water leaking from cylinder head,need advice #174314
12/24/08 07:01 PM
12/24/08 07:01 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
hi, i have a 72 barracuda with a 440 in it.car isjust a beater that i was trying to get on the road.it had a broken valve cover bolt towardsthe front of head near power steering pump which is on driver side.anyway i was drilling busted bolt out and doing well,until the idiot that i am went to deep and punctured water jacket.can i pour a jb weld type product in hole that id rilled to prevent water from comming upor do i have to remove head and get repaired.there is a freeze plug at the front of head that i can remove to maybe use the jb weld were the drill bit went through.thanks for any helpand happy holidays
Re: water leaking from cylinder head,need advice [Re: barryv] #174315
12/24/08 07:32 PM
12/24/08 07:32 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Can you tap it oversize and use sealant on the threads on the bolt or stud. Some of the exh. studs go into the water jacket. Or you could use a heilcoil.
Re: water leaking from cylinder head,need advice [Re: barryv] #174316
12/24/08 08:02 PM
12/24/08 08:02 PM
Kirkland, Washington
Pacnorthcuda Offline
OK, since were drilling in the threaded blind hole, and accidentally made it a through hole, the easiest fix would be to continue what your were going to do to repair the threads--I would use a threadsert if there's enough meat around the hole, helicoil with epoxy (to aid sealing)if there is not. Then insert a 1/4" stud, WITH epoxy or thread sealant. call it done
Re: water leaking from cylinder head,need advice [Re: Pacnorthcuda] #174317
12/24/08 08:11 PM
12/24/08 08:11 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
if i tap it complete and screw a stud in it with some type of sealant will the water make it up and of stud,thanks
Re: water leaking from cylinder head,need advice [Re: barryv] #174318
12/24/08 08:16 PM
12/24/08 08:16 PM
No thats what the sealant is for. Now some sealants are better than others. Epoxy will seal great (make sure to run a solvent--like laquer thinner) q-tip through the threads to degrease first)but its a pretty permanent installation. Teflon sealants--tape or compound, permatex etc. I would stay away from RTV for threads (because if the threads are disturbed after intial cure they can lose their seal)
Re: water leaking from cylinder head,need advice [Re: barryv] #174319
12/24/08 08:18 PM
12/24/08 08:18 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Your fix will work. I had water leaking around a valve cover bolt on a 440 restoration job. I tapped the hole a little deeper, put a set screw in with sealer on it, and that way I was able to put a bolt in it, and it never leaked water when I took the bolt back out agai8n.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: water leaking from cylinder head,need advice [Re: doctor_mopar] #174320
12/24/08 09:25 PM
12/24/08 09:25 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
thanks for the help i thought i was going to have a bad vacation,now it seems like ill be ok,thanks again
