Re: SS front spring hangers
[Re: 71GTX471]
#1748698
02/08/15 12:53 PM
02/08/15 12:53 PM
Posts: 4,672 Wichita
GY3
Wichita
Superstock springs have a 20" front segment. They fit A bodies and 62-63 B bodies. Other cars with longer front spring hangers.
[Re: GY3]
#1748699
02/08/15 01:04 PM
02/08/15 01:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I believe he is looking for actual measurements from the front mounting surface to the center line of the hole for both the stock and long hangers.... yet I have no idea what DAY they would fit.. I would guess just on Monday and Friday... LOL EDIT It would also help if he would say what car he is trying to put the SS springs on so someone could give him both the front spring length and the proper hanger length
[Re: 71GTX471]
#1748700
02/08/15 01:55 PM
02/08/15 01:55 PM
Posts: 345 Nebraska
451Cuda
Nebraska
Let me reword it there's a guy selling a set & he don't know what day fit how can I tell what day fit.
What they fit? I had to read it a few times to know what you meant.
day = a 24 hour period
[Re: 451Cuda]
#1748701
02/08/15 01:57 PM
02/08/15 01:57 PM
MR_P_BODY
I think thats E-bonics... LOL
[Re: 71GTX471]
#1748703
02/09/15 12:25 AM
02/09/15 12:25 AM
Posts: 1,481 Outside
thedriver
Outside
The amount of leafs in the springs should help determine what you have. Some have more, some less,
1973 challenger Dana. 4 speed. Low deck.
[Re: 71GTX471]
#1748705
02/09/15 04:30 PM
02/09/15 04:30 PM
Posts: 1,142 Tucson, AZ
cruzin
Tucson, AZ
If I'm understanding the question the OP (i.e. 71GTX471) is trying to ask. He has two different sets of front spring hangers. He provides measurements of 4.25" & and 5.25". Without any part numbers, he is unsure what body they came off of or what springs the hangers may fit. I believe his subject line regarding "SS front spring hangers" may be adding to the confusion of the post. 71GTX471, Can you provide the spacing / measurement of the 4 mounting bolt? Perhaps it will be easier to first determine the body (i.e. B/C or A/E) these fit. Are there two set of mounting holes for the spring? A picture would be helpful... Also, check out the following link(s) which may give you a better idea regarding the number of different front hangers. http://arengineering.com/home-page/spring-hangers/http://www.manciniracing.com/maraspha.htmlhttp://www.manciniracing.com/mopar8.html Are either set you your hangers squared-off like these SS hangers look?
[Re: Tommy D]
#1748707
02/09/15 09:25 PM
02/09/15 09:25 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
what tommyd has is correct. the measurement is 4.25" though.what will these if?
Hell Hath No Fury Like Mine
[Re: 71GTX471]
#1748710
02/10/15 03:29 PM
02/10/15 03:29 PM
cruzin
Tucson, AZ
71GTX471,
From your feedback, it sounds like these hangers were B-body and for use with SS springs. Your statement is nearly correct however, Super Stock / SS Springs are not "2 inches shorter than stock springs" but rather the front segment on SS springs are a fixed 20" long. IIRC, most non-SS springs, will have a front segments 20", 21" or 22" in length depending on the body.
As a result, of the SS spring having a 20" front segment, depending on the body, the front hangers may differ in length to accommodate the body they will be used on.
Hope this helps clarify.
[Re: 71GTX471]
#1748712
02/11/15 10:33 AM
02/11/15 10:33 AM
Posts: 21,067 Niles , Ohio
therocks
Niles , Ohio
A bodys used 20 inch fronts Bs used 22 after 66. 65 and 64 were 21. IIRC 62 63 which actually werent B bodys were 20s.The MP hangers wont work on a 64/65 b body.You have to redrill them to fit without mods.You need to use the ones Andy a member here makes.For an A body SS springs bolt right in.
Chrysler Firepower
[Re: sixpacksteve]
#1748713
02/11/15 03:28 PM
02/11/15 03:28 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
B/E-Body with SS springs(20" front segment)they should be 2" longer than stock.
