raised cam block??? #1744865
02/02/15 02:08 PM
02/02/15 02:08 PM
Chesterfield Twp. Mi.
John Burdine Offline OP
are their any cons to a .250 raised cam block such as, lifter/push rod angle or anything I'm not aware of?
Re: raised cam block??? [Re: John Burdine] #1744866
02/02/15 05:14 PM
02/02/15 05:14 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Lifter angle usually changes from 45 to 48 degree or vice versa, pushrods are a bit shorter, need a belt drive for raised cam
Re: raised cam block??? [Re: camastomcat] #1744867
02/02/15 05:16 PM
02/02/15 05:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Belt drive or KB Gear drive I believe are the only option for cam timing and they are proud of both.
Re: raised cam block??? [Re: Al_Alguire] #1744868
02/02/15 06:27 PM
02/02/15 06:27 PM
I think the Jesel for raised cam is $300 more.
Re: raised cam block??? [Re: John Burdine] #1744869
02/02/15 06:35 PM
02/02/15 06:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
So John.. are you going with that much stroke where
you need a raised cam block
Re: raised cam block??? [Re: MR_P_BODY] #1744870
02/02/15 08:34 PM
02/02/15 08:34 PM
Maybe not, I just want to think things thru before I pull the trigger on a KB.
either a 4.625 which I gather is no problem with Oliver rods, or maybe a 4.750, which sounds hit or miss with steel rods.
Re: raised cam block??? [Re: John Burdine] #1744871
02/02/15 08:40 PM
02/02/15 08:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
.. sounds like your building a biggie
Re: raised cam block??? [Re: John Burdine] #1744872
02/02/15 08:44 PM
02/02/15 08:44 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
4.75 and Olivers clear in mine with no issues.
Re: raised cam block??? [Re: Al_Alguire] #1744873
02/02/15 08:59 PM
02/02/15 08:59 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
If you're talking about your predator deal, it's a raised cam right? Tony had to do some very light touch up with the 55mm cam we used. Personally, I wouldn't go 4.75 again unless it was a predator or like flow head, there's no need.
Re: raised cam block??? [Re: Al_Alguire] #1744874
02/02/15 09:02 PM
02/02/15 09:02 PM
AL, that is a standard cam block/Predator deal?
Re: raised cam block??? [Re: camastomcat] #1744875
02/02/15 09:03 PM
02/02/15 09:03 PM
he had to do some touch up in a raised cam block?
Re: raised cam block??? [Re: John Burdine] #1744876
02/02/15 11:12 PM
02/02/15 11:12 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Mine is a raised cam deal, with a Jesel and 60MM bumpstick. Sorry I did not make that clear. Honestly if I do another predator I think we may go less stroke max bore the block can take and as much RPM as we can to make power.
Re: raised cam block??? [Re: John Burdine] #1744877
02/02/15 11:46 PM
02/02/15 11:46 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Non raised cam, oliver 2.200"rods,4.750"stroke 55mm cam with .540" lobe lift (1.028" at the valve )only a very small amount of materal needed to be removed from rods 1-3-5-7 to achive .060" cam to rod clearnce.....
Re: raised cam block??? [Re: boatracer572] #1744878
02/03/15 12:55 AM
02/03/15 12:55 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
4.75 stroke in a standard block is very doable with 2.2 pins. Dave
Re: raised cam block??? [Re: John Burdine] #1744879
02/03/15 01:28 AM
02/03/15 01:28 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Ditto on the only con, at least when I built mine, being lack of a timing chain option so need to go with a belt drive or timing gears. I'd go with the timing belt in any case. Much less resonating in the valve train (= durability) and it's nice to be able to phase the cam without removing it! Mine picked up 20+hp by retarding the cam a couple degrees on the dyno. Based on the low exhaust temps - we expect it would have picked up more by turning it back more if we had confidence in the piston to valve clearance :} My understanding is you can go with a much longer stroke crank too with the raised cam block. Good luck with your project!
Re: raised cam block??? [Re: Al_Alguire] #1744880
02/03/15 02:04 AM
02/03/15 02:04 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
that cam height and diameter work great on shortdecks with short strokes to!
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: raised cam block??? [Re: bigtimeauto] #1744881
02/03/15 02:09 AM
02/03/15 02:09 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IF I do another one that is exactly what we will do. Much smaller cube much high RPM deal. I wanted to try one of the "big" Mopar motors but cannot say I am sold yet.
Then again MAYBE I need to look into a procharger
Re: raised cam block??? [Re: Al_Alguire] #1744882
02/03/15 02:49 AM
02/03/15 02:49 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
You can really make some power with the short deck stuff.(and I'm using those junk indy heads) those long stroke tall deck engines are heavy and waste power. nothing better than short pushrods, a great line of site to the port and light weight. I'll take RPM power any day over low rpm.
You won't ever be right again if you go blower, especially with the heads you have!
Re: raised cam block??? [Re: bigtimeauto] #1744883
02/03/15 01:13 PM
02/03/15 01:13 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Oh I know I am low deck guy for sure. I have Indy heads too, just don't tell anyone. TO be honest this was not my idea originally to go big. I have been coerced into building a big mill, and have been skeptical from day one. My B1 is a low deck and does quite well and the 99 was a really short deck. Just wish I could have a bigger bore but being a Mopar it is what it is. I aint afraid of no RPM
Looks like the boy and I will be ordering up a couple of KB blocks this year...
Re: raised cam block??? [Re: bigtimeauto] #1744884
02/03/15 01:18 PM
02/03/15 01:18 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
Guess I have a power waster with my raised deck over squared combo...shift at 7800rpm and my engine builder says to go higher as were still making over 1000hp N/A at 8200rpm
