SS front spring hangers #1748695
02/07/15 07:43 PM
02/07/15 07:43 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
How can one tell the year/body a set is for if there's no part# on them.
Re: SS front spring hangers [Re: 71GTX471] #1748696
02/07/15 08:16 PM
02/07/15 08:16 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
well that was difficult to read... but I'll go out on a limb and say that the said hangers will be 2" longer than the stock ones on your B body.
Re: SS front spring hangers [Re: J_BODY] #1748697
02/08/15 08:22 AM
02/08/15 08:22 AM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
I have 2 sets,set 1 measures 4 1/4 from the front of bracket to the center of hole set 2 measures 5 1/4,any one have dimensions or a known set that could be measured to help determine what year/body they could be for, the mopar perf. catalog shows 4 sets but is no help w/out part#.
Re: SS front spring hangers [Re: 71GTX471] #1748698
02/08/15 12:53 PM
02/08/15 12:53 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Superstock springs have a 20" front segment.
They fit A bodies and 62-63 B bodies.
Other cars with longer front spring hangers.
Re: SS front spring hangers [Re: GY3] #1748699
02/08/15 01:04 PM
02/08/15 01:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe he is looking for actual measurements from
the front mounting surface to the center line of the hole
for both the stock and long hangers.... yet I have
no idea what DAY they would fit.. I would guess just
on Monday and Friday... LOL
EDIT
It would also help if he would say what car he is
trying to put the SS springs on so someone could give
him both the front spring length and the proper hanger
length
Re: SS front spring hangers [Re: 71GTX471] #1748700
02/08/15 01:55 PM
02/08/15 01:55 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Let me reword it there's a guy selling a set & he don't know what day fit how can I tell what day fit.
What they fit? I had to read it a few times to know what you meant.
day = a 24 hour period
Re: SS front spring hangers [Re: 451Cuda] #1748701
02/08/15 01:57 PM
02/08/15 01:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think thats E-bonics... LOL
Re: SS front spring hangers [Re: MR_P_BODY] #1748702
02/08/15 10:57 PM
02/08/15 10:57 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Im not putting SS springs in any car just trying to find out what sets I have.
Re: SS front spring hangers [Re: 71GTX471] #1748703
02/09/15 12:25 AM
02/09/15 12:25 AM
Outside
thedriver Offline
thedriver  Offline
Outside
The amount of leafs in the springs should help determine what you have. Some have more, some less,
1973 challenger
Dana. 4 speed. Low deck.
Re: SS front spring hangers [Re: 71GTX471] #1748704
02/09/15 01:57 AM
02/09/15 01:57 AM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
the longer set is for a Dodge, they always had 1" longer wheelbase.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: SS front spring hangers [Re: 71GTX471] #1748705
02/09/15 04:30 PM
02/09/15 04:30 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
If I'm understanding the question the OP (i.e. 71GTX471) is trying to ask. He has two different sets of front spring hangers. He provides measurements of 4.25" & and 5.25". Without any part numbers, he is unsure what body they came off of or what springs the hangers may fit.
I believe his subject line regarding "SS front spring hangers" may be adding to the confusion of the post.
71GTX471, Can you provide the spacing / measurement of the 4 mounting bolt? Perhaps it will be easier to first determine the body (i.e. B/C or A/E) these fit. Are there two set of mounting holes for the spring? A picture would be helpful...
Also, check out the following link(s) which may give you a better idea regarding the number of different front hangers.
http://arengineering.com/home-page/spring-hangers/
http://www.manciniracing.com/maraspha.html
http://www.manciniracing.com/mopar8.html Are either set you your hangers squared-off like these SS hangers look?
Re: SS front spring hangers [Re: cruzin] #1748706
02/09/15 06:44 PM
02/09/15 06:44 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
The measurements on my MRE-0097 are 3.250" from mtg surface to hole center. The photo does not look like it's ligned up correctly, but it's an optical illusion. Below is a link to a good description on Mancini.
http://www.manciniracing.com/marasphaset5.html
Re: SS front spring hangers [Re: Tommy D] #1748707
02/09/15 09:25 PM
02/09/15 09:25 PM
N.Y.
sixpacksteve Offline
N.Y.
what tommyd has is correct. the measurement is 4.25" though.what will these if?
Hell Hath No Fury Like Mine
Re: SS front spring hangers [Re: Tommy D] #1748708
02/09/15 09:48 PM
02/09/15 09:48 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
OK to answer cruzin one set I have is missing the mounting studs & I can slip the other set right in to them & everything is identical side to side top to bottom,there are 2 spring eye bolt mounting holes.
TommyD I see your hangers are for 64/70 Dodge B 3 1/4 & if SS springs are 2" shorter then stock springs my 5 1/4 hangers should be for a 66/70 Dodge B using SS springs,and I think I read Dodge factory springs are 1" longer then Plymouth springs then my 4 1/4 hangers should be for 66/70 Ply. B using SS springs.does this make sense.
Re: SS front spring hangers [Re: 71GTX471] #1748709
02/10/15 11:20 AM
02/10/15 11:20 AM
Tommy D Offline
Tommy D  Offline
I can't comment on whether that is correct or not...simply stating what I have and the dimensions. T
Re: SS front spring hangers [Re: 71GTX471] #1748710
02/10/15 03:29 PM
02/10/15 03:29 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
71GTX471,
From your feedback, it sounds like these hangers were B-body and for use with SS springs. Your statement is nearly correct however, Super Stock / SS Springs are not "2 inches shorter than stock springs" but rather the front segment on SS springs are a fixed 20" long. IIRC, most non-SS springs, will have a front segments 20", 21" or 22" in length depending on the body.
As a result, of the SS spring having a 20" front segment, depending on the body, the front hangers may differ in length to accommodate the body they will be used on.
Hope this helps clarify.
Re: SS front spring hangers [Re: cruzin] #1748711
02/11/15 10:22 AM
02/11/15 10:22 AM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Well I guess the only definitive way of knowing would be to have measurements from the 4 SS front spring hangers sets available.This would be helpful when looking @ swap meets CL ETC ETC when the owner/seller does not know what body/year they are for.Maybe Mancini could provide the measurements.
Re: SS front spring hangers [Re: 71GTX471] #1748712
02/11/15 10:33 AM
02/11/15 10:33 AM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
A bodys used 20 inch fronts Bs used 22 after 66. 65 and 64 were 21. IIRC 62 63 which actually werent B bodys were 20s.The MP hangers wont work on a 64/65 b body.You have to redrill them to fit without mods.You need to use the ones Andy a member here makes.For an A body SS springs bolt right in.
Chrysler Firepower
Re: SS front spring hangers [Re: sixpacksteve] #1748713
02/11/15 03:28 PM
02/11/15 03:28 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
B/E-Body with SS springs(20" front segment)they should be 2" longer than stock.
