Re: Hot ballast resistor
[Re: 74-440Charger]
#1747723
02/06/15 03:46 AM
02/06/15 03:46 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Ballast resistor gets hot...proven hot enough to melt skin. What should this tell me (besides not to touch it)? Putting Electronic ignition in a 65 coronet, chrome ignition box, ballast resistor is 1.25 ohms. Thanks
Ballast resistors(the Mopar ones) will burn you.. they get real hot
[Re: 74-440Charger]
#1747725
02/06/15 03:52 AM
02/06/15 03:52 AM
MR_P_BODY
Thanks, guess I just never got ahold of one with power applied.
Thats something you dont want to do... thats why they are made in porcine
[Re: 74-440Charger]
#1747727
02/06/15 04:03 AM
02/06/15 04:03 AM
MR_P_BODY
Won't let it happen again
LOL... hope it wasnt tooo bad... but I've been there
[Re: 74-440Charger]
#1747729
02/06/15 11:23 AM
02/06/15 11:23 AM
Guitar Jones
Also do not touch the positive primary terminal of an MSD Blaster 2 coil with an AL7 box with a wrench while grounding yourself to the vehicle while the engine is running. As I laid on the floor twitching I thought it was the last thing I would ever do before dying.
Fortunately I lived to nearly do the same thing to myself with a camera flash capacitor 2 weeks later.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1747730
02/06/15 02:17 PM
02/06/15 02:17 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Amen!!
[Re: tubtar]
#1747733
02/06/15 04:24 PM
02/06/15 04:24 PM
Guitar Jones
Before I mount one , I come to my senses , buy an MSD and throw the resistor in the trash.
See my MSD warning above.
[Re: tubtar]
#1747735
02/06/15 08:52 PM
02/06/15 08:52 PM
Quicktree
[Re: dakotawilly]
#1747736
02/07/15 12:25 AM
02/07/15 12:25 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
that will def learn you!.resistors get real hot and capacitors will knock you down.us old geezers remember the days of charging up distributor condensors and handing them to somebody....
That was how I invented break dancing back in 10th grade auto shop.
