Too much oil pressure #1743581
02/01/15 12:03 AM
02/01/15 12:03 AM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I built a 500" RB for a customer, (stock block) and used the oil pump that was on the old engine. It's a Melling HV oil pump with a Milodon cover, single external line from a Milodon static pick up. When I primed the engine new, it had over 100 lbs of oil pressure. I replaced the oil pump regulator and spring with a new one from a Milodon overhaul kit. That brought the oil pressure down to about 85-88 lbs with a drill and priming shaft. I'd like it around 70-75 lbs idling. Whats the best way to bring this down?
Thanks,
Brian
Re: Too much oil pressure [Re: '72CudaRacer] #1743582
02/01/15 12:25 AM
02/01/15 12:25 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
non-HV pump
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Too much oil pressure [Re: astjp2] #1743583
02/01/15 01:27 AM
02/01/15 01:27 AM
Wi.
old_racer Offline
old_racer  Offline
Wi.
how about a spring from a stock pump? why would you want 70-75 lbs idling?
Re: Too much oil pressure [Re: old_racer] #1743584
02/01/15 02:40 AM
02/01/15 02:40 AM
Montana
67DodgeCharger Offline
On vacation
On vacation
Montana
Hot Rod has an article that covers the issue of too much oil pressure, except it being a chevy engine. The owner was breaking distributor gears from too much pressure from the oil pump and a very aggressive cam. The mechanic changed out the cam, lifters and I think the rockers, I have an old brain that works really good for an hour or less. The owner had a miss match of parts to compensate for problems of parts breaking, I would look at your setup and see if you are going to cause some problems with too much oil pressure.
Re: Too much oil pressure [Re: '72CudaRacer] #1743585
02/01/15 04:26 AM
02/01/15 04:26 AM
Thanks,
Brian
I have cut and ground one to two coils off the high pressure springs in those pumps(mellings high volume) to get 60 to 70 lbs at or above 6500 RPM with hot thin (5W20WT) oil Cut twice to avoid cutting to much the first time Most BB Mopars will idle at or below 30 lbs less than when above 6000 RPM with hot oil I like and use the old school rule of using 10 lbs. per thousand RPM with hot oil Most of those high volume and high pressure pumps use the same bypass springs so they will usually bypass at or close to 80 lbs cold. Let us know what you end up doing and the resultant pressure
Re: Too much oil pressure [Re: '72CudaRacer] #1743586
02/01/15 10:31 AM
02/01/15 10:31 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Thanks,
Brian
Is it idling at 85 psi now, or priming at 85 now?
Re: Too much oil pressure [Re: BSB67] #1743587
02/01/15 10:58 AM
02/01/15 10:58 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What oil? What temp? Mine has over 100 psi cold with 5w30. Warm 25@1300, 65@7000. The drill won't tell you much.
Doug
Re: Too much oil pressure [Re: dvw] #1743588
02/01/15 01:16 PM
02/01/15 01:16 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
On the dyno the priming pressure is always higher then what the running pressure is. Before i would "fix" it, I would start the engine and see where your at.
Joe
Without Data, you’re just another guy with an opinion.
Re: Too much oil pressure [Re: '72CudaRacer] #1743589
02/01/15 02:09 PM
02/01/15 02:09 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Thanks,
Brian
That pressure will be considerably less once the oil is up to operating temp. Let it warm up and see where you're at.
75 PSI seems like a lot of pressure to me but if that is where you want it at hot idle, depending on how fast it idles, you may be putting the other spring back in.
Kevin
Re: Too much oil pressure [Re: '72CudaRacer] #1743590
02/01/15 02:09 PM
02/01/15 02:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
This is what I use. Be forewarned back it off a bit when installing it mine went to 150LB on a milidon pump now maxes at 65 to 70 cold hot.
You want volume a small pump can't supply if it needs it hot under power so HV pump with right spring is just the ticket. On a HV pump in the old days I used to have 110 going out the end for 25 years don't hurt anything but using more power than needed.
http://www.manciniracing.com/milbrbadregk.html
http://www.summitracing.com/int/parts/mil-21550
Re: Too much oil pressure [Re: Dodgem] #1743591
02/01/15 07:53 PM
02/01/15 07:53 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
2011 Drag Pak Challenger
Re: Too much oil pressure [Re: rickseeman] #1743592
02/03/15 01:53 AM
02/03/15 01:53 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Too much oil pressure equals bad things
Filter could blow off or burst at the seams
Wash the bearings
Overcome the rear main seal
Is this a street motor?
Re: Too much oil pressure [Re: '72CudaRacer] #1743593
02/03/15 11:35 AM
02/03/15 11:35 AM
gregsdart Offline
gregsdart  Offline
Stick with the original spring the pump came with, but like Cab said, shorten it a little at a time. It doesn't take much and is very easy to do. If you over shoot the mark, very thin shims behind the spring will bring it back up. I don't like the stock spring idea because someone else can come along and shim it, not knowing it is easy to put the spring into coil bind if you go too far. Then disaster strikes when the pressure goes off the chart.
