Page 3 of 3 1 2 3
Re: blown hemi questions ?? [Re: His and Her 69's] #1747113
02/08/15 01:02 AM
02/08/15 01:02 AM
Oh
His and Her 69's Offline OP
Oh
Cab how do you determine a big bore case or a standard case ??
The case measurement from main case end to end is 15" and 19.80 total length. It does have the strips on the rotors so would having those cause higher temps also ??
Thanks, David
Re: blown hemi questions ?? [Re: His and Her 69's] #1747114
02/08/15 04:31 AM
02/08/15 04:31 AM
Cab_Burge Online work
Cab_Burge  Online Work
I can't tell you how to determine if it is a big bore or small bore case sorry. That one was a BDS and it had a serial number on it so I called BDS with that number and they told me it was a small bore case Strips can cause heat inside, I've melted one(strip) on a SB Chevy on the dyno several years back
Re: blown hemi questions ?? [Re: His and Her 69's] #1747115
02/08/15 07:14 AM
02/08/15 07:14 AM
SW WI
cudacustoms1 Offline
SW WI
It is the rotor dia that makes it a big/small bore. You can measure it at the top opening. I can't remember the thickness.
Re: blown hemi questions ?? [Re: cudacustoms1] #1747116
02/08/15 05:39 PM
02/08/15 05:39 PM
Antioch, CA
lucky13 Offline
lucky13  Offline
Antioch, CA
its 5.8 versus 5.525 diameter on the case openings for the rotors. Easy way to tell is if the case looks more like an hourglass its a big case, whereas the small case looks like a more open chamber. Hope that helps
www.racemagnum.com
1954 Plymouth Savoy 2 door
Re: blown hemi questions ?? [Re: lucky13] #1747117
02/09/15 05:49 AM
02/09/15 05:49 AM
Oh
Oh
Yes that Helps me guys.
I Appreciate the info and suggestions.
I will try and get out to the garage and get the measurements
or a photo in a day or so.
Thanks Guys.
David
Re: blown hemi questions ?? [Re: His and Her 69's] #1747118
02/09/15 05:51 AM
02/09/15 05:51 AM
Oh
Oh
Here is a back view of the blower.
(open the attachment to see the photo.)
Re: blown hemi questions ?? [Re: His and Her 69's] #1747119
02/09/15 05:54 AM
02/09/15 05:54 AM
Oh
Oh
Front view.
(Open attachment to see photo.)
Re: blown hemi questions ?? [Re: His and Her 69's] #1747120
02/09/15 04:32 PM
02/09/15 04:32 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I bought a 6-71 setup that was on a 440, and was going to build a wedge, but found a 426 block, new iron MP heads, stock bore, aftermarket crank that's stock stroke. Have a set of Arias pistons. I have aluminum rods, but no idea how many runs on them. Looking at some steel rods now. No one has mentioned the aluminum rods OP is planning to use also. Would like to hear some opinions.
Re: blown hemi questions ?? [Re: Bull1tt] #1747121
02/09/15 04:36 PM
02/09/15 04:36 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I am only looking for up to 700HP, max 1:1 on the blower. Strictly a street setup.
Re: blown hemi questions ?? [Re: Bull1tt] #1747122
02/09/15 06:40 PM
02/09/15 06:40 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Just curious, but why limit yourself to 1:1? I ran 11% over crank speed on the street, which equated to about 11 lbs. of boost, no problems.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: blown hemi questions ?? [Re: DusterDave] #1747123
02/09/15 07:09 PM
02/09/15 07:09 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Just don't want heat to become an issue with the 6-71
Re: blown hemi questions ?? [Re: Bull1tt] #1747124
02/09/15 09:14 PM
02/09/15 09:14 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I believe the holes in the sides of those pistons are for Nylon buttons.Not that anyone asked.
Re: blown hemi questions ?? [Re: Clanton] #1747125
02/09/15 09:19 PM
02/09/15 09:19 PM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Yes, those are nylon buttons, they look like holes in that pic.
Re: blown hemi questions ?? [Re: Bull1tt] #1747126
02/10/15 06:04 AM
02/10/15 06:04 AM
Oh
Oh
The reason I am using the aluminum rods is I have them, they have a lot of use left in them yet and I don't think eagle rods are adequate
for this combo.
There are no rods in between the quality/price range of eagle rods and the expensive GRP or other high quality expensive steel rods that I know of for a build like this. Is there any rods out there that I am not thinking of that fit in between these other 2 ??
I may want to get stupid a time or 2 and want good parts that will hold up to 850 or so HP.
I will order/get some Good pistons since I don't have any for a hemi.
I had a friend with a 355 chevy, iron heads, 671 blower, and 2 carbs make 830 HP. He then bought an injection hat for the engine but never redynoed it. It was a LOT more responsive, better 60', and faster ET so it was making more HP after the swap.
I have run aluminum rods in 2 different engines and I like them.
I don't put a lot of passes or miles on my stuff either.
David
Page 3 of 3 1 2 3
