motor plate tips #1752745
02/12/15 01:45 AM
02/12/15 01:45 AM
ky, usa
littlejohn44 Offline OP
ky, usa
How are you guys sealing your water pumps with motor plates? Are you running gaskets on both sides or just sealer?
Re: motor plate tips [Re: littlejohn44] #1752746
02/12/15 01:54 AM
02/12/15 01:54 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I went with a remote pump , but was planning on using this till I changed plans.
The stuff is supposed to seal really well....no gasket needed.
http://www.ebay.com/itm/Yamaha-Yamalube-...407&vxp=mtr
Re: motor plate tips [Re: tubtar] #1752747
02/12/15 02:04 AM
02/12/15 02:04 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used a set of superformanceproducts gaskets on each side of the plate. No sealer and it has never leaked even a drip.
Re: motor plate tips [Re: littlejohn44] #1752748
02/12/15 02:13 AM
02/12/15 02:13 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
I also only used just gaskets on each side of the plate . Recently I had the motor plate powder coated and cannot seem to keep the pump from leaking now . Did it in the spring and had to replace the gaskets twice through the year when it would start to leak . I am going to remove the powder coating where the gaskets go and reseal . never had issues before the coating . Gary
Re: motor plate tips [Re: littlejohn44] #1752749
02/12/15 02:16 AM
02/12/15 02:16 AM
I use two gaskets per side and thermostat housing silicone sealer on them
Re: motor plate tips [Re: WILD BILL] #1752750
02/12/15 02:41 AM
02/12/15 02:41 AM
ky, usa
ky, usa
Where have you been getting your gaskets from? Are they thicker than the fel pros?
Re: motor plate tips [Re: WILD BILL] #1752751
02/12/15 03:22 AM
02/12/15 03:22 AM
fresno ca
mikeysmopars Offline
fresno ca
SAME HERE!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: motor plate tips [Re: littlejohn44] #1752752
02/12/15 04:14 AM
02/12/15 04:14 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Click the link in my post. I know there a aa number of vendors that carry them but I got mine directly from Greg as he helped sponsor my motor build with Koffel's Place.
It's been a while since I put it together but IIRC they are a hair thicker then the Fel Pro's.
Re: motor plate tips [Re: littlejohn44] #1752753
02/12/15 01:13 PM
02/12/15 01:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the Mopar black RTV on both sides of the plate
Re: motor plate tips [Re: littlejohn44] #1752754
02/12/15 02:14 PM
02/12/15 02:14 PM
an8sec70cuda Offline
Just grey silicone on both sides of mine...never leaked a drop.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: motor plate tips [Re: an8sec70cuda] #1752755
02/12/15 03:37 PM
02/12/15 03:37 PM
ky, usa
ky, usa
i have never ran a plate so i didnt know if it was a leaky area. Thanks for all the replies
Re: motor plate tips [Re: littlejohn44] #1752756
02/12/15 04:26 PM
02/12/15 04:26 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
O ring. I oring'd the plate. Absolutely no leaks.
Re: motor plate tips [Re: markz528] #1752757
02/12/15 06:35 PM
02/12/15 06:35 PM
ky, usa
ky, usa
Just got off the phone with superformance i have 4 sets heading this way. Greg was really helpful, will buy from him again.
Re: motor plate tips [Re: littlejohn44] #1752758
02/12/15 06:59 PM
02/12/15 06:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A few more tips.. put the frame mounting points BEHIND
the motor plate.. that way you dont have to lift up
and over the mounts... also put at least 2 bolts per
side and spread them apart.. that way it wont try to
pivot on a single bolt.. I use a 3/8" motor plate to
reduce flex
Re: motor plate tips [Re: MR_P_BODY] #1752759
02/12/15 07:14 PM
02/12/15 07:14 PM
sccuda Offline
sccuda  Offline
Permatex Right Stuff on both sides of plate w/NO Gaskets. Never look back will last for years.
Re: motor plate tips [Re: littlejohn44] #1752760
02/12/15 08:35 PM
02/12/15 08:35 PM
AndyF Offline
AndyF  Offline
On my old school setups I use paper gaskets but I hang everything from studs so I can slide the water pump on and off without dropping the engine.
My newer stuff is all converted over to o-rings and/or remote water pump. I think the remote water pump is the way to go.
Re: motor plate tips [Re: AndyF] #1752761
02/12/15 08:50 PM
02/12/15 08:50 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Black RTV only for me, Gray is even better as Chip mentioned but it almost welds the parts together lol. I blew out gaskets in the burnout box years ago and never used them again but I bet the Superformance ones are fine.
Re: motor plate tips [Re: Gabby63] #1752762
02/12/15 09:59 PM
02/12/15 09:59 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
Must have orange peel if I had to guess. You could sand it with scotch brite or real fine sandpaper before you put it back together, you shouldn't have to take it down to bare metal, though.
Re: motor plate tips [Re: Chad Bittle] #1752763
02/12/15 11:09 PM
02/12/15 11:09 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ultra gray only here..Never had an issue.
Re: motor plate tips [Re: WILD BILL] #1752764
02/13/15 07:33 PM
02/13/15 07:33 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Same here..NO leaks at all!
Nautilus Racing-
