Newly rebuilt engine leaking coolant from a freezeplug
#1753980
02/13/15 07:51 PM
02/13/15 07:51 PM
Posts: 156 San Diego
Instigate
San Diego
I get my LA 318 rebuilt by a machine shop and I've got it all put back in the truck and I put coolant in because I'm all ready to start it up and I see before I even start it, its leaking coolant from a freeze plug..
So this shop that rebuilt the engine, they put the rocker shafts on backwards, put rocker arms in the wrong order, fail to chase ANY threads and now I see a freeze plus is leaking.
I call the shop and the guy says to go ahead and start it up that the plug will stop leaking once it gets up to temp. Is this correct. Has anyone experienced this? The guy said it's a common thing to happen. But with all the other mistakes they made it seems to me that they prolly just didn't do a good job cleaning it. But this is the first time I've started a newly rebuilt engine so idk.
If what he's saying is true wouldn't it leak again once it cools down?
Re: Newly rebuilt engine leaking coolant from a freezeplug
[Re: RapidRobert]
#1753982
02/13/15 08:13 PM
02/13/15 08:13 PM
Instigate
San Diego
I call the shop and the guy says to go ahead and start it up that the plug will stop leaking once it gets up to temp. Is this correct. [quote/] (1) not correct. I'd go ahead and pull it & drive in a new one/with sealant. & since they butchered a kindergarten level job like the freeze plugs, before firing I'd pump the system up to 15 or 20 lbs & see if it holds. SB's have (2) in the back bell area
Ya, that's what I was thinking I should do. Thanks bud. I sure learned a lesson about just going with the cheapest place available. I would have been better off paying a couple hundred more to have a more reputable place do the job.
[Re: OzHemi]
#1753984
02/13/15 08:25 PM
02/13/15 08:25 PM
Instigate
San Diego
As Robert said...that is not true...that engine shop sure doesn't have much going for them.
Freeze plugs should not weep hot or cold, etc. Started or not..
Once it is running the cooling system builds pressure, what will it be like then!
That's what I thought lol and when it cools it will be just as it was before.
[Re: Instigate]
#1753985
02/13/15 09:20 PM
02/13/15 09:20 PM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
Sleep easy, I'm sure that they got the hard, complicated and critical parts right.
[Re: scratchnfotraction]
#1753987
02/13/15 10:07 PM
02/13/15 10:07 PM
Instigate
San Diego
are they brass or steel plugs?
I have had a couple brass leak and I used the brown Indian head gasket shellac to seal on install.
after it got up to temp a FEW times it sealed the plug and never leaked again.
best to use some emery cloth to clean the cast iron seal surface before hand...done at the same time you would chase ALL threds/holes in the block.
I ALWAYS use 2 brass plugs in the back of block, sucks when you have to R&R the trans to replace a rusted steel plug.
I wager you have a 50/50 chance a couple heat cycles would expand it enough to seal...if they did not bend it or cup it out of shape.
another reason I test fire my engine build with water the first go round..anti freeze is $$ to be leaking out on the ground.
good luck and keep us posted on progress plez.
check your PM, I sent you one about the vid link you posted
For sure. They used brass plugs on it.
[Re: Instigate]
#1753988
02/13/15 10:39 PM
02/13/15 10:39 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You think the factory f'd around with leaky freeze plugs that finally sealed after a few warmups?
No, if it's leaking it was done wrong.
[Re: TJP]
#1753994
02/14/15 01:42 PM
02/14/15 01:42 PM
Challenger 1
Cincinnati, Ohio
I would say, How bad is it leaking??? A drip, a stream ???? It is not unusual for freeze plugs to leak a bit if they were installed DRY. A heat cycle or two may correct a small drip. A stream not likely. A lot of suppliers of reman or even new engines recommend their "sealant of choice" for cooling systems on install of the motor. So a minor drip, MAYBE, a steady leak, not likely the long term fix I would be comfortable with. Hope this helped to some degree
Put some stop leak in the coolant system and get it hot and all of the leaks will seal forever. It's a conditioner also for the coolant system too. No big deal on the freeze/core plugs, imo.
[Re: Challenger 1]
#1753995
02/14/15 03:26 PM
02/14/15 03:26 PM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
Better yet check to see if there is a small crack in the block.I had a 440 that had a leak there.Sealed for years then when it was tanked the crack was there and bigger.Rocky
Chrysler Firepower
[Re: Challenger 1]
#1753996
02/14/15 11:12 PM
02/14/15 11:12 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Don't bandaide. Do it right. Pop out the plug, get a new one and smooth out the block surfaces, put a little sealer on the plug/block surfaces and reinstall.
[Re: GarageDodge]
#1753998
02/15/15 02:16 PM
02/15/15 02:16 PM
Posts: 601 Mass
charge70
Mass
Is there any possibility that it is one of the end exhaust manifold studs/bolts leaking.Coolant leaking there and running down onto the freeze plug making it look like the plug is leaking? Just thinking out loud. My John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#1753999
02/15/15 03:07 PM
02/15/15 03:07 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I'd love to hear this shop's fix when the rods start knocking because they didn't check bearing clearances...
'Add some 90 weight gear oil...and sawdust. That'll stop the knocking'
**Photobucket sucks**
