factory air 1969/dart w/340 #1748824
02/08/15 12:20 AM
02/08/15 12:20 AM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
I need to get all under hood components to complete my project. Did other models/years/or engines use the same set-up as the 69 dart. I have seen parts from other models/years/engines but I do not know if they would be compatible. Thanks for the help. Scott
Re: factory air 1969/dart w/340 [Re: IEAT4DS] #1748825
02/08/15 01:37 AM
02/08/15 01:37 AM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
340 a bodies had a single pulley clutch on the compressor , all other body styles had a double pulley.
Re: factory air 1969/dart w/340 [Re: formula_s] #1748826
02/08/15 02:24 AM
02/08/15 02:24 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Any 69 small block A-body AC parts will work. Other years in either direction may also work.
Re: factory air 1969/dart w/340 [Re: Jim_Lusk] #1748827
02/08/15 03:37 AM
02/08/15 03:37 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
67-69 small block A-body I believe.
70 small block will have different pulleys because of the aluminum waterpump.
Re: factory air 1969/dart w/340 [Re: autoxcuda] #1748828
02/08/15 01:10 PM
02/08/15 01:10 PM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Thanks a bunch. That will be helpful when seeking parts.
Re: factory air 1969/dart w/340 [Re: IEAT4DS] #1748829
02/08/15 01:36 PM
02/08/15 01:36 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
SOME of the parts will work. 273-318 engines have different length compressor struts as the 4-bbl intake is taller making the struts shorter. When I put a crate 360 with a factory 340 intake in my 68 Dart convertible that was originally a 318 A/C car I had to modify the struts. The original parts will work but modifications are needed. As said above 70-up parts are even more different.
JB Rhinehart, Realist
A-Body's RULE!
Re: factory air 1969/dart w/340 [Re: Rhinodart] #1748830
02/08/15 01:40 PM
02/08/15 01:40 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Pic 2
A-Body's RULE!
Re: factory air 1969/dart w/340 [Re: Rhinodart] #1748831
02/08/15 01:41 PM
02/08/15 01:41 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Pic 3
A-Body's RULE!
Re: factory air 1969/dart w/340 [Re: Rhinodart] #1748832
02/08/15 03:00 PM
02/08/15 03:00 PM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Hi Rhinodart,
Thank you so much for the pictures. Those will be very helpful. I have a service manual but it only has drawings of 273 and 225.
Re: factory air 1969/dart w/340 [Re: IEAT4DS] #1748833
02/09/15 02:51 AM
02/09/15 02:51 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
See the 340 engine assembly manual reprint here:
http://www.faxonautoliterature.com/1969-Dodge-Dart-Engine-Assembly-Manual-Reprint-P20360.aspx
Very nice to have - shows Mopar drawings of all the brackets and part numbers for A/C on a 340 plus more. I have the Plymouth version of the manual, which might be the same as Dodge. I think these drawings are a small part of what used to be available at Hamtramck Historical but were "seized" by Chrysler.
This manual has drawings of all the "engine dress", the stuff put on the engine at the assembly plant, such as throttle cable, accelerator pedal, carb, PVC, fuel pump, starter, engine and trans mounts, choke, fan drive, alternator, PS, A/C. The drawings don't show anything done at the engine plant.
PM me if you want a peek.
Re: factory air 1969/dart w/340 [Re: Rhinodart] #1748834
02/09/15 11:59 AM
02/09/15 11:59 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Scott:
Jim is a member that you are going to want to embrace on this endeavor! He probably has all the parts you are looking for as well.
I think you should drive the dart to his shop in Illinois and stop by my house on your way!!!!
Admiration For Multiple Carburetor Vehicles...
Re: factory air 1969/dart w/340 [Re: kentj340] #1748835
02/09/15 09:08 PM
02/09/15 09:08 PM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Thanks Kentj340, I will be ordering that resource.
Re: factory air 1969/dart w/340 [Re: IEAT4DS] #1748836
02/22/15 09:39 PM
02/22/15 09:39 PM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Still looking for parts. It seems 70 is a easier year to find parts for. I think I am going to hold out longer for 1969 a-body 340 parts. If anyone knows of any out there, let me know. Thank You, Scott
Re: factory air 1969/dart w/340 [Re: IEAT4DS] #1748837
02/22/15 09:44 PM
02/22/15 09:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Isn't 68 the same? Or does the pad around the vents make the 68 case and other stuff different enough not to bother with a '68?
The air vents are chrome on 69 and 68. But '68 has pad around it similar in idea to the bottom dash pads on 68 only dashes.
I think went black plastic in 70.
Re: factory air 1969/dart w/340 [Re: autoxcuda] #1748838
02/22/15 10:01 PM
02/22/15 10:01 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Found these pics of a of 69 Dart custom with 273 (originally 2bbl) car.
Re: factory air 1969/dart w/340 [Re: autoxcuda] #1748839
02/22/15 10:47 PM
02/22/15 10:47 PM
Minnesota
I
IEAT4DS Offline OP
IEAT4DS  Offline OP
I
Minnesota
Those are great pictures! Thank you
I have all the inside stuff.Heater box is all rebuilt too. It looks and works like new. The only thing I have under the hood is a water valve. It is the same valve you have in the photo's.
Re: factory air 1969/dart w/340 [Re: IEAT4DS] #1748840
02/23/15 02:47 AM
02/23/15 02:47 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My advice is to go to Carlisle, PA, July 10-12 for the Mopar Nationals. Friday and Saturday are the big days. You can find hundreds of vendors selling used parts. It's a parts picker's paradise.
