Aftermarket Valve Covers on an RB #1743726
02/01/15 07:16 AM
02/01/15 07:16 AM
Iowa
76dodgeboy Offline OP
Iowa
Anyone Have pics of the 440 equipped truck with Aftermarket Valve covers and what you had to do if Anything to get them to clear? Specifically Aluminum! Thanks
Re: Aftermarket Valve Covers on an RB [Re: 76dodgeboy] #1743727
02/01/15 07:19 AM
02/01/15 07:19 AM
Iowa
Iowa
Sorry in a 72-78 truck
Re: Aftermarket Valve Covers on an RB [Re: 76dodgeboy] #1743728
02/02/15 08:32 PM
02/02/15 08:32 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
do you have a factory 440 truck?
I'm asking because you've gotta have the correct Power Brake Booster.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Aftermarket Valve Covers on an RB [Re: shanker] #1743729
02/03/15 02:40 AM
02/03/15 02:40 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
I used M/T valve covers and had to shave the fins under the booster, even with the small booster.
Re: Aftermarket Valve Covers on an RB [Re: shanker] #1743730
02/03/15 05:08 AM
02/03/15 05:08 AM
Iowa
Iowa
Yes I know.
Re: Aftermarket Valve Covers on an RB [Re: 76dodgeboy] #1743731
02/03/15 05:46 AM
02/03/15 05:46 AM
Iowa
Iowa
Its a factory 440 Truck. I know the RB have and must use the Small diameter booster. Im going to be regasketing another 440 to stick in because the head gasket sprung a leak. I was wanting some First hand experiance with aftermarket Valve covers. I dont want a chrome stamped one.
I may end up just getting the Stockers Hydro Dipped. Thanks
Re: Aftermarket Valve Covers on an RB [Re: 76dodgeboy] #1743732
02/03/15 09:16 AM
02/03/15 09:16 AM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
The Mopar Performance cast valve cover hit the booster pretty hard in my truck. Might have been able to grind the fins down to clear but it still would have been too close for my liking. I removed the booster.
Re: Aftermarket Valve Covers on an RB [Re: tmef] #1743733
02/03/15 09:30 AM
02/03/15 09:30 AM
It's beer:30 somewhere
adventurer Offline
adventurer  Offline
I am running the Mopar Perf. cast aluminum covers, I did have to grind the fins down under the booster. I'll get you a pic this evening.
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: Aftermarket Valve Covers on an RB [Re: adventurer] #1743734
02/03/15 07:37 PM
02/03/15 07:37 PM
dogdays Offline
dogdays  Offline
A Hydraboost will cure all your problems, as long as you have power steering already.
R.
Re: Aftermarket Valve Covers on an RB [Re: dogdays] #1743735
02/03/15 09:56 PM
02/03/15 09:56 PM
adventurer Offline
adventurer  Offline
Not the greatest pic, but there is about 1/2" or so clearance between cover and booster, hope this helps you.
14 Ram R/T
Re: Aftermarket Valve Covers on an RB [Re: adventurer] #1743736
02/05/15 06:31 AM
02/05/15 06:31 AM
Iowa
Iowa
Thats exactly what I wanted to see. Anyone have the M/T or Holley Version? Thanks. This will help with a later build. I think the clubcab is just getting the stockers Hydro Dipped
Re: Aftermarket Valve Covers on an RB [Re: 76dodgeboy] #1743737
02/09/15 07:50 PM
02/09/15 07:50 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
M/T's but I moved my booster up.
Moparlee
Re: Aftermarket Valve Covers on an RB [Re: Robbins] #1743738
02/09/15 07:51 PM
02/09/15 07:51 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
shot of it raised
Moparlee
Re: Aftermarket Valve Covers on an RB [Re: Robbins] #1743739
02/09/15 07:53 PM
02/09/15 07:53 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
An 85 1 ton small booster with Mopar Performance valve covers would still hit with the fins taken all the way off. In this picture the fins weren't machined off yet....and the booster wouldn't sit flush against the firewall with or without fins. Ended up selling the MP ones to a member here.
Moparlee
Re: Aftermarket Valve Covers on an RB [Re: Robbins] #1743740
02/10/15 01:12 AM
02/10/15 01:12 AM
Iowa
Iowa
What did you do if anything the the brake rod?
Re: Aftermarket Valve Covers on an RB [Re: 76dodgeboy] #1743741
02/16/15 06:36 AM
02/16/15 06:36 AM
Iowa
Iowa
This is the route I went with.
Re: Aftermarket Valve Covers on an RB [Re: 76dodgeboy] #1743742
02/16/15 06:38 AM
02/16/15 06:38 AM
Iowa
Iowa
Re: Aftermarket Valve Covers on an RB [Re: 76dodgeboy] #1743743
02/16/15 06:39 AM
02/16/15 06:39 AM
Iowa
Iowa
Finished product
Re: Aftermarket Valve Covers on an RB [Re: 76dodgeboy] #1743744
02/16/15 06:40 PM
02/16/15 06:40 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
How many hours did that take?
Moparlee
Re: Aftermarket Valve Covers on an RB [Re: 76dodgeboy] #1743745
02/16/15 09:12 PM
02/16/15 09:12 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Cool!
