Page 3 of 3 1 2 3
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175143
12/28/08 11:16 PM
12/28/08 11:16 PM
NC
440Jim Offline
440Jim  Offline
NC
According to a article in the latest Drag racing action mag there is a tester offered by Quick Fuel that will test the Ethanol content of your fuel, might be somthing to look into and it look's to be a decent article,,,guess I need to sit down and do some reading. now I need to try and find a station around these part's that sell's it.
Bill do you have any info or P/N on that tester
or the article that you can post. I might have to see
if I can get that mag
I have been happy with this method from the E85 handbook on the National Ethanol Vehicle Coalition website:
http://www.e85fuel.com/pdf/storing-handling-e85.pdf
Procedure for Testing Hydrocarbon Percent of Ethanol Fuel Samples
Based on SAE International Paper 912421 (Prepared by NEVC)
Equipment for E85 testing
VWR Scientific phone # 800-932-5000
50 mL pipettes; Cat. # 52966-217 pack of 12/$212.18
Safety Bulb; Cat. # 53497-202 pack of 3/$18.45
100 mL cylinders; Cat. # 24762-117 pack of 4/$120
Procedure
• Using the suction bulb, pipette exactly 50 mL of fuel sample into the graduated cylinder.
• Add about 48 mL of water to make the total liquid volume just less than 100 mL.
• Place the stopper in the cylinder and shake vigorously for about 15 seconds.
• Carefully loosen the stopper to release any accumulated pressure; do not remove the stopper.
• Close the stopper again and place the cylinder upright on a level surface. Allow the mixture to sit for about
15 minutes.
• Record the total volume of liquid by reading the lowest part of the upper meniscus (the curved interface
between the liquid and air).
• Record the total volume of the alcohol/water layer by reading the lowest part of the lower meniscus (the
curved interface between the two liquid layers).
Calculation
• The hydrocarbon percent is calculated by: 2.1 + 1.94 * (total volume - alcohol/water volume)
• Assuming the sample was an ethanol/hydrocarbon mixture, the ethanol percent is 100 minus the
hydrocarbon percent.
Example:
Upper 98 ml, lower 91 ml
2.1 + 1.94 x (98 - 91) = 15.68
ethanol = 100 - 15.68 = 84.3%
DOE Handbook 2008, Appexdix D, page 45.
Re: Converting your bracket car to E-85, dicuss or link [Re: 440Jim] #175144
12/28/08 11:23 PM
12/28/08 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Procedure
15 minutes.
Calculation
Example:
Jim, thats the same as I use to do when I was working,
same procedure. I was wondering if they came out
with some thing new
Re: Converting your bracket car to E-85, dicuss or link [Re: 440Jim] #175145
12/28/08 11:37 PM
12/28/08 11:37 PM
Illinois
493_Scamp Offline
super gas
493_Scamp  Offline
super gas
Illinois
My Mallory pump locked up after E85 use,but I bought it used about 4 years ago,and it didnt act right when I pumped the cell dry for the switch over. I assumed my Battery was low, after runnung the last race and sitting a few weeks It wont even turn. Mallory has alcohol gasket rebuild kits for the pumps and regulators and offers a rebuild service.I think the paper filters may be prone to failures as well so I deliberately left it fueled as a test.
Re: Converting your bracket car to E-85, dicuss or link [Re: 493_Scamp] #175146
12/28/08 11:44 PM
12/28/08 11:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm running a pair of Holley black 150's and so far
they've been fine
Re: Converting your bracket car to E-85, dicuss or link [Re: RyanJ] #175147
12/30/08 09:06 PM
12/30/08 09:06 PM
Missouri
StrokerPost Offline OP
Missouri
I just found out today that there is finally an E85 pump within 15 minutes of my house!
It is $2.89 today.
I paid $1.23 here last week....
Its amazing and confusing why there is such a difference in price around the country. I checked on it while I was out today, its $2.49 gal here. I thought it had kinda been keeping pace with gas, but I guess not. For those paying $1.23 what is reg unleaded, and those paying $2.89, whats reg there? Reg here is $1.34.
Re: Converting your bracket car to E-85, dicuss or link [Re: StrokerPost] #175148
12/30/08 11:13 PM
12/30/08 11:13 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Anyway you look at it, it still beats the snot out of paying $7.50 a gallon for Cam2.
It's just the initial hurdle of buying a new E85 carb, fuel pump and regulator. Or having these pieces modified.
Re: Converting your bracket car to E-85, dicuss or link [Re: StrokerPost] #175149
12/30/08 11:28 PM
12/30/08 11:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It is $2.89 today.
At 2.89 thats real pricey, around here its about
1.65 for E-85 and about 1.50 for regular. If your
pump can handle the increase in volume by 30% all
you would need to do is the carb. I have a spare
1050 that if I ran out of E-85 I can switch the carb
and be running on race gas(buy it at the track) and
be running in 5 minutes by just changing the carb
and backing the timing down a few degrees and be
running the same times(what I've seen so far)
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175150
12/30/08 11:44 PM
12/30/08 11:44 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
hey P body, I can't remember did you pick up some when you switched?
Re: Converting your bracket car to E-85, dicuss or link [Re: dthemi] #175151
12/31/08 12:09 AM
12/31/08 12:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Actually I stayed the same BUT I didnt touch the
timing yet, I was going to start bumping it up
but I put the car away early this year. I do mean
it stayed the same within .01, best before was 9.08
and with the E-85 it was 9.09 3 passes in a row
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175152
12/31/08 01:15 PM
12/31/08 01:15 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Here's another question, there's alot of deals out there right now on alcohol carbs. What's it take to run E85 with an alcohol carb?
Re: Converting your bracket car to E-85, dicuss or link [Re: ProSport] #175153
12/31/08 01:20 PM
12/31/08 01:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well its starting out with the good parts but I
would think you would still be working it over just
the same as going from gas to E-85 when it comes
to the passages and jetting but that MIGHT be a
good way to start if it isnt all corroded
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175154
12/31/08 04:58 PM
12/31/08 04:58 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Maybe I'll call Quickfuel and see what the difference is between their E85 and alcohol carbs.
They have a 1050cfm 4150 alcohol carb for a half way decent price.
Quickfuel
Re: Converting your bracket car to E-85, dicuss or link [Re: ProSport] #175155
12/31/08 11:05 PM
12/31/08 11:05 PM
NC
440Jim Offline
440Jim  Offline
NC
I am no expert on carb design, but the gas carb should be closer to start with than a methanol (alky) carb. Remember if gas is 100%, E85 is about 135%, and methanol is around 200%. So the boosters and passages in the metering blocks will be too large and slow the fuel down in an alky carb running E85 (if you can choke down the total fuel flow).
Things like the main well dia, cross channel passage dia, booster fuel flow channel dia, etc.
I have been talking with guys on e85forum about my 950 carb boosters. On gas they are 0.156", an alky setup might be around 0.190", I am having a shop put 0.170" boosters in for 2009.
Re: Converting your bracket car to E-85, dicuss or link [Re: 440Jim] #175156
01/01/09 03:34 PM
01/01/09 03:34 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Oh ok, I thought I'd read here several times that alcohol carbs were pretty close to an E85 carb.
I think the best bet is an E85 carb from someone like Quickfuel.
I'm just worried about getting a batch of E70 instead of E85 from the pump.
Re: Converting your bracket car to E-85, dicuss or link [Re: ProSport] #175157
01/01/09 03:47 PM
01/01/09 03:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is something that we all look at, but if you
check the drop sheets before you buy your fuel you
would have a pretty decent idea what your getting.
Of course you check it and if its what you want then
buy it in quanity(drums) instead of just a tank at a
time. Check with Quick Fuel like you said about the
differences between the 2 style carbs
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175158
01/01/09 04:03 PM
01/01/09 04:03 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Jim, I have been following the discussion on the E85 forum. It seems to me that Drag Chevette has a pretty firm grasp of what needs to be modified to make a carb work on E85. Would that be your opinion as well? I'm considering having him modify my 950 is the reason I ask. Jim
Re: Converting your bracket car to E-85, dicuss or link [Re: rt66jim] #175159
01/01/09 04:14 PM
01/01/09 04:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes I believe he has about as much info as anyone
and he did a fair amount of testing to get where he is.
I would let him or just use his info and do it yourself
Re: Converting your bracket car to E-85, dicuss or link [Re: MR_P_BODY] #175160
01/01/09 08:30 PM
01/01/09 08:30 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Mike I'm just not comfortable trying to do it myself. I'd sure hate to mess up a few hundred $$ worth of parts. When that would get it done by someone who knows what they are doing. Jim
Re: Converting your bracket car to E-85, dicuss or link [Re: rt66jim] #175161
01/01/09 10:13 PM
01/01/09 10:13 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Ive been talking to Drag Chevette also. He sure seems to know what he is talking about. I think I'll have him convert my carb, especially if the new station being built carries E-85.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Converting your bracket car to E-85, dicuss or link [Re: rt66jim] #175162
01/01/09 10:23 PM
01/01/09 10:23 PM
NC
440Jim Offline
440Jim  Offline
NC
I trust him to do the work.
There are a bunch of reputable carb shops that can do E85 carbs now. Talk to them and pick who you want (including Drag Chevette - Mark).
With anyone, tune the carb after you get it for optimum performance.
Page 3 of 3 1 2 3
