2 piece driveshaft confusion.FIXED. Now, headlights
#1743252
01/31/15 05:28 PM
01/31/15 05:28 PM
Posts: 16,813 Between Houston & Galveston TX
SattyNoCar
On my 'new' '93 Dakota, its got a low speed vibration I'm trying to trace down. (Its not the tires for sure). I went ahead and pulled the driveshaft assembly to check the u-joints and grease them. According to info I pulled up on various websites, this assembly is NOT in phase because the yoke ears are not in the same plane. Looks factory to me, what say you?
John
Re: 2 piece driveshaft confusion.......
[Re: SattyNoCar]
#1743258
02/01/15 12:51 AM
02/01/15 12:51 AM
Posts: 18,409 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
In that aspect, yes it is in phase, BUT quite a few websites I visited took the reading off the yolks. Based on pics like the one I attached, the drive shafts are NOT in phase.
Your's is phased just like that one is. I don't get what you are looking at to be so confused?
[Re: SattyNoCar]
#1743259
02/01/15 12:54 AM
02/01/15 12:54 AM
Posts: 516 ND
dodgedon
ND
Being "in phase" and "in plane" are two different things.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: SattyNoCar]
#1743261
02/01/15 01:51 AM
02/01/15 01:51 AM
NITROUSN
Yup, you're right. Just livin' up to my title I guess.... Blind Melon Chitlin
Funny. When you had the shaft out could you move the all the joints smoothly esp the front one?
[Re: NITROUSN]
#1743262
02/01/15 02:05 AM
02/01/15 02:05 AM
SattyNoCar
Funny. When you had the shaft out could you move the all the joints smoothly esp the front one? Yes. That was part of the reason I did pull the whole assembly rather than grease it in place, I wanted to feel how smoothly the joints moved. All moved smoothly, none felt 'tight', none felt rough. They were all the same style aftermarket joint, so, I assume they were all changed at once, and not individually as they wore out. Before I pulled the joint free from the rear, I marked it to be sure to put it back the same way too.
John
[Re: SattyNoCar]
#1743263
02/01/15 02:30 AM
02/01/15 02:30 AM
Posts: 954 garnett kansas
rhad
garnett kansas
im fairly sure that the splines just behind the center bearing will only let the shafts fit together one way,how is the center bearing,smooth,ruff?
my ladder of success is missing some rungs
[Re: rhad]
#1743264
02/01/15 03:42 PM
02/01/15 03:42 PM
SattyNoCar
Center bearing spins smoothly. Rubber around bearing is tight, NOT dry rotted, cracked, etc.
John
[Re: SattyNoCar]
#1743271
02/03/15 02:10 AM
02/03/15 02:10 AM
rhad
garnett kansas
if you can tell where the weight is missing from you can put a screw type hose clamp o the shaft with the screw head where the weight was,it will take some adjustment but it can be done,ive seen pictures of shafts with two clamps on them,or just take it to a drive-line shop for a perfect balance
