Posting here after posting in the jeep section and another jeep forum and not getting any love. Swapping a 4.0 from a 92 into my 95 wrangler 4 cylinder. Using the engine harness and computer from the 92. The dash harness and headlight harness is from my 95. I thought everything was the same but apparently I'm wrong.
Starter relay does not get power when the key is turned to start. It will start and run fine when you jumper at the starter and the key is turned to run. Now the even funnier part. it starts with the brake pedal. When the key is on and you depress the brake it starts and runs fine...something must be different between the years regarding brake light and starter relay wiring.
The wiring diagrams in my chiltons manual aren't the best and aren't helping. I did find a pin readout of the firewall junction block but it looks like the start/run/brake pins are the same between the years. The 92 did have an alarm but I think all the wiring was in the dash harness, the engine harness I am using looks unmodified.
Any help would be appreciated. thanks.
