65 Plymouth dual diaphragm booster #1750213
02/09/15 07:44 PM
02/09/15 07:44 PM
Lost and Spaced
bboogieart Offline OP
Lost and Spaced
I am trying to help a fellow enthusiast from Finland,
get his 65 Fury up and going for an inspection.
His car was equipped with the rare Budd disc brake system.
He has retro fitted a dual pot master for safety, along with the system from a 71 Town and Country wagon, but the dual diaphragm booster is out of commission.
Anybody have a source for a booster or a rebuild kit?
I have mechanical Aptitude.
I can screw up anything.
Re: 65 Plymouth dual diaphragm booster [Re: bboogieart] #1750214
02/10/15 12:14 AM
02/10/15 12:14 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I think one for a 69 C-body disc brake car will work. I have one on my 66 but it is a console shift car. The later model boosters will interfere with the column shift linkage but I think that is the larger single diaphragm one.
The 65 column shift is cable operated so it might not be an issue meaning anything from 69 to 73 and perhaps later might work if your car is column shift.
Kevin
Re: 65 Plymouth dual diaphragm booster [Re: Twostick] #1750215
02/10/15 12:00 PM
02/10/15 12:00 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Did your friend's original master cylinder have a circular reservoir extension on the top of the master cylinder? I have a booster/MC combination with that feature. Off what I do not know.
Re: 65 Plymouth dual diaphragm booster [Re: Twostick] #1750216
02/10/15 02:11 PM
02/10/15 02:11 PM
Georgia
K
KingTuna Offline
KingTuna  Offline
K
Georgia
Kevin
I am looking at doing a disc brake swap down the road and have researched this. You are correct, he could use the large single diaphragm or a dual. I have to use a dual due to mine is column shift.
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
Re: 65 Plymouth dual diaphragm booster [Re: KingTuna] #1750217
02/10/15 08:32 PM
02/10/15 08:32 PM
Lost and Spaced
Lost and Spaced
Thanx folks.
I will pass this along.
