What do you use to remove overspray from chrome ? #174636
12/25/08 11:05 AM
12/25/08 11:05 AM
Kentucky
mopar155 Offline OP
mopar155  Offline OP
Kentucky
I have a little overspray on my chrome exhaust tips- What have you used to remove the overspray without damaging your chrome finish ? I appreciate any responses, Thanks-Ron
1970 Plymouth Duster 1971 Dodge Challenger 2009 Dodge Challenger R/T 1970 Dodge Dart Swinger 340 4 Speed (Son's) 1985 Chevrolet Corvette (Wife's)
Re: What do you use to remove overspray from chrome ? [Re: mopar155] #174637
12/25/08 11:13 AM
12/25/08 11:13 AM
Conway, SC
T2R9 Online confused
T2R9  Online Confused
Conway, SC
Turtle wax chrome polish and a little elbow grease has always worked for me.
Re: What do you use to remove overspray from chrome ? [Re: T2R9] #174638
12/25/08 11:19 AM
12/25/08 11:19 AM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
Just wipe it off with some lacquer thinner wont hurt the chrome.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: What do you use to remove overspray from chrome ? [Re: mopar155] #174639
12/25/08 11:20 AM
12/25/08 11:20 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
super fine steel wool and some chrome polish.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: What do you use to remove overspray from chrome ? [Re: 69superbee383] #174640
12/25/08 11:20 AM
12/25/08 11:20 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: What do you use to remove overspray from chrome ? [Re: mopar155] #174641
12/25/08 11:31 AM
12/25/08 11:31 AM
Jacksonville Florida
elitecustombody Offline
clay bar is the first choice,second is lacquer thinner,third is very fine steel wool
Re: What do you use to remove overspray from chrome ? [Re: Challenger 1] #174642
12/25/08 11:58 AM
12/25/08 11:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: What do you use to remove overspray from chrome ? [Re: mopar155] #174643
12/25/08 09:55 PM
12/25/08 09:55 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
OO or OOO steel wool soaked with laquer thinner.
Re: What do you use to remove overspray from chrome ? [Re: Quikshft] #174644
12/28/08 06:07 PM
12/28/08 06:07 PM
Eau Claire, WI
ResQ911 Offline
super gas
ResQ911  Offline
super gas
Eau Claire, WI
Re: What do you use to remove overspray from chrome ? [Re: ResQ911] #174645
12/28/08 06:09 PM
12/28/08 06:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Brake clean. Spray it on and wipe it off.
Re: What do you use to remove overspray from chrome ? [Re: GoodysGotaCuda] #174646
12/28/08 06:26 PM
12/28/08 06:26 PM
Kirkland, Washington
Pacnorthcuda Offline
ANYTHING abrasive (including ANY polish or 0000 steel wool) should be an absolute LAST resort on a good chrome finish.
If you have true show quality chrome it WILL leave minute scratches in the right light. DAMHIK.
I would use chemicals first.
Now if the chrome isn't perfect to begin with then polish away!
Re: What do you use to remove overspray from chrome ? [Re: Pacnorthcuda] #174647
12/28/08 08:15 PM
12/28/08 08:15 PM
NC USA
71mopardude Offline
I don't get it?
71mopardude  Offline
I don't get it?
NC USA
neverdull chrome cleaner!!!!!!!!
Re: What do you use to remove overspray from chrome ? [Re: 71mopardude] #174648
12/28/08 08:45 PM
12/28/08 08:45 PM
IN
ahy Offline
ahy  Offline
IN
If lacquer thinner won't do it, paint remover will. It won't hurt the crome. If you're working around the new paint, a little bit on a rag wrapped around a finger of a gloved hand will give the best chance of avoiding hurting the new finish. The same caution applies to lacquer thinner around new paint also.
Re: What do you use to remove overspray from chrome ? [Re: ahy] #174649
12/28/08 08:49 PM
12/28/08 08:49 PM
Fredericktown, PA 15333
maundmotorworks Offline
Stealth poster
Stealth poster
You never use steel wool on chrome!!! In such cases where I have overspray or yellow rust, instead of steel wool, get a piece of aluminum foil from the kitchen and fold it into a small square. Apply lacquer thinner or chrome polish to the square and scrub your chrome with it. The aluminum foil is stiffer than a rag, but softer than steel so it won't scratch. I've made some really ragged out chrome look good again with that trick..
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
Re: What do you use to remove overspray from chrome ? [Re: maundmotorworks] #174650
12/28/08 09:17 PM
12/28/08 09:17 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Acetone or if it's just a small spot and only need a little, wifey's nail polish remover(most are acetone based)
Re: What do you use to remove overspray from chrome ? [Re: rrunner] #174651
12/28/08 11:31 PM
12/28/08 11:31 PM
Houma, Louisiana
twister360 Offline
twister360  Offline
Houma, Louisiana
How about a clay bar? Works great on painted surfaces.
My car 74 Duster mild 360/904/3.91 13.44/101.54 Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408 2004 Dodge Ram 1500 Laramie 5.7 2010 Dodge Challenger R/T Classic B-5 6 speed 2010 Jeep SRT8 for the little wife
Re: What do you use to remove overspray from chrome ? [Re: twister360] #174652
12/29/08 06:44 AM
12/29/08 06:44 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I have heard about Coca Cola and a ball of aluminum foil....whether that holds water or not is completely up to you to find out....
I usually just use the thinner of the paint chemicals you used.....like if it was PPG I'd Use DT870 to clean up...
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: What do you use to remove overspray from chrome ? [Re: mopar155] #174653
12/29/08 04:53 PM
12/29/08 04:53 PM
US of A
A38s! Offline
A38s!  Offline
US of A
Oven cleaner.
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: What do you use to remove overspray from chrome ? [Re: A38s!] #174654
12/29/08 05:30 PM
12/29/08 05:30 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
I'd be leery about using oven cleaner. I tried using it to get paint off my brake lines, and ended up removing the plating.
