Page 1 of 3 1 2 3
Help pick a cam Agan a lttle long #1746681
02/04/15 09:31 PM
02/04/15 09:31 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Hello all as we are still in the middle of winter around here I would like some feed back on a cam to use
car 71 demon 2977 with me in it
motor 440 .055 11.78 comp indy ez-1 heads 1050 with 2in adapter, 727 trans 8in conv 5400 stall 4.56 gears 31x14 tires ladder bar set-up
current cam 660 lift duration @ .050 282 adv 312 1.5 rockers.
choice of cams 1st 682 lift 267/274 duration 108 lsa
2nd cam 669 lift 272/280 duration on a 106 lsa
3rd cam 705/681 lift 27/278 duration on a 107 lsa
best times for the car is in my sig.....Thanks everyoe
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Help pick a cam Agan a lttle long [Re: 67mprfan] #1746682
02/04/15 09:37 PM
02/04/15 09:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are the heads ported and what rpm do you trap at now..
and are you happy with the rpm... do you want to go up
in rpm..which you will unless you change gear ratio
Re: Help pick a cam Agan a lttle long [Re: MR_P_BODY] #1746683
02/04/15 10:16 PM
02/04/15 10:16 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
yes they have been 346 on intake and 236 on exhaust or somewhere around there sheets in the basement...shift at 6500 rpm going thru traps about 6700 rpm
Re: Help pick a cam Agan a lttle long [Re: 67mprfan] #1746684
02/04/15 10:26 PM
02/04/15 10:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At what lift was the max flow... you want to exceed
that lift to utilize the max out of the head
Re: Help pick a cam Agan a lttle long [Re: MR_P_BODY] #1746685
02/04/15 10:35 PM
02/04/15 10:35 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I run a 'small roller' 620 lift, 272/276 @.050 been 10.20's 130mph with the crossram thru the exhaust. Put your intake and dominator on my motor probably easy 9's and car weighs 3300lbs. 4.30 gear 29.5 tires, little ez heads. The cam is from Indy R1, it's easy on the valve train.
Re: Help pick a cam Agan a lttle long [Re: MR_P_BODY] #1746686
02/04/15 10:39 PM
02/04/15 10:39 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
700 lift they were ported by Nick @ compu flo. my thinking is the current cams duration is a little high for my comp ratio even though it seems to be working good just trying to tweak it as much as possible....time in my sig is with good air
Re: Help pick a cam Agan a lttle long [Re: nss guy] #1746687
02/04/15 10:42 PM
02/04/15 10:42 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Jim I was told to leave it alone another cam won't help me but chasing that 9 sec time slip it hard for me not to touch it.
Re: Help pick a cam Agan a lttle long [Re: 67mprfan] #1746688
02/04/15 10:48 PM
02/04/15 10:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What's it 60 ft?
Why do you think you should change the cam?
Also, your #s just look odd to me... almost 4 mph faster in the 1/8th than me, yet only 2 mph faster in the 1/4, like you're running out of rpm or over geared.
Re: Help pick a cam Agan a lttle long [Re: BradH] #1746689
02/04/15 11:02 PM
02/04/15 11:02 PM
gregsdart Offline
gregsdart  Offline
What's it 60 ft?
I was going to ask the same question. If you raise the stall, It might wake it up or just be in the range the cam you have will work best. What is the LSA of the cam? Where do you have it installed? What are you shifting at now? 1.7 rockers on the intake may work well, but I have no experience with a setup like yours. I am assuming these are big port heads?
Re: Help pick a cam Agan a lttle long [Re: gregsdart] #1746690
02/04/15 11:16 PM
02/04/15 11:16 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
What's it 60 ft?
Just thinking duration is to high for my compression and to much overlap. Lsa is 106 now, tried different shift points made no difference. heads are indy ez-1 MW ports
Re: Help pick a cam Agan a lttle long [Re: 67mprfan] #1746691
02/04/15 11:48 PM
02/04/15 11:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What's it 60 ft?
You need more lift to utilize you flow.. but I would
talk to a few cam companies.. one of them would be
Bullit Cams.. they make some nice ones but they do
tend to be aggressive
Re: Help pick a cam Agan a lttle long [Re: BradH] #1746692
02/05/15 12:44 AM
02/05/15 12:44 AM
USA
B3RE Offline
B3RE  Offline
USA
What's it 60 ft?
Or, maybe it's the valvetrain. Was the valvetrain checked for proper geometry? A stock stroke 440 with 346 cfm heads and 282 @ .050 cam should be shifting higher than 6500 rpm. I think with a 31 x 14 slick and those engine specs, it would need more gear. I'd expect peak power to be more than 6500 rpm. It just needs to get there. That would explain the lower 1/4 mile mph.
That being said, it could benefit from more lift, and if the cam is being changed anyway, I'd go with a little less duration, and a higher ratio rocker.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Help pick a cam Agan a lttle long [Re: 67mprfan] #1746693
02/05/15 12:06 PM
02/05/15 12:06 PM
BradH Offline
BradH  Offline
After re-reading your info and seeing the combination is under 3000#s, I don't understand why it's not already well into the 9s. My junk ran 10.5s at 126 (6.6s at 101-102 in the 1/8th) at over 3700#s w/ a far more conservative combination.
I don't think you need a different cam; I think you need more cubic inches to make the rest of the combination you have work better.
EDIT: If you're "stuck" w/ changing only the cam, I'd say use the first cam in your list to see how much mid-range torque you can recover vs. that big-a$$ 'stick in there now.
Re: Help pick a cam Agan a lttle long [Re: 67mprfan] #1746694
02/05/15 12:20 PM
02/05/15 12:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With the cam you have.. whats the LSA on it and what
did you degree it in at(if you did)
Re: Help pick a cam Agan a lttle long [Re: 67mprfan] #1746695
02/05/15 12:27 PM
02/05/15 12:27 PM
gregsdart Offline
gregsdart  Offline
Those heads on a 451 will run best at a higher rpm by a bunch. You might be losing a lot to bad valve springs and lousy valve control. A motor like yours shouldn't quit making power till well into the 7,000 rpm range. If you have very good rockers and pushrods, put some good springs on it and get a cam that has somewhere around 276 to 280 duration, 108 or slightly higher LSA, and .700+ lift. Isky has a RR735 grind that looks good on paper for your application. It has 280/288/110 duration numbers, .735/.684 lift numbers.
I have run this cam in my 528 and it pulled power past 7200 with a single four. If you cut your heads for some serious compression, (13+) this cam ought to make serious power. Put a 6,000 plus stall converter in front of it, and hang on.
Re: Help pick a cam Agan a lttle long [Re: gregsdart] #1746696
02/05/15 01:13 PM
02/05/15 01:13 PM
USA
B3RE Offline
B3RE  Offline
USA
I think we are on the same page here Greg. Big cam with small cubes is going to need more rpm. I think it has valvetrain instability, which will weaken the springs prematurely. Could be a combination of both at this point. I do think a smaller duration cam would help the bottom end some and avoid more gear and maybe get away with his current converter to get that 9 sec slip. It all comes back to whether or not he can turn the needed rpm without the motor laying down.
Mike Beachel
Re: Help pick a cam Agan a lttle long [Re: 67mprfan] #1746697
02/05/15 02:14 PM
02/05/15 02:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You know my thoughts on this.............. I can get ya .2 more than likely according to how screwed up your carb is. My cam is 276-281 and has no issues idling or goin past 7000 BUT more cubes.
Re: Help pick a cam Agan a lttle long [Re: B3RE] #1746698
02/05/15 11:03 PM
02/05/15 11:03 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
First off let me say Thanks for everyone input
Now new springs are n the upgrade list but just trying to figure out this cam deal, so I can get the right ones. the conv is out and will be sending it to UCC for a refreshing and talk to Lenny about spec change. PLEASE don't beat me to bad on this one but rocker are crane gold 1.5s
Re: Help pick a cam Agan a lttle long [Re: 67mprfan] #1746699
02/06/15 12:32 AM
02/06/15 12:32 AM
gregsdart Offline
gregsdart  Offline
Hopefully you have time to research this deal, and figure out what is going to work best for you. Those Gold rockers aren't as stout as some rockers from what I here, and it may take some research to figure out a combo that is right for your deal. The right amount of spring, lobe profile and lift will all come into play. There are a number of guys on this board that have run those rockers, myself included. I didn't run enough spring or rpm to hurt mine though. Good luck with it, and keep us posted.
Re: Help pick a cam Agan a lttle long [Re: gregsdart] #1746700
02/06/15 12:51 AM
02/06/15 12:51 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Thanks Greg I been working on this combo for about 3 yrs now and I bought all these parts WAY b4 I knew what I was doing lol. truth be told the cam duration thing really has me confused some say I have too much some want it lower just don't know
Page 1 of 3 1 2 3
