger cover to see if it has the right wire loom. They would have been turquoise originally, but maybe they were stripped before orange paint.
Re: 340 valve covers [Re: GO_Fish] #1754266
02/17/15 04:34 AM
02/17/15 04:34 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Can't see the bottom side of the bottom valve cover in the first photo, but the covers look to be almost the same as these 69 340 covers. My engine was built early, 11/1/68.
Only small difference I can spot is the tall vertical bracket at lower right in this photo looks to be 180 degrees different from the OP's photo. Either way would work.
