Hot ballast resistor #1747722
02/06/15 03:38 AM
02/06/15 03:38 AM
FL
74-440Charger Offline OP
FL
Ballast resistor gets hot...proven hot enough to melt skin. What should this tell me (besides not to touch it)? Putting Electronic ignition in a 65 coronet, chrome ignition box, ballast resistor is 1.25 ohms. Thanks
Re: Hot ballast resistor [Re: 74-440Charger] #1747723
02/06/15 03:46 AM
02/06/15 03:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Ballast resistors(the Mopar ones) will burn you..
they get real hot
Re: Hot ballast resistor [Re: MR_P_BODY] #1747724
02/06/15 03:49 AM
02/06/15 03:49 AM
FL
FL
Thanks, guess I just never got ahold of one with power applied.
Re: Hot ballast resistor [Re: 74-440Charger] #1747725
02/06/15 03:52 AM
02/06/15 03:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats something you dont want to do... thats why they
are made in porcine
Re: Hot ballast resistor [Re: MR_P_BODY] #1747726
02/06/15 03:59 AM
02/06/15 03:59 AM
FL
FL
Won't let it happen again
Re: Hot ballast resistor [Re: 74-440Charger] #1747727
02/06/15 04:03 AM
02/06/15 04:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... hope it wasnt tooo bad... but I've been there
Re: Hot ballast resistor [Re: MR_P_BODY] #1747728
02/06/15 04:08 AM
02/06/15 04:08 AM
FL
FL
Hanging on to a cold beer, all is good
Re: Hot ballast resistor [Re: 74-440Charger] #1747729
02/06/15 11:23 AM
02/06/15 11:23 AM
Guitar Jones Offline
Also do not touch the positive primary terminal of an MSD Blaster 2 coil with an AL7 box with a wrench while grounding yourself to the vehicle while the engine is running. As I laid on the floor twitching I thought it was the last thing I would ever do before dying.
Fortunately I lived to nearly do the same thing to myself with a camera flash capacitor 2 weeks later.
Re: Hot ballast resistor [Re: Guitar Jones] #1747730
02/06/15 02:17 PM
02/06/15 02:17 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Amen!!
Re: Hot ballast resistor [Re: bonefish] #1747731
02/06/15 03:10 PM
02/06/15 03:10 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
before i bolt it to the fire wall i shim it out 1/8" at least to get some air movement behind it.
Re: Hot ballast resistor [Re: ademon] #1747732
02/06/15 03:53 PM
02/06/15 03:53 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Before I mount one , I come to my senses , buy an MSD and throw the resistor in the trash.
Re: Hot ballast resistor [Re: tubtar] #1747733
02/06/15 04:24 PM
02/06/15 04:24 PM
See my MSD warning above.
Re: Hot ballast resistor [Re: Guitar Jones] #1747734
02/06/15 08:21 PM
02/06/15 08:21 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
that will def learn you!.resistors get real hot and capacitors will knock you down.us old geezers remember the days of charging up distributor condensors and handing them to somebody....
SFI 25.5 depends,no leak,even at 213 mph....
Re: Hot ballast resistor [Re: tubtar] #1747735
02/06/15 08:52 PM
02/06/15 08:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: Hot ballast resistor [Re: dakotawilly] #1747736
02/07/15 12:25 AM
02/07/15 12:25 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That was how I invented break dancing back in 10th grade auto shop.
Re: Hot ballast resistor [Re: tubtar] #1747737
02/07/15 01:36 AM
02/07/15 01:36 AM
Cab_Burge Online work
Cab_Burge  Online Work
Was that break dancing or broken dancing A good freind of mine found out the hardway about MSD 7 ignitions being able to zap the crap out of him with the motor and igntion switch turned off, he had drank several after work hour beers and touch his arm onto one of the coil terminals with his hand touching the motor He fell, was knock off of, his open car trailer and broke a tooth on the steel channel on the side of the trailer where the tires ride on Be careful around any ignitions components, engine running or not
