Need fast questions answered on Hotchkis Subs install!! #1744021
02/01/15 05:08 PM
02/01/15 05:08 PM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
I am in the middle of my install for my Hotchkis Subframe connectors on my 1968 Dodge Charger. What side is what??? The instructions have a view showing the "Drivers Side" But I am able to re-create that view with either side connector by simply flipping it over. Is this view from the top?? Or the bottom??
Does the flange that bolts to the spring hanger default to the outside of the car, leaving the connector more inboard?? If I do this, it fits nice, but the stickers are then visible on the inboard side of the connector. All the pictures I see shows the "Hotchkis" sticker visible to the outside of the car when installed.
Ready to tack weld in, just stuck at this point in the install.
Thanks!
Re: Need fast questions answered on Hotchkis Subs install!! [Re: redmist] #1744022
02/01/15 10:15 PM
02/01/15 10:15 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
If every thing is good, the front part of the connector should align with the "T" of the front subframe where the front frame rails are welded to the Torsion Bar crossmember. Sticker "SHOULD" be to the outside, but production has shifted from the west coast to the east coast and we've seen our fair share of upside-down and backwards sticker placement. I'll see if I can get you a pic as well.
Re: Need fast questions answered on Hotchkis Subs install!! [Re: Dan@Hotchkis] #1744023
02/01/15 10:21 PM
02/01/15 10:21 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
That is what happens when you farm out production of parts...
Quality stays at home...
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Need fast questions answered on Hotchkis Subs install!! [Re: Dan@Hotchkis] #1744024
02/01/15 10:21 PM
02/01/15 10:21 PM
It's a bit zoomed out, but you can see the alignment of the connectors.
Re: Need fast questions answered on Hotchkis Subs install!! [Re: amxautox] #1744025
02/01/15 10:23 PM
02/01/15 10:23 PM
It's still at home. We moved production from Hotchkis Performance in Santa Fe Springs, CA to our new East Coast Facility Hotchkis Performance East in Moorseville, NC.
Re: Need fast questions answered on Hotchkis Subs install!! [Re: Dan@Hotchkis] #1744026
02/01/15 10:26 PM
02/01/15 10:26 PM
Re: Need fast questions answered on Hotchkis Subs install!! [Re: Dan@Hotchkis] #1744027
02/01/15 10:34 PM
02/01/15 10:34 PM
amxautox Offline
amxautox  Offline
Ya, but when the local company opened a new plant in Georgia they had lots of quality problems.
Tom
author unknown
Re: Need fast questions answered on Hotchkis Subs install!! [Re: amxautox] #1744028
02/02/15 02:00 AM
02/02/15 02:00 AM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
I went with Flange out, stickers in... they mounted more in line with the front frame rails, and the seat holes lined up better.
It's stickers in, so now I will have to tell everyone I have them Instead of just letting people notice.
Sorta like all the crossfit people do!
Re: Need fast questions answered on Hotchkis Subs install!! [Re: redmist] #1744029
02/02/15 02:48 AM
02/02/15 02:48 AM
Thanks for the heads up. Can you tell me the assembly date on the label that has the part number on it? I'll pass an e-mail along to the production manager.
Re: Need fast questions answered on Hotchkis Subs install!! [Re: Dan@Hotchkis] #1744030
02/03/15 02:02 AM
02/03/15 02:02 AM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
1/28/2014
Re: Need fast questions answered on Hotchkis Subs install!! [Re: redmist] #1744031
02/03/15 04:47 AM
02/03/15 04:47 AM
Thank you Sir!
Re: Need fast questions answered on Hotchkis Subs install!! [Re: Dan@Hotchkis] #1744032
02/04/15 12:31 AM
02/04/15 12:31 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Any pics of these installed on a b body? A side view also to see how low they hang. Thanks!!
Re: Need fast questions answered on Hotchkis Subs install!! [Re: 68KillerBee] #1744033
02/04/15 12:40 AM
02/04/15 12:40 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Found a decent pic. Now I just have to make sure my cutouts don't interfere with these...
[image]http://[/image]
Re: Need fast questions answered on Hotchkis Subs install!! [Re: 68KillerBee] #1744034
02/04/15 03:47 AM
02/04/15 03:47 AM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
I have cutouts on my car. They would be sorta blasting the bars, but I have room for a turndown if I wanted. I will post a pic here.
Re: Need fast questions answered on Hotchkis Subs install!! [Re: 68KillerBee] #1744035
02/04/15 01:59 PM
02/04/15 01:59 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Hey, that's my car. Always liked that pic.
We had an issue when we installed those a few years back. The flange that bolts to the leaf spring side was upside down. The bolt pattern differed slightly top to bottom. So we cut, flipped and re-welded. Extra work, but I still think they are best for the common guy.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
