Two Piece Crank--440 go BOOM! #1742795
01/31/15 12:23 AM
01/31/15 12:23 AM
Anonymous OP
Anonymous OP
OK you know that a 727 will take out your 8 track if you do burn outs in first with a manual valve body--Right? The sprag fails and BOOM! I have done it--most Mopar racers have done ONE--but then we learn--OK..here is what happens when 727 explodes--shoves engine into radiator--this 440 was finished and sent out a few weeks back--it ran GREAT! Made some good HP with Sidewinders and .509 ( yea..the ole good one) during recent burn out "stunt" trans goes Pow! and customer advises engine has a tight spot now--OK bring it and we will look--HOLY SMOKES!! Yanked the pan and here is what we found
Re: Two Piece Crank--440 go BOOM! [Re: ] #1742796
01/31/15 12:25 AM
01/31/15 12:25 AM
Anonymous OP
Anonymous OP
Yikes!!
Re: Two Piece Crank--440 go BOOM! [Re: ] #1742797
01/31/15 12:27 AM
01/31/15 12:27 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Two Piece Crank--440 go BOOM! [Re: ] #1742798
01/31/15 12:29 AM
01/31/15 12:29 AM
Anonymous OP
Anonymous OP
Guessing this ain't covered under warranty
I have seen some wild ones but this is one for the record book. Trans exploded so hard it shoved engine through the radiator and did not do the rest of the car any favors either--Engine would still turn but was a little tight--crank was magged a few weeks before this by me and was AOK
I guess the sudden stop got her
Re: Two Piece Crank--440 go BOOM! [Re: ] #1742799
01/31/15 12:31 AM
01/31/15 12:31 AM
Anonymous OP
Anonymous OP
Got me a new door stop for the shop
Re: Two Piece Crank--440 go BOOM! [Re: ] #1742800
01/31/15 01:10 AM
01/31/15 01:10 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
"engine has a tight spot"
Re: Two Piece Crank--440 go BOOM! [Re: ] #1742801
01/31/15 01:14 AM
01/31/15 01:14 AM
Australia
P
Project kickin A Offline
P
Australia
bearings will go again lol
Re: Two Piece Crank--440 go BOOM! [Re: Project kickin A] #1742802
01/31/15 03:14 AM
01/31/15 03:14 AM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
ive seen a steel ford crank do that, but never a mopar big block.and the occasional cast sm block stroker crank.but thats what them sm block guys get when they race with a 300 dollar crank.thats one place i never buy cheap,i use winberg.they are truly a work of art..
SFI 25.5 depends,no leak,even at 213 mph....
Re: Two Piece Crank--440 go BOOM! [Re: dakotawilly] #1742803
01/31/15 03:42 AM
01/31/15 03:42 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I spun a rod bearing in a 426 wedge and it ran but would not idle
My fault, I just got the car and it was low on oil
Unfortunately that is the hard way to learn, but you never forget. Every time I break something I learn something new.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Two Piece Crank--440 go BOOM! [Re: Polarapete] #1742804
01/31/15 04:13 AM
01/31/15 04:13 AM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
did it run still? had an big block mopar irrigation pump do this once, it ran........terribly with the worst noises ever but it ran.
Re: Two Piece Crank--440 go BOOM! [Re: CTD5.9] #1742805
01/31/15 05:19 AM
01/31/15 05:19 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
I looked at a '70 383 Roadrunner that had a broken crank and still ran. Sounded like somebody was in the pan hitting the block with a big hammer.
Re: Two Piece Crank--440 go BOOM! [Re: CTD5.9] #1742806
01/31/15 11:53 AM
01/31/15 11:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a crawler-loader that has a 4 cyl diesel in
it... I broke the crank in it right under the #2 main
bearing.. I did it twice the same way.. it would just
loose power and a minor knocking... the main thing
it was a MAJOR PITA to get it fired up.. basically
it turned into a 2 cyl engine... I found out later
that the previous owner blew the head off the engine
using starting fluid.. I believe he cracked the crank
and bent the block
Re: Two Piece Crank--440 go BOOM! [Re: ] #1742807
01/31/15 12:34 PM
01/31/15 12:34 PM
Az
Crizila Offline
Crizila  Offline
Az
I used to have a "conversation shelf" in my office with stuff like that on it. Was he running a motor plate or conventional motor mounts? His 8 track still work??
Fastest 300
Re: Two Piece Crank--440 go BOOM! [Re: ] #1742808
01/31/15 01:45 PM
01/31/15 01:45 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Yikes!!
It's obvious..... the wrong pan gasket was used
Going to save and re-use that rear seal?
Re: Two Piece Crank--440 go BOOM! [Re: roadhazard] #1742809
01/31/15 05:13 PM
01/31/15 05:13 PM
Maryland
gofastboater Offline
Maryland
I once got a Coronet wagon with a 360 with a motor noise. Didn't figure it out until it wouldn't move. Crank broke on an angle between the #6 rod and the 4th main. It would start and run ok. The flexing of the crank finally broke the flex plate.
Re: Two Piece Crank--440 go BOOM! [Re: gofastboater] #1742810
01/31/15 05:35 PM
01/31/15 05:35 PM
P
Porter67 Offline
Porter67  Offline
P
Should of built the complete trans to match the motor.
Re: Two Piece Crank--440 go BOOM! [Re: Porter67] #1742811
01/31/15 06:57 PM
01/31/15 06:57 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Trans was not our doing. The new one is. Well known brand three letters TURNS to CRAP INSTANTLY. New trans has a proper Griner Low band apply valve body and good guts.
Motor mount was elephant ear type.
The motor shut off instantly when it popped. Barely nicked the rod. COULD easily been a total loss.
Todd
Re: Two Piece Crank--440 go BOOM! [Re: sasquatch] #1742812
02/03/15 11:03 PM
02/03/15 11:03 PM
jax. fla.
70Dustmite440 Offline
jax. fla.
Dang!!!!!!!!!!!
I still start my burnout in first, either i'm too old to change my ritual or my engines are too weak starting in second... or both
Hi guys
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
Re: Two Piece Crank--440 go BOOM! [Re: 70Dustmite440] #1742813
02/04/15 12:17 AM
02/04/15 12:17 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I even start my powerglide burn-outs in 2nd gear.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Two Piece Crank--440 go BOOM! [Re: pittsburghracer] #1742814
02/04/15 02:14 AM
02/04/15 02:14 AM
jax. fla.
jax. fla.
Maybe I'll give it a try.
