W2's and Fron engine plates...pics please #1744087
02/01/15 05:29 PM
02/01/15 05:29 PM
British Columbia
toddd Offline OP
toddd  Offline OP
British Columbia
Can some guys with W2's and engine plates post some pics please.
I bought a motor with W2's and need to get some ideas.
Thanks.
Todd
Re: W2's and Fron engine plates...pics please [Re: toddd] #1744088
02/01/15 05:35 PM
02/01/15 05:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks.
Todd
The SB all mounts the same.. behind the water pump..
this is my W-5 but you will get the idea
Re: W2's and Fron engine plates...pics please [Re: MR_P_BODY] #1744089
02/01/15 05:37 PM
02/01/15 05:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In the car
Re: W2's and Fron engine plates...pics please [Re: MR_P_BODY] #1744090
02/01/15 05:46 PM
02/01/15 05:46 PM
British Columbia
toddd Offline OP
toddd  Offline OP
British Columbia
I just started to "mock " mine up, and was afraid the water pump bolts wouldn't be strong enough.
I have 1 bolt on the RH side and 2 on the LH side.
I also have a mid mount.
Thanks Mr P.
Re: W2's and Fron engine plates...pics please [Re: toddd] #1744091
02/01/15 05:53 PM
02/01/15 05:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a mid plate also.... .090 thick steel that mounts
between the trans and block... dont let that go into
the starter area.. that would give a larger space
between the starter gear and the ring on the conv
Re: W2's and Fron engine plates...pics please [Re: toddd] #1744092
02/01/15 07:22 PM
02/01/15 07:22 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I really like my engine plate from AR Engineering Andy has been making some cool small block stuff lately too.
Here's a link to the motor plates http://arengineering.com/products/small-block-a-body/
Gus
64 Plymouth Savoy
Dana 60
Re: W2's and Fron engine plates...pics please [Re: toddd] #1744093
02/01/15 07:43 PM
02/01/15 07:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks Mr P.
I forgot.... I use 3/8" 6061 T6 alum plate for the
front mounting plate... I wouldnt go thinner.. JMO
but I have bent 5/16" coming down from big wheel stand
because that plate is a structural member of the chassis
Re: W2's and Fron engine plates...pics please [Re: MR_P_BODY] #1744094
02/04/15 02:28 AM
02/04/15 02:28 AM
British Columbia
toddd Offline OP
toddd  Offline OP
British Columbia
Thanks for the info.
Looks like more changes than I thought.
It's all good.
Re: W2's and Fron engine plates...pics please [Re: MR_P_BODY] #1744095
02/04/15 02:41 AM
02/04/15 02:41 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Thanks Mr P.
Mike when do you know that you need a middle plate or do you need one at all or what's the deal with it please school me
Re: W2's and Fron engine plates...pics please [Re: RAY1969CARS] #1744096
02/04/15 12:36 PM
02/04/15 12:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks Mr P.
I run tube chassis cars so the front and mid plates
help stiffen the chassis... a lot of people run a front
plate but not a mid
