22" radiator enough for A body stroker?? #1745831
02/03/15 08:53 PM
02/03/15 08:53 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
I have a the original 22" 3 core max cooling radiator for my 71 demon, but I'm wondering when I go to a 426" or so, 500HP is this going to keep it cool or do I have it recored with more fins per inch? What have you seen with your strokers and 22" radiators? I don't want to cut it up for a 26". Thanks
Re: 22" radiator enough for A body stroker?? [Re: ademon] #1745832
02/03/15 09:40 PM
02/03/15 09:40 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Would think you could try it out, as is, and see what happens. If you were living in Phoenix Arizona and had Air Conditioning and towing a trailer the answer might be different.
All else equal, it would be nice to swap in a 26-inch radiator, but I can understand your not wanting to cut a larger hole in your radiator support.
Some things to consider.... Do you have enough airflow generated by your cooling fan? If you have an automatic transmission, do you have a separate transmission oil cooler? Will you have a larger capacity engine oil pan? That should help too. Also, do you or will you have a well designed radiator shroud?
A 4-core radiator might help too. Greater capacity, yet some argue that efficiency decreases as you go from 3 to 4 core thickness.
Some advocate Aluminum versus original Brass radiator construction as being more efficient as well.
Re: 22" radiator enough for A body stroker?? [Re: ademon] #1745833
02/03/15 09:43 PM
02/03/15 09:43 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
My 440-6 is a factory 22" rad car. it is currently running around 450hp with no issues though I did recore it with a high performance 3 row "dimpled" core.
...personally, I'd do quite a bit as far as core upgrades before I'd hack my rad support.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 22" radiator enough for A body stroker?? [Re: DPelletier] #1745834
02/03/15 09:53 PM
02/03/15 09:53 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
It comes down to how often you will be at full power. The 22 should be fine for daily use and some strip use. If your going endurance racing you need much more.
Burning fuel makes the heat...
Re: 22" radiator enough for A body stroker?? [Re: ruderunner] #1745835
02/03/15 11:42 PM
02/03/15 11:42 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
I had a 69 Chrysler 300, factory HP440 with the trailer towing package it had a 3 row 22 inch radiator, 3.23 rear gears, it was a workhorse.
Re: 22" radiator enough for A body stroker?? [Re: ademon] #1745836
02/04/15 12:12 AM
02/04/15 12:12 AM
wv
Dartcuda Offline
Dartcuda  Offline
wv
Might want to face facts and realize you are going to need a 3 or 4 core aluminum if you want to stay 22". You could always paint it black for the stock look.
Re: 22" radiator enough for A body stroker?? [Re: Dartcuda] #1745837
02/04/15 12:41 AM
02/04/15 12:41 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
It has been proven that aluminum does not cool any better than brass. Those who would have you believe that want to sell you a radiator. The only thing aluminum does better is to reduce weight. Call Glen-Ray Radiator and talk with Bob, he will tell you what you will need.
JB Rhinehart, Realist
A-Body's RULE!
Re: 22" radiator enough for A body stroker?? [Re: Rhinodart] #1745838
02/04/15 12:58 AM
02/04/15 12:58 AM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I run my stock 22" radiator in my 69 Road Runner with a 470 stroker. I had the radiator re-cored at my local radiator shop with standard replacement material. I run an electric fan that really is not rated at a high enough cfm for my set up. Most of the time in the heat my car runs right around 200 degrees or a touch below. In close to 100 degree heat driving in stop and go traffic the temp will get to 208 tops. My car makes 425hp and 520 ft lbs.
Re: 22" radiator enough for A body stroker?? [Re: ruderunner] #1745839
02/04/15 02:30 AM
02/04/15 02:30 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
When I'm out at Willow Springs running lap after lap I don't have any cooling issues. There is so much airflow it cools well.
But if it's 95 degrees out and I'm stuck in a LA traffic jam moving 1/4 miles in 15 mins, it will get up to 190.
I have a champion 4 core, with shroud and viscous jag clutch. I don't run anti freeze though, just Justice Brothers Radiator Cool Additive and distilled water.
Re: 22" radiator enough for A body stroker?? [Re: autoxcuda] #1745840
02/04/15 02:38 AM
02/04/15 02:38 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I have pretty much that exact car, 422 stroker, 530HP, stock 22.00 radiator restored/recored by Glen-Ray to max cooling specs, stock shroud and fan, works fine in all conditions (and I don't baby it!).
Re: 22" radiator enough for A body stroker?? [Re: ScottSmith_Harms] #1745841
02/04/15 05:23 AM
02/04/15 05:23 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
By Max Cooling Specs, do you mean tighter fin count.
I think Troy did that with a tighter fin count in his 472 Hemi Dart stroker with a stock 67-69 A-body radiator. He's not running a shroud and runs an OE viscous fan clutch. He doesn't have any issues. Hemi hood scoop might help cooling?
Re: 22" radiator enough for A body stroker?? [Re: autoxcuda] #1745842
02/04/15 11:45 AM
02/04/15 11:45 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Not tighter fin count, just his standard modern day replacement style (which looks very original but is roughly 20% more efficient than stock) and 3 cores thick.
Re: 22" radiator enough for A body stroker?? [Re: autoxcuda] #1745843
02/04/15 12:35 PM
02/04/15 12:35 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Maybe max cooling was the wrong word, I have the "976" radiator, it's a stock three core 22" that was found in some 71 340's.
Re: 22" radiator enough for A body stroker?? [Re: ademon] #1745844
02/04/15 12:46 PM
02/04/15 12:46 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Mine is also a 976, just checked, its a 3 core.
Re: 22" radiator enough for A body stroker?? [Re: ademon] #1745845
02/04/15 12:48 PM
02/04/15 12:48 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
I have the P/S cooler, so maybe a max cooling package?
Re: 22" radiator enough for A body stroker?? [Re: ademon] #1745846
02/04/15 02:07 PM
02/04/15 02:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There is only one CORE in any radiator.
That CORE might have one, two, three or four ROWS of tubes in it though.
That all being said what you need to concern yourself about is HP, the radiator does not care if you have a turbo 2.0L, a stroked 360 or a 440 all putting out 500hp, all it cares about is heat and that is a function of HP.
Don't be the exception.
Re: 22" radiator enough for A body stroker?? [Re: Rhinodart] #1745847
02/04/15 03:03 PM
02/04/15 03:03 PM
DPelletier Offline
DPelletier  Offline
I basically have the same setup Scott has and it works just fine. Honestly this whole 22" vs. 26" thing is a Mopar only concept; in brand X land the rads are the same size and differ in the number of rows. I'd bet that my recored 3 row 22" cools better than a factory 26" 2 row....and I didn't have to cut my rad support on my #'s six pack car, nor do I have to use an aluminum rad that looks completely out of place.
Re: 22" radiator enough for A body stroker?? [Re: Supercuda] #1745848
02/04/15 05:11 PM
02/04/15 05:11 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Supercuda, semantics aside, mine is a 3 row
Re: 22" radiator enough for A body stroker?? [Re: ademon] #1745849
02/05/15 03:40 AM
02/05/15 03:40 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
No shortage of good answers so I'll just add my anecdotal experience. I first successfully ran a 22" copper 3 row and shroud with my 440. When I added the blower, for space reasons, I switched to a 22" aluminum 2 row and single pusher fan. It runs cooler than the copper unit.
Re: 22" radiator enough for A body stroker?? [Re: 70Duster440] #1745850
02/05/15 01:31 PM
02/05/15 01:31 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Thanks for the info!
