Page 1 of 3 1 2 3
65 town wagon project #1749913
02/09/15 02:31 AM
02/09/15 02:31 AM
mesa , az
P
penski61 Offline OP
penski61  Offline OP
P
mesa , az
started a build on a 65 town wagon , picked it up a few months ago . when i bought it i was told it would take a few hours and the wagon would be back up and running just needed a starter and alt , well after i got it home that was not the case . i had to go thru all the hack wiring just to get it to where i could even try and start it , finally got that done and the engine would not turn over ( i tried by hand first but only moved it 1/4 turn ) took the new starter out and tested and was good . pulled the valve cover off (slant 6 ) and found cover was not sealed and water was all over the rocker and springs , so i pulled the head and checked the block and found the engine would turn over now but the first piston had bad rings so i decided to just pull the engine and do a v8 swap .
while i had the front end apart and engine out i decided to modify the frame to accept a crown vic front suspension that uses the aluminum cross member will all the suspension tied onto it , Im almost done with the install just need to tie in the trailing arms that come off the lower control arm . Yesterday i went to the Jy and pulled a 5.9 magnum and got it mocked up then one of the motor mount brackets just about done , hoping to finish it off get the 2nd one done , pull motor back out , box in the lower portion of the brackets then finish off the trailing arms
day we picked it up
out with the old
old motor mounts out and frame pressure washed
boxing started
frame cleaned up
suspension installed
and how it currently sits
went to the junkyard and pulled a 46rh /a518 out of a 1990 d150 , got it all cleaned up and bolted to the engine . put both back in the wagon and found i had to cut out the old trans cross member so the new trans could sit in down, once i had that cut out the other cross member was right under the very tail end of the trans so i decided to make a new removable cross member .
started on the 4 link in the rear , so far i got a section of the frame plated and upper link mounts done on both frame and axle . also went to the junk yard and found a rear sway bar off a crown vic that fits very well , just had to make the axle mounts
Re: town wagon project [Re: penski61] #1749914
02/09/15 02:33 AM
02/09/15 02:33 AM
mesa , az
P
penski61 Offline OP
penski61  Offline OP
P
mesa , az
went to the junkyard and pulled a dodge 1500 pedal assembly and brake booster , benefits will be cable gas pedal vs rod linkage and power brakes . also pulled backing plates and e-brake line from a grand cherokee do a disc brake conversion
made adapter plates which also covered the old holes then made an adapter for the steering column i picked up last week
Re: town wagon project [Re: penski61] #1749915
02/09/15 02:35 AM
02/09/15 02:35 AM
mesa , az
P
penski61 Offline OP
penski61  Offline OP
P
mesa , az
got the new gas tank mounted up
pulled a floor shifter from the junkyard to see if i could adapt it to work in the dodge
what it looks like after i modified it
pulled grand cherokee disc brake assembly for the conversion on the 8.75 . i went a little different route than most for the caliper bracket but i didn't want to have a spacer so i just cut the caliper bracket out and welded it to the tube end
Re: town wagon project [Re: penski61] #1749916
02/09/15 02:59 PM
02/09/15 02:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Looks good so far but you deleted the important part as to what it is and what you r plan is.
Re: town wagon project [Re: stumpy] #1749917
02/09/15 03:34 PM
02/09/15 03:34 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Wonder why he deleted it I saw it posted last night and it looked to be a great project. If I remember right it was a 1955 Town Panel wagon and I like the direction he is going
Re: town wagon project [Re: max_maniac] #1749918
02/09/15 03:49 PM
02/09/15 03:49 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
That's strange, I agree this really looked interesting.
Sheldon
Re: town wagon project [Re: RUNCHARGER] #1749919
02/09/15 07:37 PM
02/09/15 07:37 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Wow....I agree.....it looks like it's all Mopar too. I'm using those Grand Cherokee rear disk breaks also on my Valiant.
Moparlee
Re: town wagon project [Re: Robbins] #1749920
02/11/15 02:38 AM
02/11/15 02:38 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I believe he said 65 town wagon.
Re: town wagon project [Re: Robbins] #1749921
02/15/15 05:15 PM
02/15/15 05:15 PM
Chicagoland
Cooter Online rolleyes
Cooter  Online Rolleyes
Chicagoland
Well, except for the Crown Vic front suspension.
Re: town wagon project [Re: Cooter] #1749922
02/15/15 08:23 PM
02/15/15 08:23 PM
Missouri
galen Offline
galen  Offline
Missouri
Cool project. Missed the first post. Thanks for sharing this.
Re: town wagon project [Re: penski61] #1749923
02/15/15 09:13 PM
02/15/15 09:13 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
looks like a pretty cool build. what's up with your first post?
Re: town wagon project [Re: Golden-Arm] #1749924
02/15/15 10:24 PM
02/15/15 10:24 PM
N
NITROUSN Offline
NITROUSN  Offline
N
3 posts and poof.?????
Re: town wagon project [Re: Golden-Arm] #1749925
02/16/15 04:00 AM
02/16/15 04:00 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
It wasn't much really, he just showed a white town wagon and how he tore it apart. Very strange that he would just delete the first post and disappear. Proprietary information?
Re: town wagon project [Re: Cooter] #1749926
02/16/15 06:42 PM
02/16/15 06:42 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Oh sun of a......your right.
Moparlee
Re: town wagon project [Re: Robbins] #1749927
02/26/15 02:46 AM
02/26/15 02:46 AM
mesa , az
P
penski61 Offline OP
penski61  Offline OP
P
mesa , az
huh , i didn't realize the thread was still visible , most forums will delete the thread when ou delete the 1st post
i was having issues with photobucket and was going to re-post once i got the issues fixed but forgot to update since ive been busy with the project
Re: town wagon project [Re: penski61] #1749928
02/26/15 02:51 AM
02/26/15 02:51 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Understandable once you post more pics and give us some more info.
Re: town wagon project [Re: MuuMuu101] #1749929
02/26/15 03:09 AM
02/26/15 03:09 AM
mesa , az
P
penski61 Offline OP
penski61  Offline OP
P
mesa , az
1st post fixed and more pics of the progress
made a bracket for the steering column and got it mounted into place , then got the steering figured out to the steering rack
then i got the frame out and cleaned up , cut the rivets out for the body mounts so the brackets could be cleaned up. frame along with body mounts , links and a few cross members are at powder coat and should have everything by Friday
tore down the 742 case and cleaned everything up then put all new bearings in and checked the pattern . then cleaned up the inside of the housing as well as outside and got it painted
while the rear axle was drying pulled the crown vic suspension apart and painted the x member . once that was dry started putting back together
Re: town wagon project [Re: penski61] #1749930
02/26/15 03:37 AM
02/26/15 03:37 AM
mesa , az
P
penski61 Offline OP
penski61  Offline OP
P
mesa , az
so the purpose of the build is to have something different all the other vehicles we have are 4x4 (1) dedicated crawler (1) dd/ camping rig and (1) tow rig plus i wanted to try my hand at putting a spin on something classic. being a cruiser we wanted to be comfortable and bring the pups with us so took the wife to the jy and picked out seats , scored some decent seats out of an 98 durango
decided to add sheet metal for the bench seat instead of just bolting it to the plywood wood platform in the back .
dogs testing the truck out
thats it for pics tonight but i should have more tomorrow of the axle put back together as well as the crown vic front end
Re: town wagon project [Re: penski61] #1749931
02/26/15 10:43 AM
02/26/15 10:43 AM
Guitar Jones Offline
Dog tested and approved.
I like it better than a Subaru.
Re: town wagon project [Re: Guitar Jones] #1749932
02/26/15 11:41 PM
02/26/15 11:41 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
That's funny. I just saw that comercial for the first time about a minute ago.
Can't wait to get home tommorow night so I can take a look at the photos.
Glad this thread was updated. Seems to be a fun build.
I have mechanical Aptitude.
I can screw up anything.
Page 1 of 3 1 2 3
