Page 1 of 13 1 2 3 12 13
The Quest Has Begun......605 Hemi Build, Updated! #1754090
02/13/15 09:57 PM
02/13/15 09:57 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Well I am now the proud owner of a pile of parts that will be an all aluminum 605 Hemi running pump gas in the quest for 9's in my street car....But I am not ruling out it could end up in my race car for a season.
Re: The Quest Has Begun.......Parts Arrived! [Re: Dragula] #1754091
02/13/15 10:43 PM
02/13/15 10:43 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Nice, what block did you go with?
Re: The Quest Has Begun.......Parts Arrived! [Re: Dragula] #1754092
02/13/15 10:47 PM
02/13/15 10:47 PM
gregsdart Offline
gregsdart  Offline
I'm jealous! Those parts would look great under the hood of my blue 65!
Re: The Quest Has Begun.......Parts Arrived! [Re: Dragula] #1754093
02/13/15 10:48 PM
02/13/15 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes sir you sure did get some parts
Re: The Quest Has Begun.......Parts Arrived! [Re: MR_P_BODY] #1754094
02/13/15 11:31 PM
02/13/15 11:31 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Spill your guts Randy, we need specs!! What did Bullet grind for you for starters????Dave
Re: The Quest Has Begun.......Parts Arrived! [Re: quickd100] #1754095
02/13/15 11:51 PM
02/13/15 11:51 PM
Dragula Offline OP
Dragula  Offline OP
Actually I still need head studs, head gaskets, lifters, pushrods, and a torque convertor.
Cam is kinda mild...I would call it a good Drag Week cam if I ever get a chance to do that...Its a cross between race and street longevity...And its a Barton Grind for his big Hemi's. He says he has this grind in hundreds of big Hemi's with very good success and lots of miles on them, so I am looking forward to firing it up to say the least.
Re: The Quest Has Begun.......Parts Arrived! [Re: DUSTER_340] #1754096
02/14/15 01:32 AM
02/14/15 01:32 AM
Dragula Offline OP
Dragula  Offline OP
It's an Indy block. Very light, for a Hemi. Especially when compared to the later World Block cast iron ones...I think mine was over 300lbs.
4.75" crank and 4.5 Bore...
Re: The Quest Has Begun.......Parts Arrived! [Re: Dragula] #1754097
02/14/15 03:56 AM
02/14/15 03:56 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Quest for 9's... 605 hemi...... sandbagger!!
That's a real nice pile of parts
Re: The Quest Has Begun.......Parts Arrived! [Re: Dragula] #1754098
02/14/15 05:47 AM
02/14/15 05:47 AM
California
mickm Offline
mickm  Offline
California
yup, keep the pictures, specs and progress coming!
Re: The Quest Has Begun.......Parts Arrived! [Re: SpareParts] #1754099
02/14/15 09:34 AM
02/14/15 09:34 AM
Dragula Offline OP
Dragula  Offline OP
I know, really...More like 9.50's...
Re: The Quest Has Begun.......Parts Arrived! [Re: Dragula] #1754100
02/14/15 05:33 PM
02/14/15 05:33 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Big Time nice pile
Re: The Quest Has Begun.......Parts Arrived! [Re: 340RICK] #1754101
02/15/15 12:58 AM
02/15/15 12:58 AM
Dragula Offline OP
Dragula  Offline OP
More pics....
Re: The Quest Has Begun.......Parts Arrived! [Re: Dragula] #1754102
02/15/15 08:53 AM
02/15/15 08:53 AM
pa
572charger Offline
572charger  Offline
pa
great choice on parts !!! solid roller cam ?? i ran 9.60s on pump gas with that mopar iron block i going to call bob george this week and get a indy block my block weighed 315 lbs indy is 133 lbs u get anything special done to the block ??
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: The Quest Has Begun.......Parts Arrived! [Re: 572charger] #1754103
02/15/15 09:23 AM
02/15/15 09:23 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
DrrrrrrrrrrrrrrroooooooooooooooooollllllllllllllllllllllL
Re: The Quest Has Begun.......Parts Arrived! [Re: 572charger] #1754104
02/15/15 12:14 PM
02/15/15 12:14 PM
Dragula Offline OP
Dragula  Offline OP
Jim,
Nothing too special. I had it drilled and tapped for the oil cross-over line, had it clearance for the 4.75 stroke, and at the advice of Bob, it was decked a couple thou after the sleeves were put in..
Its not even a raised cam block as I did not want the added expense of a Jesel belt drive..Based on the cam, I was not going to need it. Its a mild mechanical with, just under .700" lift when you factor in my rockers.
So it needs final hone for final bore size and we will begin assembly....Got one other engine on the stand that will be coming off by then...Not mine, but a nice street engine.
Re: The Quest Has Begun.......Parts Arrived! [Re: Dragula] #1754105
02/15/15 01:10 PM
02/15/15 01:10 PM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
If only I wasn't so poor! Looks like fun. Good luck with it.
Re: The Quest Has Begun.......Parts Arrived! [Re: Leigh] #1754106
02/15/15 01:14 PM
02/15/15 01:14 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
"Honey...? Do you mind if we skip making the mortgage payment for the next year... or two?"
Re: The Quest Has Begun.......Parts Arrived! [Re: mickm] #1754107
02/15/15 02:14 PM
02/15/15 02:14 PM
NC
440Jim Offline
440Jim  Offline
NC
Looks like a great start.
I agree with posting some specs on the build.
605 CID.... I remember when 500 CID was big !
Re: The Quest Has Begun.......Parts Arrived! [Re: 440Jim] #1754108
02/15/15 02:55 PM
02/15/15 02:55 PM
Mo.
racerx Offline
racerx  Offline
Mo.
And this is what I have to keep telling those GM guys
Re: The Quest Has Begun.......Parts Arrived! [Re: 440Jim] #1754109
02/15/15 04:25 PM
02/15/15 04:25 PM
Dragula Offline OP
Dragula  Offline OP
Ok so you guys want some specs......
With BGR's help we spec'd out some cool stuff. The Eagle Rods are 7.1 with ARP 2000 bolts. This was an upgrade BGR wanted due to the stroke of the engine. My understanding is the rods take a lot of abuse in a stroker mill...
