Re: factory air 1969/dart w/340
[Re: IEAT4DS]
#1748829
02/08/15 01:36 PM
02/08/15 01:36 PM
Posts: 43,590 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
SOME of the parts will work. 273-318 engines have different length compressor struts as the 4-bbl intake is taller making the struts shorter. When I put a crate 360 with a factory 340 intake in my 68 Dart convertible that was originally a 318 A/C car I had to modify the struts. The original parts will work but modifications are needed. As said above 70-up parts are even more different.
JB Rhinehart, Realist
A-Body's RULE!
[Re: IEAT4DS]
#1748833
02/09/15 02:51 AM
02/09/15 02:51 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
See the 340 engine assembly manual reprint here: http://www.faxonautoliterature.com/1969-Dodge-Dart-Engine-Assembly-Manual-Reprint-P20360.aspxVery nice to have - shows Mopar drawings of all the brackets and part numbers for A/C on a 340 plus more. I have the Plymouth version of the manual, which might be the same as Dodge. I think these drawings are a small part of what used to be available at Hamtramck Historical but were "seized" by Chrysler. This manual has drawings of all the "engine dress", the stuff put on the engine at the assembly plant, such as throttle cable, accelerator pedal, carb, PVC, fuel pump, starter, engine and trans mounts, choke, fan drive, alternator, PS, A/C. The drawings don't show anything done at the engine plant. PM me if you want a peek.
[Re: kentj340]
#1748835
02/09/15 09:08 PM
02/09/15 09:08 PM
Posts: 119 Minnesota
IEAT4DS
Minnesota
Thanks Kentj340, I will be ordering that resource.
[Re: IEAT4DS]
#1748840
02/23/15 02:47 AM
02/23/15 02:47 AM
kentj340
Cut and Shoot, TX
My advice is to go to Carlisle, PA, July 10-12 for the Mopar Nationals. Friday and Saturday are the big days. You can find hundreds of vendors selling used parts. It's a parts picker's paradise.
