connecting rod weight? #1750261
02/09/15 08:16 PM
02/09/15 08:16 PM
ohio
all spooled up Offline OP
ohio
what is a good connecting rod weight for a small block 6.125 long rod
Re: connecting rod weight? [Re: all spooled up] #1750262
02/09/15 08:26 PM
02/09/15 08:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being 6.125 I assume chevy... is it a I or H beam
Re: connecting rod weight? [Re: all spooled up] #1750263
02/09/15 09:29 PM
02/09/15 09:29 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
My CAT H beams weigh 735gm about the same as a stock rod. They are 6.123 long. I have a set of Pankle's that are 6.4 long and weigh 585gm.
Re: connecting rod weight? [Re: rt66jim] #1750264
02/09/15 09:46 PM
02/09/15 09:46 PM
ohio
ohio
chevy ls7 thay are 466 grams.
Re: connecting rod weight? [Re: all spooled up] #1750265
02/10/15 01:48 PM
02/10/15 01:48 PM
dogdays Offline
dogdays  Offline
For a Mopar 6.123 they'll usually come in about 650 grams. The SIR rods are close to 600, can't remember if over or under.
A 6.125" chevy rod should weigh around 600 grams, I have some that were heavy duty right at 660.
Stock Mopar rods are clubs, IIRC 728 and 756 grams.
R.
