Newly rebuilt engine leaking coolant from a freezeplug #1753980
02/13/15 07:51 PM
02/13/15 07:51 PM
San Diego
Instigate Offline OP
San Diego
I get my LA 318 rebuilt by a machine shop and I've got it all put back in the truck and I put coolant in because I'm all ready to start it up and I see before I even start it, its leaking coolant from a freeze plug..
So this shop that rebuilt the engine, they put the rocker shafts on backwards, put rocker arms in the wrong order, fail to chase ANY threads and now I see a freeze plus is leaking.
I call the shop and the guy says to go ahead and start it up that the plug will stop leaking once it gets up to temp. Is this correct. Has anyone experienced this? The guy said it's a common thing to happen. But with all the other mistakes they made it seems to me that they prolly just didn't do a good job cleaning it. But this is the first time I've started a newly rebuilt engine so idk.
If what he's saying is true wouldn't it leak again once it cools down?
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: Instigate] #1753981
02/13/15 08:09 PM
02/13/15 08:09 PM
I call the shop and the guy says to go ahead and start it up that the plug will stop leaking once it gets up to temp. Is this correct. [quote/] (1) not correct. I'd go ahead and pull it & drive in a new one/with sealant. & since they butchered a kindergarten level job like the freeze plugs, before firing I'd pump the system up to 15 or 20 lbs & see if it holds. SB's have (2) in the back bell area
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: RapidRobert] #1753982
02/13/15 08:13 PM
02/13/15 08:13 PM
San Diego
San Diego
Ya, that's what I was thinking I should do. Thanks bud. I sure learned a lesson about just going with the cheapest place available. I would have been better off paying a couple hundred more to have a more reputable place do the job.
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: Instigate] #1753983
02/13/15 08:16 PM
02/13/15 08:16 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
As Robert said...that is not true...that engine shop sure doesn't have much going for them.
Freeze plugs should not weep hot or cold, etc. Started or not..
Once it is running the cooling system builds pressure, what will it be like then!
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: OzHemi] #1753984
02/13/15 08:25 PM
02/13/15 08:25 PM
San Diego
San Diego
That's what I thought lol and when it cools it will be just as it was before.
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: Instigate] #1753985
02/13/15 09:20 PM
02/13/15 09:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Sleep easy, I'm sure that they got the hard, complicated and critical parts right.
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: Instigate] #1753986
02/13/15 09:40 PM
02/13/15 09:40 PM
scratchnfotraction Offline
are they brass or steel plugs?
I have had a couple brass leak and I used the brown Indian head gasket shellac to seal on install.
after it got up to temp a FEW times it sealed the plug and never leaked again.
best to use some emery cloth to clean the cast iron seal surface before hand...done at the same time you would chase ALL threds/holes in the block.
I ALWAYS use 2 brass plugs in the back of block, sucks when you have to R&R the trans to replace a rusted steel plug.
I wager you have a 50/50 chance a couple heat cycles would expand it enough to seal...if they did not bend it or cup it out of shape.
another reason I test fire my engine build with water the first go round..anti freeze is $$ to be leaking out on the ground.
good luck and keep us posted on progress plez.
check your PM, I sent you one about the vid link you posted
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: scratchnfotraction] #1753987
02/13/15 10:07 PM
02/13/15 10:07 PM
San Diego
San Diego
For sure. They used brass plugs on it.
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: Instigate] #1753988
02/13/15 10:39 PM
02/13/15 10:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You think the factory f'd around with leaky freeze plugs that finally sealed after a few warmups?
No, if it's leaking it was done wrong.
Don't be the exception.
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: Supercuda] #1753989
02/13/15 11:27 PM
02/13/15 11:27 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I would say, How bad is it leaking??? A drip, a stream ????
It is not unusual for freeze plugs to leak a bit if they were installed DRY. A heat cycle or two may correct a small drip. A stream not likely. A lot of suppliers of reman or even new engines recommend their "sealant of choice" for cooling systems on install of the motor.
So a minor drip, MAYBE, a steady leak, not likely the long term fix I would be comfortable with. Hope this helped to some degree
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: TJP] #1753990
02/14/15 01:41 AM
02/14/15 01:41 AM
france
jose jones Offline
jose jones  Offline
france
On the last 440 we built one of the freeze plugs leaked for a few minutes at start up then sealed itself, This was months ago and it never leaked again
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: jose jones] #1753991
02/14/15 01:54 AM
02/14/15 01:54 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
leaking before any pressure build up is no good in my book
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: AARCONV] #1753992
02/14/15 10:44 AM
02/14/15 10:44 AM
Maryland
gofastboater Offline
Maryland
LMFAO. Is this guy serious?? I have NEVER had a freeze plug leak on a rebuild. Even on salt water marine motors. Sounds like a real [Edited by Moparts - Family Friendly Site - Keep it clean]. Pull out the leaking plug and clean the sealing surface with emory cloth. Get a new brass plug and use some sealer and put it back in. Problem should be solved. And oh yea, find a different machine shop for your next rebuild !!!!
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: gofastboater] #1753993
02/14/15 01:02 PM
02/14/15 01:02 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
This is a lose lose situation. On all internet forums there are conflicting opinions. 1 Person may want to do his own rebuild- members chime in even flaming him for not being willing to do the job himself. Then if he does it himself and something is wrong members flame away saying you shoulda paid a shop to do it right. 2 Person pays a shop to do everything because they want it done right. Engine has problems and members chime in saying you shoulda done it yourself and not paid some hacks to mess up your engine. I sure feel bad and angry for anyone who pays a supposed pro for pro results- but gets hack results and service after payment.
Keep old mopars alive.
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: TJP] #1753994
02/14/15 01:42 PM
02/14/15 01:42 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Put some stop leak in the coolant system and get it hot and all of the leaks will seal forever. It's a conditioner also for the coolant system too. No big deal on the freeze/core plugs, imo.
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: Challenger 1] #1753995
02/14/15 03:26 PM
02/14/15 03:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Better yet check to see if there is a small crack in the block.I had a 440 that had a leak there.Sealed for years then when it was tanked the crack was there and bigger.Rocky
Chrysler Firepower
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: Challenger 1] #1753996
02/14/15 11:12 PM
02/14/15 11:12 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Don't bandaide. Do it right. Pop out the plug, get a new one and smooth out the block surfaces, put a little sealer on the plug/block surfaces and reinstall.
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: MoparforLife] #1753997
02/15/15 12:36 PM
02/15/15 12:36 PM
Central NY
GarageDodge Online content
GarageDodge  Online Content
Central NY
rebuild alot of engines,&replaced alot of freezeplugs in the vechiles,never had one leak. Replace the leaking one,clean block with sandpaper then coat plug with sealer,I use permatex #2 &install,good luck.
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: GarageDodge] #1753998
02/15/15 02:16 PM
02/15/15 02:16 PM
Mass
charge70 Offline
charge70  Offline
Mass
Is there any possibility that it is one of the end exhaust manifold studs/bolts leaking.Coolant leaking there and running down onto the freeze plug making it look like the plug is leaking? Just thinking out loud. My John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Newly rebuilt engine leaking coolant from a freezeplug [Re: charge70] #1753999
02/15/15 03:07 PM
02/15/15 03:07 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'd love to hear this shop's fix when the rods start knocking because they didn't check bearing clearances...
'Add some 90 weight gear oil...and sawdust. That'll stop the knocking'
**Photobucket sucks**
