2 piece driveshaft confusion.FIXED. Now, headlights #1743252
01/31/15 05:28 PM
01/31/15 05:28 PM
Between Houston & Galveston TX
SattyNoCar Offline OP
On my 'new' '93 Dakota, its got a low speed vibration I'm trying to trace down. (Its not the tires for sure).
I went ahead and pulled the driveshaft assembly to check the u-joints and grease them.
According to info I pulled up on various websites, this assembly is NOT in phase because the yoke ears are not in the same plane.
Looks factory to me, what say you?
John
Re: 2 piece driveshaft confusion....... [Re: SattyNoCar] #1743253
01/31/15 08:59 PM
01/31/15 08:59 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Looks inline from here.
Re: 2 piece driveshaft confusion....... [Re: buildanother] #1743254
01/31/15 09:16 PM
01/31/15 09:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That's in phase. I am not sure what years were involved but there was a TSB to replace the two piece style with a one piece. This was to eliminate a low speed vibration or shudder on acceleration. It was for 2wd models only if I remember correctly.
Re: 2 piece driveshaft confusion....... [Re: NITROUSN] #1743255
01/31/15 10:42 PM
01/31/15 10:42 PM
Hmmmmm.....interesting. Wouldn't that make for one l-o-n-g driveshaft though?
Didn't find anything obviously wrong, so, I greased everything up and put it back in, and now the vibration is worse. Put everything back the way it was, didn't forget to tighten anything, the only difference is the fresh grease in the U-joints. At 35MPH, it now vibrates hard enough that the sun visors drop down a little.
Ran out of light tonite. Going to check things again tomorrow.
John
Re: 2 piece driveshaft confusion....... [Re: SattyNoCar] #1743256
01/31/15 11:16 PM
01/31/15 11:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Like I said I don't remember what years but it was a 2wd that the two piece was converted to a one piece. I think the problem is a tight joint and its right in front of your nose. Also double check the transmission mount. I don't know how you can say the shaft is out of phase as your picture clearly shows its in phase.
Re: 2 piece driveshaft confusion....... [Re: NITROUSN] #1743257
02/01/15 12:43 AM
02/01/15 12:43 AM
In that aspect, yes it is in phase, BUT quite a few websites I visited took the reading off the yolks. Based on pics like the one I attached, the drive shafts are NOT in phase.
John
Re: 2 piece driveshaft confusion....... [Re: SattyNoCar] #1743258
02/01/15 12:51 AM
02/01/15 12:51 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Your's is phased just like that one is. I don't get what you are looking at to be so confused?
Re: 2 piece driveshaft confusion....... [Re: SattyNoCar] #1743259
02/01/15 12:54 AM
02/01/15 12:54 AM
ND
dodgedon Offline
dodgedon  Offline
ND
Being "in phase" and "in plane" are two different things.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: 2 piece driveshaft confusion....... [Re: NITROUSN] #1743260
02/01/15 01:47 AM
02/01/15 01:47 AM
Yup, you're right. Just livin' up to my title I guess.... Blind Melon Chitlin
John
Re: 2 piece driveshaft confusion....... [Re: SattyNoCar] #1743261
02/01/15 01:51 AM
02/01/15 01:51 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Funny. When you had the shaft out could you move the all the joints smoothly esp the front one?
Re: 2 piece driveshaft confusion....... [Re: NITROUSN] #1743262
02/01/15 02:05 AM
02/01/15 02:05 AM
Yes. That was part of the reason I did pull the whole assembly rather than grease it in place, I wanted to feel how smoothly the joints moved. All moved smoothly, none felt 'tight', none felt rough. They were all the same style aftermarket joint, so, I assume they were all changed at once, and not individually as they wore out.
Before I pulled the joint free from the rear, I marked it to be sure to put it back the same way too.
John
Re: 2 piece driveshaft confusion....... [Re: SattyNoCar] #1743263
02/01/15 02:30 AM
02/01/15 02:30 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
im fairly sure that the splines just behind the center bearing will only let the shafts fit together one way,how is the center bearing,smooth,ruff?
my ladder of success is missing some rungs
Re: 2 piece driveshaft confusion....... [Re: rhad] #1743264
02/01/15 03:42 PM
02/01/15 03:42 PM
Center bearing spins smoothly. Rubber around bearing is tight, NOT dry rotted, cracked, etc.
John
Re: 2 piece driveshaft confusion....... [Re: SattyNoCar] #1743265
02/02/15 01:08 AM
02/02/15 01:08 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Its Not a Keyed Spline. It can be put in anyway
Re: 2 piece driveshaft confusion....... [Re: 76dodgeboy] #1743266
02/02/15 02:52 AM
02/02/15 02:52 AM
I found out it is. So,no it can't.
John
Re: 2 piece driveshaft confusion....... [Re: SattyNoCar] #1743267
02/02/15 05:33 AM
02/02/15 05:33 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Mine wasn't
Re: 2 piece driveshaft confusion....... [Re: 76dodgeboy] #1743268
02/02/15 05:35 AM
02/02/15 05:35 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
My bad your Talking Dakota I'm talking full size.
Re: 2 piece driveshaft confusion....... [Re: 76dodgeboy] #1743269
02/02/15 09:10 PM
02/02/15 09:10 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Tossed a balance weight. Delt with that several times...
Re: 2 piece driveshaft confusion....... [Re: ruderunner] #1743270
02/02/15 09:56 PM
02/02/15 09:56 PM
I had my mechanic look at it and thinks the same. There's no excessive slop anywhere, no obvious damage to either shaft.
So, now I gotta pull the unit again and get it balanced.
John
Re: 2 piece driveshaft confusion....... [Re: SattyNoCar] #1743271
02/03/15 02:10 AM
02/03/15 02:10 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
if you can tell where the weight is missing from you can put a screw type hose clamp o the shaft with the screw head where the weight was,it will take some adjustment but it can be done,ive seen pictures of shafts with two clamps on them,or just take it to a drive-line shop for a perfect balance
