Re: Too much oil pressure
[Re: '72CudaRacer]
#1743586
02/01/15 10:31 AM
02/01/15 10:31 AM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
I built a 500" RB for a customer, (stock block) and used the oil pump that was on the old engine. It's a Melling HV oil pump with a Milodon cover, single external line from a Milodon static pick up. When I primed the engine new, it had over 100 lbs of oil pressure. I replaced the oil pump regulator and spring with a new one from a Milodon overhaul kit. That brought the oil pressure down to about 85-88 lbs with a drill and priming shaft. I'd like it around 70-75 lbs idling. Whats the best way to bring this down?
Thanks, Brian
Is it idling at 85 psi now, or priming at 85 now?
[Re: BSB67]
#1743587
02/01/15 10:58 AM
02/01/15 10:58 AM
Posts: 9,839 MI, usa
dvw
MI, usa
What oil? What temp? Mine has over 100 psi cold with 5w30. Warm 25@1300, 65@7000. The drill won't tell you much. Doug
[Re: dvw]
#1743588
02/01/15 01:16 PM
02/01/15 01:16 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
On the dyno the priming pressure is always higher then what the running pressure is. Before i would "fix" it, I would start the engine and see where your at.
Joe
Without Data, you’re just another guy with an opinion.
[Re: '72CudaRacer]
#1743589
02/01/15 02:09 PM
02/01/15 02:09 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Thanks, Brian
That pressure will be considerably less once the oil is up to operating temp. Let it warm up and see where you're at.
75 PSI seems like a lot of pressure to me but if that is where you want it at hot idle, depending on how fast it idles, you may be putting the other spring back in.
Kevin
[Re: '72CudaRacer]
#1743593
02/03/15 11:35 AM
02/03/15 11:35 AM
Posts: 10,001 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Stick with the original spring the pump came with, but like Cab said, shorten it a little at a time. It doesn't take much and is very easy to do. If you over shoot the mark, very thin shims behind the spring will bring it back up. I don't like the stock spring idea because someone else can come along and shim it, not knowing it is easy to put the spring into coil bind if you go too far. Then disaster strikes when the pressure goes off the chart.
