Re: blown hemi questions ??
[Re: His and Her 69's]
#1747114
02/08/15 04:31 AM
02/08/15 04:31 AM
Posts: 43,185 Bend,OR USA
Cab_Burge
I can't tell you how to determine if it is a big bore or small bore case sorry. That one was a BDS and it had a serial number on it so I called BDS with that number and they told me it was a small bore case Strips can cause heat inside, I've melted one(strip) on a SB Chevy on the dyno several years back
[Re: cudacustoms1]
#1747116
02/08/15 05:39 PM
02/08/15 05:39 PM
Posts: 153 Antioch, CA
lucky13
Antioch, CA
It is the rotor dia that makes it a big/small bore. You can measure it at the top opening. I can't remember the thickness.
its 5.8 versus 5.525 diameter on the case openings for the rotors. Easy way to tell is if the case looks more like an hourglass its a big case, whereas the small case looks like a more open chamber. Hope that helps
#1747120
02/09/15 04:32 PM
02/09/15 04:32 PM
Posts: 1,606 Pgh, PA
Bull1tt
Pgh, PA
I bought a 6-71 setup that was on a 440, and was going to build a wedge, but found a 426 block, new iron MP heads, stock bore, aftermarket crank that's stock stroke. Have a set of Arias pistons. I have aluminum rods, but no idea how many runs on them. Looking at some steel rods now. No one has mentioned the aluminum rods OP is planning to use also. Would like to hear some opinions.
[Re: Bull1tt]
#1747124
02/09/15 09:14 PM
02/09/15 09:14 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I believe the holes in the sides of those pistons are for Nylon buttons.Not that anyone asked.
