Re: raised cam block???
[Re: camastomcat]
#1744867
02/02/15 05:16 PM
02/02/15 05:16 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Belt drive or KB Gear drive I believe are the only option for cam timing and they are proud of both.
[Re: MR_P_BODY]
#1744870
02/02/15 08:34 PM
02/02/15 08:34 PM
Posts: 1,404 Chesterfield Twp. Mi.
John Burdine
So John.. are you going with that much stroke where you need a raised cam block
Maybe not, I just want to think things thru before I pull the trigger on a KB. either a 4.625 which I gather is no problem with Oliver rods, or maybe a 4.750, which sounds hit or miss with steel rods.
[Re: John Burdine]
#1744871
02/02/15 08:40 PM
02/02/15 08:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
.. sounds like your building a biggie
[Re: John Burdine]
#1744872
02/02/15 08:44 PM
02/02/15 08:44 PM
Al_Alguire
Las Vegas
4.75 and Olivers clear in mine with no issues.
[Re: Al_Alguire]
#1744873
02/02/15 08:59 PM
02/02/15 08:59 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
If you're talking about your predator deal, it's a raised cam right? Tony had to do some very light touch up with the 55mm cam we used. Personally, I wouldn't go 4.75 again unless it was a predator or like flow head, there's no need.
[Re: camastomcat]
#1744875
02/02/15 09:03 PM
02/02/15 09:03 PM
John Burdine
he had to do some touch up in a raised cam block?
[Re: John Burdine]
#1744876
02/02/15 11:12 PM
02/02/15 11:12 PM
Al_Alguire
Las Vegas
Mine is a raised cam deal, with a Jesel and 60MM bumpstick. Sorry I did not make that clear. Honestly if I do another predator I think we may go less stroke max bore the block can take and as much RPM as we can to make power.
[Re: bigtimeauto]
#1744881
02/03/15 02:09 AM
02/03/15 02:09 AM
Al_Alguire
Las Vegas
IF I do another one that is exactly what we will do. Much smaller cube much high RPM deal. I wanted to try one of the "big" Mopar motors but cannot say I am sold yet. Then again MAYBE I need to look into a procharger
[Re: bigtimeauto]
#1744883
02/03/15 01:13 PM
02/03/15 01:13 PM
Al_Alguire
Las Vegas
Oh I know I am low deck guy for sure. I have Indy heads too, just don't tell anyone. TO be honest this was not my idea originally to go big. I have been coerced into building a big mill, and have been skeptical from day one. My B1 is a low deck and does quite well and the 99 was a really short deck. Just wish I could have a bigger bore but being a Mopar it is what it is. I aint afraid of no RPM Looks like the boy and I will be ordering up a couple of KB blocks this year...
[Re: bigtimeauto]
#1744884
02/03/15 01:18 PM
02/03/15 01:18 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
You can really make some power with the short deck stuff.(and I'm using those junk indy heads) those long stroke tall deck engines are heavy and waste power. nothing better than short pushrods, a great line of site to the port and light weight. I'll take RPM power any day over low rpm.
You won't ever be right again if you go blower, especially with the heads you have!
Guess I have a power waster with my raised deck over squared combo...shift at 7800rpm and my engine builder says to go higher as were still making over 1000hp N/A at 8200rpm
[Re: Gary Robbins]
#1744885
02/03/15 01:23 PM
02/03/15 01:23 PM
Al_Alguire
Las Vegas
I will see soon enough I suppose. We have had to make a lot of changes to my stuff to make everyone happy. It should hit the dyno in the next couple months and will surely let everyone know what it makes.
[Re: Gary Robbins]
#1744886
02/03/15 01:43 PM
02/03/15 01:43 PM
Posts: 3,441 Mo.
supercomp
Mo.
I that a SELF 2 piece intake?
